Print quality - low jerk low acceleration
I'd say this is probably the most helpful, polite and free of BS 3D printing forum I've come across.
+1.
+1 Indeed.
I really enjoy reading this forum. -
+1, I regularly stalk this forum just to absorb some of the ludicrous amount of knowledge contained herein.
here you go 950 vs 50 jerk setting left to right marvin respectively. Thanks
That's better then. It also confirms my theory that most instances of "ringing" aren't actually caused by the print head vibrating due to some sort of resonance, but rather that the print head was doing exactly what it was told to do, and in this case it was due to the instantaneous speed change ("jerk" as we have to call it) being set too low. Glad it worked for you.
Very interesting! So, a simple cylinder can highlight this?
I guess that the instantaneous speed change should be as low as possible, to avoid shaking to much the machine, but high enough to avoid such artifacts. Am I right ? So, one should start with a low value, print some cylinders with different diameters (smaller ones should have more artifacts, right?), and increase the value until artifacts are gone?
And if they don't go away, this means than there is a mechanical issue…
Yes that pretty well sums it up - works for me anyway. I create the cylinders using OpenScad and set the number of segments to 100 ($fn) so the size of each segment will increase as the diameter of the circle increases.
One effect of using a constant $fn is that the angle between segments will always be the same. It's the angle between segments that determines the minimum value that the XY jerk needs to be for a give print speed. The theoretical minimum XY jerk you need is approximately (printing_speed * 6/$fn) when $fn is large.
To check that you haven't set the jerk too high, print octagons and see how the machine sounds.
That sounded very subjective… I'll see if I can find octagons to print. How does it should sounds like if jerk set too high? Rough corner turn? Banging sound perhaps?
Stephen
Banging sound.
It is subjective to some extent but you can still compare one setting against another. It;s how it prints that's important but in my experience if it sounds "rough" or the motion looks "rough", it prints "rough".
Fair comment. My rationale about using the same $fn was to keep the angle the same but vary the length of the segments, but what you say is also a valid approach - possible more so.
If you have over extrusion in corners, try increasing pressure advance.
I made a test on a simple 20x20x2 cube: I used 0.1, 0.2 and 0.4, but it didn't improved (not even really changed) the over-extrusion in angles. In fact, the angle where extrusion stats/stops at each layer is worse.
I also tried to increase jerk on E, from 10mm.s⁻² to 20mm.s⁻², without success.
Any idea why? Could it be another problem?
@fma:
Can you post the photos?
