LE TORRI NEL GRAFICO
M666 Endstop adjustments X-1.63 Y-1.84 Z3.46
I'm not positive, but I think this would indicate that the endstop on your Z tower is much farther out of position compared to your other towers.
Auto calibration can compensate I think, but the recommendation is to be within 1mm of each other.
https://docs.duet3d.com/en/User_manual/Tuning/Delta_calibration#m666-command
@phaedrux forse non riesco a spiegarmi la distanza fisica dei fine corsa al piano di stampa per ciascuna torre risulta uguale con m666 x0 y0 z0 e stampa corretto (quindi se sono corretti i fine corsa ,perché mi corregge z 3.46 non può esserci un errore di 4mm . ma se lancio il g32 o g29 mi cambia sia la distanza fisica dei fine corsa al piano di stampa sia m666 =X-1.63 Y-1.84 Z3.46, e in piu' non stampa piu',la soda e' una BLTouch funziona correttemente. (
@rjenkinsgb said in LE TORRI NEL GRAFICO:
Kossel
ciao ho letto che hai fatto diversi progetti, ecco la mia domanda :nella progettazione di una delta Kossel che limiti si hanno dimensionalmente
@phaedrux CIAO CARO maximum size delta bed AND OF THE TOWERS MANAGED BY Duet3D WIFE, IT HAS LIMITS
@luca-massimiliano said in LE TORRI NEL GRAFICO:
I am not sure what you are saying.
@phaedrux using my Duet3D WIFE I would like to build a new delta printer, are there any size limits, for example the maximum height or the print radius, would I like to build a new delta printer?
Start by reading this. I am building Delta 1400 high 550 diameter.
@tecno thanks tecno my question: are there maximum size limits for the management of my Duet3D WIFE card?
@tecno GeoGebra dSim graphic simulato non riesco aprire scaricare i programmi dei vari simulatore tu quale usi ?simulated I can not open download the programs of the various simulator which one do you use?
If there are limits, they are likely higher than anything you intend to build as I've seen some real giants running Duets. How big are you planning to go?
@phaedrux THEY ARE IN THE INITIAL PHASE, BUT YOUR ANSWER IS IMPORTANT TO START TO DO THE PROJECT, I WOULD NEED I WOULD LIKE TO DOWNLOAD THE PROGRAMS OF THE VARIOUS SIMULATORS FOR DELTA CAN YOU INDICATE ME?
Sorry, but I don't understand what you're asking me for. I don't have any delta simulator software.
I would like to download an application for the kinematic simulation of a delta, in order to design one of this type https://www.geogebra.org/m/Br52nAjP this has size limits, it does not go beyond the delta radius 200 max
HERE is a link to a linear delta simulator with source so you can change the radius to what you need.
@alankilian
GRAZIE ALAN , MI POTRESTI INSEGNARE A SCARICARLO , C'E' UN MODO PARTICOLRE ? HO ALCUNI FILE NON RIESCO
Go to that link, click on the "code" button and choose "Download ZIP"
Then unzip the file and you will see a list of files:
Read the "Readme_first.txt file to learn now to use OpenSCAD
You will need to download and install OpenSCAd and then double-click on the file Delta_simulator.scad to run the sinulator
@alankilian THANKS ALAN, I INSTALLED EVERYTHING. I TAKE THE OPPORTUNITY TO WISH YOU SERENE EASTER HOLIDAYS TO YOU AND TO ALL THE FRIENDS WHO HELPED ME. THANK YOU
