New experimental firmware 1.20 alpha 2
"M552 P10.71.163.xxx S1" this is what I had in my config before the upgrade and it worked. I have never used M587.
Is this what I should have now?
M552 S1
M587 P10.71.163.xxx -
On the Duet WiFi, the P parameter in "M552 P10.71.163.xxx S1" will not have had any effect.
I didn't realize that.
I've released 1.20alpha4. Changes since alpha 2 are:
A resurrect.g file is now created any time that you pause the print. So you can pause a print, turn the printer off, and resume it subsequently - subject to a few conditions e.g. you can home the printer without disturbing the print, and the print will not detach from the bed while the heater is off. This feature is also supported on the older Duets.
Changed to a later version of the compiler, and to the hardware floating point ABI on the newer Duets.
Just FYI I installed alpha 2 on my kossel XL, and after the print finished it went on an excursion, the effector moved up and right outside the travel limits, knocking the side panel out of my enclosure, which is quite robust.
So I installed alpha 7 from the edge folder and it works fine. So hopefully a non-issue.
Thanks. We're running alpha7 on 2 of the 3 printers we have at the TCT show.
Ill come and have a look tomorrow.
Hello
With each update it works better and better on my scara
tests on ==> DuetWiFiFirmware-1.20alpha7.bin
1.20beta1 is now available, with further improvements over alpha7.
eh eh
I test tomorrow ! -
OK i give up. Where are the gcode files going on the micro SD card?
They are in the Gcodes folder.
