DUEX 5 V0.8 TO DUEX 5 V0.11
@paolozampini1973 No, I just want to check that the two extruder drives work in DueX2 mode.
@droftarts a moment I have problem with the Z switch the switch LEDs light up but it never stops and you have to configureconfig (19).g
@droftarts can you help me because the Z switches no longer intervene
@paolozampini1973 Move Z2 endstop to ystop on Duet 2. Change config.g to:
M574 Z2 S1 P"!zstop+!ystop"
@droftarts said in DUEX 5 V0.8 TO DUEX 5 V0.11:
Now I have this problem
@paolozampini1973 Either Home X and Y first, or send
M564 S0 H0
to allow axes to move without homing, then home Z.Ian
@droftarts it is already included in the configuration
@paolozampini1973 Send
G92 X0 Y0 Z0
@droftarts DONE
@droftarts what a problem before he did not
@paolozampini1973 Post a picture of the Duet. I think the endstop is plugged in in the wrong place.
@droftarts Sorry, I realise that ystop was not free; the Y axis was using it already. There should not be a problem using a duex endstop, though.
dovrebbero esserci problemi nell'utilizzo di un duex endstop.
Yes exactly but it doesn't work anymore it has always worked perfectly so what do you do
@droftarts That is, the Switches no longer work, the LEDs are signaled but it no longer works, it no longer stopsthe problem occurs on both Z axes when it reaches the end of the stroke In which the LEDs light up but it does not stop anymore
@paolozampini1973 DueX2 should allow use of all 5 endstops. To test, plug the Z2 endstop back into duex.e6stop, change config.g back to
M574 Z2 S1 P"!zstop+!duex.e6stop"
Turn off Duet. Put DueX5 jumper back on. Turn on, and test Z homing.
Then turn off Duet, remove DueX5 jumper, turn on and test Z homing.
@droftarts 22/3/2022, 16:35:46 Error: short-to-ground reported by driver(s) 7 8 9
Error: over temperature shutdown reported by driver(s) 7 8 9so nothing works anymore and gives The error that I always complained always said
@paolozampini1973 Also, the X endstop line is wrong. X0 means no endstop, it should be X1 or X2, eg:
M574 X1 S1 P"!xstop"
@paolozampini1973 said in DUEX 5 V0.8 TO DUEX 5 V0.11:
That's because the on-board drivers are disabled. Ignore it for testing Z.
@droftarts so the Z axis doesn't work eitherconfig (20).g
@droftarts you are right because you rightly want to try how it goes like this the aces if they have a loss of pace I understand what you want to do you are fine with me too you are right but unfortunately it cannot be done
