DUEX 5 V0.8 TO DUEX 5 V0.11
@droftarts
i can't move them because i have it busy driver 5 driver 6 are busy driver 4 is busy driver 3 is busy there are 4 extruders connected
@droftarts Sorry my dear I sent you the photos because I can't explain I have 4 instructors as you can see from the photos they are connected then I need two outputs for X and Y then I need two independent outputs for Zeta and this seems to me that we understand each other Have patience because the printer is a bit complex
self-leveling takes place via two switches As you can see from the photos Look carefully at the photos Maybe so I can explain myself better Forgive me for my poor English -
@paolozampini1973 Can you move the motor connected at the bottom of the image, to the top?
- DRIVER 3 E0 extruders
DRIVER 4 E1 extruders
DRIVER 5 E2 extruders
DRIVER 6 E3 extruders
TOTAL 4 extruders
these are four extruders these Drivers are already engaged Tell me if I have made myself clear please - Z1 DRIVER 2 Z2 DRIVER 9 Here are the independent AXIS Z
@droftarts YES THIS Z2 that is Z2 driver 9
@paolozampini1973 said in DUEX 5 V0.8 TO DUEX 5 V0.11:
Yes. Can you move it as indicated?
@droftarts Yes of course I can move it but once we have moved Z you are doing all this to switch to DUEX 2 correct me if I'm wrong ?
Ok I moved Z2 But where do you tell me that's driver 1 = Y -
@droftarts I moved like you told me now what to do?
@paolozampini1973 In config.g, change:
M569 P1 S1 ; Z2 (Y) physical drive 1 goes forwards M584 X7 Y8 Z2:1 E3:4:5:6 S0 ; set drive mapping
Reset after this change, then test Z works correctly
@droftarts AXIS Z OK
M574 Z2 S1 P"!zstop+!duex.e6stop" I have to reconfigure it as I configure it because otherwise the switches don't work rightly? -
@paolozampini1973 duex.e6stop should still work in DueX2 mode, but if you want you can move it to the Duet 2. I suggest ystop.
@droftarts Yes you're right No it's okay let it stay where it is
@droftarts Ok Now what do you want me to do ?
@paolozampini1973 Next, remove these 4 jumpers on DueX:
1 for DueX2 mode:
3 to disable on board stepper drivers:
@droftarts Yes I have already done this
Including the jumper on EN9?
@droftarts YES
Reset Duet and DueX. Check that DueX is recognised as DueX2. Send M122 to check.
@droftarts 22/3/2022, 15:31:27 M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later + DueX2
Board ID: 0JD0M-9P6M2-NW4SN-6J1DD-3SJ6K-KAURK
Used output buffers: 6 of 24 (20 max)
Static ram: 23876
Dynamic ram: 77448 of which 0 recycled
Never used RAM 13092, free system stack 184 words
Tasks: NETWORK(ready,10.5%,246) HEAT(delaying,0.0%,330) Move(notifyWait,0.1%,313) DUEX(notifyWait,0.0%,24) MAIN(running,86.4%,433) IDLE(ready,2.9%,29), total 100.0%
Owned mutexes: WiFi(NETWORK)
Last reset 00:00:25 ago, cause: power up
Last software reset at 2022-03-22 15:15, reason: User, GCodes spinning, available RAM 13092, slot 1
Error status: 0x00
Aux0 errors 0,0,0
Step timer max interval 0
MCU temperature: min 25.3, current 29.0, max 29.1
Supply voltage: min 25.6, current 25.7, max 25.8, under voltage events: 0, over voltage events: 0, power good: yes
Driver 0: position 0, standstill, SG min/max not available
Driver 1: position 0, standstill, SG min/max not available
Driver 2: position 0, standstill, SG min/max not available
Driver 3: position 0, standstill, SG min/max not available
Driver 4: position 0, standstill, SG min/max not available
Driver 5: position 0, standstill, SG min/max not available
Driver 6: position 0, standstill, SG min/max not available
Driver 7: position 0
Driver 8: position 0
Driver 9: position 0
Driver 10: position 0
Driver 11: position 0
Date/time: 2022-03-22 15:31:26
Cache data hit count 987899119
Slowest loop: 6.44ms; fastest: 0.18ms
=== Storage ===
Free file entries: 10
SD card longest read time 0.7ms, write time 0.0ms, max retries 0
=== MainDDARing ===
=== AuxDDARing ===
Heater 1 is on, I-accum = 0.0
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty.
=== Filament sensors ===
Extruder 0 sensor: no filament
Extruder 1 sensor: ok
Extruder 2 sensor: no filament
Extruder 3 sensor: ok
=== DueX ===
Read count 1, 2.32 reads/min
=== Network ===
Slowest loop: 39.64ms; fastest: 0.00ms
HTTP sessions: 1 of 8- WiFi -
Network state is active
WiFi firmware version 1.26
WiFi MAC address 40:f5:20:0d:6b:49
WiFi Vcc 3.37, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 23400
WiFi IP address 192.168.1.4
WiFi signal strength -63dBm, mode 802.11n, reconnections 0, sleep mode modem
Clock register 00002002
22/3/2022, 15:31:20 Connected to 192.168.1.4
- WiFi -
@paolozampini1973 Great. Test if the extruder drives on driver 5 and 6 work. These are tool 2 and tool 3. Send
M302 P1
to allow cold extrusion.Ian
