DUEX 5 V0.8 TO DUEX 5 V0.11
@paolozampini1973 What exact thermistors are you using? You have set the default, which will not be correct, and probably why temperature is incorrect.
M308 S0 P"bedtemp" Y"thermistor" T100000 B4138
And you need to move Z2 from driver 9 on DueX to driver 0 or 1 on Duet 2. You DueX is being recognised as a DueX2, so probably driver 9 is not working. If it is using an external driver, don't do that; drives on a shared axis need to be identical.
@droftarts Yes I set it to DUEX2 because the axes moved when I turned on the electronics Now I can't on DUEX5 Thanks for the dictation problems but for now it is more important to solve the problem of pitch loss and axis movement
@droftarts Yes I know that the engines must be identical and are identical
@paolozampini1973 said in DUEX 5 V0.8 TO DUEX 5 V0.11:
@droftarts Then send me the correct file as you think you are right and I will load it and do the tests you think that for this I lose the steps?
at this point what do I do I reassemble the v08 or I leave the V 011 I am willing to do any test Thank you please fill in the config file for me and I will load it exactly as you give it to me and I will let you know
It will have to be later, I have other things I must do.
I'd keep the V011 in for now.
Please show how you have wired the 74HC level shifters. Wiring diagram and/or photo.
@droftarts Listen to the 74hc I have to take it apart Because it gives me more problems it practically skips the steps at the entrance I have to give it three times and 8 and it doesn't skip my steps but if I give it 5 volts it skips my steps it practically gets worse
I did as you told me but the axes move by themselves without command Both X and Y
@droftarts I would like to leave V 011 but the Y x move without giving it the command so it is useless to talk about other problems there is to solve the first This is the problem Okay I'll wait when you get free I'll publish the config file thanks
21/3/2022, 15:38:13 Error: short-to-ground reported by driver(s) 7 8
Error: over temperature shutdown reported by driver(s) 7 8
21/3/2022, 15:38:08 Error: short-to-ground reported by driver(s) 7 8
21/3/2022, 15:38:04 Error: short-to-ground reported by driver(s) 7 8
21/3/2022, 15:37:59 Error: short-to-ground reported by driver(s) 7 8
21/3/2022, 15:37:55 Error: short-to-ground reported by driver(s) 7 8
21/3/2022, 15:37:50 Error: short-to-ground reported by driver(s) 7 8
21/3/2022, 15:37:49 M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later + DueX5
Board ID: 0JD0M-9P6M2-NW4SN-6J1DD-3SJ6K-KAURK
Used output buffers: 3 of 24 (20 max)
Static ram: 23876
Dynamic ram: 77448 of which 0 recycled
Never used RAM 13092, free system stack 184 words
Tasks: NETWORK(ready,10.4%,231) HEAT(delaying,0.1%,330) Move(notifyWait,0.1%,319) DUEX(notifyWait,0.0%,24) MAIN(running,86.5%,411) IDLE(ready,3.0%,29), total 100.0%
Owned mutexes:
Last reset 00:00:25 ago, cause: software
Last software reset at 2022-03-21 15:37, reason: User, GCodes spinning, available RAM 13092, slot 1
Error status: 0x00
Aux0 errors 0,0,0
Step timer max interval 0
MCU temperature: min 29.3, current 30.0, max 30.3
Supply voltage: min 25.6, current 25.7, max 25.8, under voltage events: 0, over voltage events: 0, power good: yes
Driver 0: position 0, standstill, SG min/max not available
Driver 1: position 0, standstill, SG min/max not available
Driver 2: position 0, standstill, SG min/max not available
Driver 3: position 0, standstill, SG min/max not available
Driver 4: position 0, standstill, SG min/max not available
Driver 5: position 0, standstill, SG min/max not available
Driver 6: position 0, standstill, SG min/max not available
Driver 7: position 0, temperature-shutdown! short-to-ground, standstill, SG min/max not available
Driver 8: position 0, temperature-shutdown! short-to-ground, standstill, SG min/max not available
Driver 9: position 0, standstill, SG min/max not available
Driver 10: position 0
Driver 11: position 0
Date/time: 2022-03-21 15:37:49
Cache data hit count 981081507
Slowest loop: 6.48ms; fastest: 0.19ms
=== Storage ===
Free file entries: 10
SD card longest read time 1.0ms, write time 0.0ms, max retries 0
=== MainDDARing ===
=== AuxDDARing ===
Heater 1 is on, I-accum = 0.0
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty.
=== Filament sensors ===
Extruder 0 sensor: no filament
Extruder 1 sensor: ok
Extruder 2 sensor: no filament
Extruder 3 sensor: ok
=== DueX ===
Read count 1, 2.36 reads/min
=== Network ===
Slowest loop: 39.88ms; fastest: 0.00ms
Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
HTTP sessions: 1 of 8- WiFi -
Network state is active
WiFi firmware version 1.26
WiFi MAC address 40:f5:20:0d:6b:49
WiFi Vcc 3.37, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 20888
WiFi IP address 192.168.1.5
WiFi signal strength -64dBm, mode 802.11n, reconnections 0, sleep mode modem
Clock register 00002002
Socket states: 0 4 0 0 0 0 0 0
21/3/2022, 15:37:46 Error: short-to-ground reported by driver(s) 7 8
21/3/2022, 15:37:41 Error: short-to-ground reported by driver(s) 7 8
21/3/2022, 15:37:39 Connected to 192.168.1.5
config (18).g
- WiFi -
Is that in both DueX2 mode and DueX5 mode?
@droftarts As you can see the errors alone are only when AND IN DUEX MODE 5 DRIVER 7+ DRIVER 8 ARE OFF IN DUEX 2 MODE IT DOESN'T GIVE SHORT-CIRCUIT ERRORS SO IT IS NOT NORMAL IN MY MEETING
@droftarts No in DUEX2 MODE they do not move by themselves they move only with the command IN DUEX5 MODE THE MOVEMENT HAS BEEN ALONE WITHOUT COMMAND
@droftarts from my experience it tells me that this expansion has problems but I think they are more software problems and not hardware problems Tell me what you think
Also because I'm sorry if I always repeat the same thing but I find myself with so many problems that I did not have Maybe some of these problems are not aware I will tell you more I tried to disconnect everything on the problem outputs it gives the same so on all the drivers I am disconnected disconnected nothing is connected and it still gives problems in duex 5 mode -
@paolozampini1973 You need to run the Duex in Duex2 mode. In this way it will disable the internal drivers on 7,8,9 allowing you to have external drivers on 7 & 8 for your X & Y axes.
If you have it in Duex5 mode BOTH the internal and external drivers are connected which is causing the movement without commands. -
@droftarts Listen to me when I say something and before I say something I think about it I don't talk to Ugh the problem now that I still have to solve the problem But you have to understand you are a hardware problem or a software problem as I said before for me it is a software problem and obviously before I had a small problem now I have big problems so what I ask you and please please please at least try to understand if it is a hardware problem or a software problem because otherwise I am forced to upgrade to version 0.8
unless I could print with some pitch loss problem but at least I could print now I have practically the printer stopped
@tekkydave Excuse me but if I do as you say or three motors that I cannot use then I still have a big problem So what is the advantage of having bought the 011 version because I have these problems that I have with the 011 I did not have them so explain to me you this solution that you recommend me maybe I don't understand Thanks very kind
@paolozampini1973 @droftarts has already given the solution:
Move the Z2 axis from output 9 on the Duex to either 0 or 2 on the Duet.
Put the Duex in Duex2 mode.
Make the changes to config.g that he will be giving to you.Once that is done lets see what remaining problems there are.
@tekkydave my printer configuration:
Z is configured with two INDEPENDENT motors FOR SELF-LEVELING one on Driver 1 = Z one on the driver 9 = Z then X = DRIVER 7 EXSTERNAL DM860H Y = DRIVER 8 EXSTERNAL DM860H then I have 4 driver instructors 3 TMC2660 + driver 4 TMC2660 + driver 5 TMC2660 + driver 6 TMC2660
PROBLEMS WITH DUEX5 V0.11 IN DUEX5 OFF DRIVE MODE 7 AXIS X + DRIVER 8 AXIS Y WHY I NEED TO USE IT
are engaged or four independent extruders in total there are 8 motors Now I am sending you how I configured the printer and This is how it must be then the solution of You tell me how I can do it if I have 8 motors -
@paolozampini1973
I'll do it by means of a table:Driver Axis ------ ----- 0 unused 1 Z1 2 Z2 3 E1 4 E2 5 E3 6 E4 7 X (external) 8 Y (external) 9 unused (external)
This is all 8 motors. The Duex is in Duex2 mode.
@tekkydave DRIVER 5 + DRIVER 6 in DUEX mode 2 they do not work they are disabled understood This is a test that I have already done they do not work only 7 8 and 9 works I think you don't know this thing you've never tried But they don't work
@tekkydave I repeat then this is not a solution this is to turn the problem because as I repeat with the 0.8 these problems I did not have the 0.11 HAS problems Then honestly buying a version that should solve some problems but instead you create other problems this is not normal what I mean understood I Thanks for your kind attention Thank you but in this way you do not solve the problem it turns it creating even more problems
Correct - I haven't tried it. I only have a duex2 in my printer as I only have one extruder and 3 Z motors plus X & Y. I am simply repeating the information that others have already given days ago. Good luck solving your issues. Now I am convinced this thread is a Turing Test
@tekkydave Please Unfortunately, this version has problems that in the design phase it can happen that one does not notice it But in fact I now take down the 0:11 you were MonterĂ² from 08 However I do not recommend to buy the 011 Until proven otherwise it is that I now have 6 problems including 4 are very serious
