Proposed removal of DHT11 sensor support
Funnily enough I am just trying to configure a DHT11, but as it reads a temperature in the thousands °C I assume it is faulty... IMHO DHT11 can be dropped if alternatives are available. I would love to see support for the more accurate and nearly as cheaply available BOSCH BME280 instead.
Edit: Maybe even BME680 to allow the filter fan to run based of the VOC reading inside the chamber?
@pixelpieper You can go for DHT22. It's more accurate and has the same footprint - and it works with 3.2.2
BME280 could be supported vis the SPI daughter board connector, but the driver would need to be written. Does it offer any advantages over the DHT22?
BME680 could be supported likewise.
@dc42 this should give you an overview https://randomnerdtutorials.com/dht11-vs-dht22-vs-lm35-vs-ds18b20-vs-bme280-vs-bmp180/
The BME280 also has pressure.
It generally gives more stable readings compared to a DHT22 -
I don't have time to write a BME280/BME680 right now, but if anyone else wants to then I will provide advice. It should use SPI protocol and the primary sensor class should be derived from SpiTemperatureSensor.
"long time no see", I know this a bit old, but just stumbeld upon this comparison "shoot-out" and it seems there are better alternatives to the DHT´s on the long run: https://www.kandrsmith.org/RJS/Misc/Hygrometers/calib_many.htmlQuestion is now for me: What do I need to train to write the library for e.g. the sensirion e.g. here https://sensirion.com/de/produkte/katalog/SHT45/ or https://sensirion.com/de/produkte/katalog/SHT85/ (we have sensirion at work also) and the bosch (given the fact that the temperature-max is a bit low but humidity seems to be pretty on spot https://www.bosch-sensortec.com/products/environmental-sensors/humidity-sensors-bme280/)
Lucas
@lbtqsb I've added
BMP280BME280 support as an item for consideration in the RRF 3.5 development cycle. -
that is really cool! Thank you! I hope my post was not too "threatening", or was it "too good", I rather not know We currently test at work printer with duet-mainboard (duet3mini) with heated chamber to around 70°C (goal is to reach around 95°C till end of the year (need to switch cables and or maybe motors for that) and you can already now see that the dht´s drift away from our other laboratory temperature probes, e.g. when our good calibrated voltcraft probe I installed right next to the dht inside says chamber has 70 dht tells me 65 and so forth, let´s see what even higher temperatures will show Can report back if that stays same with 3.4 or higher, but I think the posted website shows already that dht´s can vary quite a bit +- so the easiest would be to switch to something that has a lower error (also the bosch seems to give rather "hot" values back). On the very long run (3.5/3.6 or even higher) it would be great to be able to calibrate temperature-probes, first maybe by a simple +- value and maybe later with a LUT but I remember I had this discussion already in the forum some time ago...
@lbtqsb the SHT45 and SHT85 are I2C only, so only usable reliably with very short cable lengths. The BME280 also does SPI, which is better with longer cable lengths and will fit in with the existing SPI temperature sensor support, so I plan to support it.
Have you considered using a thermistor or PT100 or Pt100 sensor to monitor the chamber temperature? Or do you need to monitor humidity as well?
Thanks! Definetly I can cut the cable shorter! Will try that. Ah you are right we do not really need humidity, it was more a test to see how a heated chamber maybe could drive out relative humidity as well. Yeah so I guess on the long run it will be replaced by a "classic" temperature sensor. Albeit in the filament-chamber of course it will stay there to trigger for now an alarm to swap dry-bags and on the long run have an automated dehumidifier take care of that.
Thanks! -
@lbtqsb btw I didn't find you post at all threatening. I had been looking at the BMP280 and BME280 already.
