firmware retraction
hello, I wanted to test the firmware retraction but I have a problem, with the same settings as my slicer, my filament moves back with each retraction to the point where it no longer feeds the tool, M207 S5 F3000 Z0.1
Circuit: Duet 2 WiFi (2WiFi)
Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta7+7 (2022-01-14)
Duet WiFi Server Version: 1.23 -
Are you still using wipe or coast in the slicer?
Can you post your config.g?
Are you sure you have firmware retraction enabled in the slicer?
@bastien said in firmware retraction:
3.4.0beta7+7
You may want to update to 3.4 RC2
I enabled firmware retraction in cura
after M207
Tool 0 retract/reprime: length 5.00/5.00mm, speed 50.0/50.0mm/sec, Z hop 0.10mm -
@bastien sounds like you might be using absolute rather than relative extrusion in the slicer.
@droftarts I had thought about it, but I am in relative extrusion, and I have M83 at the beginning of my config.g, when the retraction is managed by the slicer, everything is fine, but not the firmware
@bastien Can you make the gcode file that you are trying to print available. Or at least a section of it which shows a few retract/unretract cycles. It might also help if you post your complete config.g file as well as your slicer start code.
@deckingman
my config.gG90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"Predator" ; set printer name M665 L440.000 R221 B185.0 H456 ; Set delta radius, diagonal rod length, printable radius and homed height M665 L415.000 R222.5 B185.0 H486 ; rod alu M666 X0 Y0 Z0 A0.00 B0.00 ; put your endstop adjustments here, or let auto calibration find them ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S1 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S0 ; physical drive 0 goes forwards M569 P1 S0 ; physical drive 1 goes forwards M569 P2 S1 ; physical drive 2 goes forwards M569 P3 S1 ; physical drive 3 goes forwards M584 X0 Y1 Z2 E3 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X160 Y160 Z160 E392.5 ; set steps per mm M566 X1000 Y1000 Z1000 E1000 ; set maximum instantaneous speed changes (mm/min) M203 X12000 Y12000 Z12000 E1200 ; set maximum speeds (mm/min) M201 X3000 Y3000 Z3000 E3000 ; set accelerations (mm/s^2) M906 X1000 Y1000 Z1000 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 Z0 S1 ; set minimum Z ; Endstops M574 X2 S1 P"xstop" ; configure active-high endstop for high end on X via pin xstop M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop M574 Z2 S1 P"zstop" ; configure active-high endstop for high end on Z via pin zstop ; Z-Probe M558 P5 C"e0stop" H8 F120 T6000 ; set Z probe type to switch and the dive height + speeds M558 H10 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved G31 P500 X0 Y0 Z14.95 ; set Z probe trigger value, offset and trigger height M557 R175 S20 ; Define mesh grid G29 S1 ; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B4300 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M307 H0 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S80 ; set temperature limit for heater 0 to 80C M308 S1 P"e0temp" Y"thermistor" T100000 B4300 ; configure sensor 1 as thermistor on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit ; Fans M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Retraction ;M207 S4.0 F5000 R-0.025 T2500 Z0.5 M207 S6.5 F3700 Z0.1 ; Custom settings are not defined ; Custom settings are not configured ;M572 D0 S0.1 ; Pressure Advance ;M591 D0 P2 C"e1stop" S0 ; Activate filament sensor M404 N1.75 ; Set for print monitor ;M592 D0 A0.07772 B-0.00029 ; Nonlinear extrusion. Set parameters for extruder drive 0 ; Miscellaneous M575 P1 S1 B57600 ; enable support for PanelDue M501
Could you show photo examples of what results you get with both?
@phaedrux said in firmware retraction:
3.4.0beta7+7
this. the 3.4 betas are known (and confirmed) to have a retraction issue..
@bberger said in firmware retraction:
it's ok after update thanks
