Issue after updating 3.4 beta 6 to 3.4 RC1
@flopo76 Please open the JS console via F12 and check for JS errors when you get performance issues. DWC should not be affected by the M80/M81 bug seen in another thread.
This post is deleted! -
@flopo76 Thanks, please upgrade to this DWC version: https://pkg.duet3d.com/testing/DuetWebControl-SD.zip Then please try to reproduce the problem and check the console again. If the same bug occurs as seen from your log, you should get an extra
Failed to parse response:
message in the JS console. Please right-click that message and copy it to clipboard, then paste it here. -
@chrishamm Updated the DWC no print stats. On 5i display all ok.
PollConnector.js:105 Failed to parse response:
{"fileName":"0:/gcodes/V350_z_drive_main_b_x2.gcode","offset":6680585,"data":"9G0 F6000 X200.839 Y151.582G1 F4800 X204.532 Y147.889 E0.16676G0 F6000 X203.966 Y147.889G1 F4800 X200.839 Y151.016 E0.1412G0 F6000 X200.839 Y150.451G1 F4800 X203.4 Y147.889 E0.11567G0 F6000 X202.834 Y147.889G1 F4800 X200.839 Y149.885 E0.09011G0 F6000 X200.839 Y149.319G1 F4800 X202.269 Y147.889 E0.06457G0 F6000 X201.703 Y147.889G1 F4800 X200.839 Y148.754 E0.03904G0 F6000 X200.839 Y148.188G1 F4800 X201.137 Y147.889 E0.01348G0 F6000 X201.137 Y147.11TIME_ELAPSED:8411.749681G1 F2100 E-0.8M140 S0M82 ;absolute extrusion modeG91 ;relative positioningG1 Z5 F500; move nozzle relative to positionG90 ;absolute positioningG1 X5 Y340M104 S0M140 S0G92 E0M109 S50M83 ;relative extrusion modeM104 S0End of GcodeSETTING_3 {"global_quality": "[general]\nversion = 4\nname = Fast #2\ndefiniSETTING_3 tion = voron2_350\n\n[metadata]\ntype = quality_changes\nquality_SETTING_3 type = fast\nsetting_version = 19\n\n[values]\nadhesion_type = brSETTING_3 im\nadhesion_z_offset = -0.1\nmaterial_bed_temperature = 85\nspeedSETTING_3 _slowdown_layers = 1\n\n", "extruder_quality": ["[general]\nversioSETTING_3 n = 4\nname = Fast #2\ndefinition = voron2_350\n\n[metadata]\ntySETTING_3 pe = quality_changes\nquality_type = fast\nsetting_version = 19\npSETTING_3 osition = 0\n\n[values]\nbottom_layers = 3\ncool_fan_enabled = FaSETTING_3 lse\nfill_perimeter_gaps = everywhere\ninfill_pattern = grid\ninfiSETTING_3 ll_sparse_density = 35\nline_width = 0.4\nmaterial_flow = 96\nmateSETTING_3 rial_flow_layer_0 = 98\nmaterial_print_temperature = 250\nretractioSETTING_3 n_amount = 0.8\nretraction_hop = 0.5\nretraction_speed = 35\nspeedSETTING_3 _layer_0 = 40\nspeed_print = 80\nspeed_roofing = 80\nspeed_topbottSETTING_3 om = 80\nspeed_travel = 100\nspeed_travel_layer_0 = 100\nspeed_walSETTING_3 l = 80\nspeed_wall_0 = 80\nspeed_wall_x = 80\nsupport_angle = 80\SETTING_3 nsupport_infill_rate = 30\nsupport_pattern = grid\nsupport_use_toweSETTING_3 rs = False\nsupport_xy_distance = 1\nwall_line_count = 4\n\n"]}","next":0,"err":1}q.onload @ PollConnector.js:105
load (async)
(anonymous) @ PollConnector.js:94
request @ PollConnector.js:93
_callee15$ @ PollConnector.js:781
tryCatch @ runtime.js:63
invoke @ runtime.js:294
(anonymous) @ runtime.js:119
asyncGeneratorStep @ asyncToGenerator.js:3
_next @ asyncToGenerator.js:25
Promise.then (async)
asyncGeneratorStep @ asyncToGenerator.js:13
PollConnector.js:793 SyntaxError: Unexpected token g in JSON at position 792
at JSON.parse (<anonymous>)
at XMLHttpRequest.q.onload (PollConnector.js:102:22)
_callee15$ @ PollConnector.js:793
_throw @ asyncToGenerator.js:29
_next @ asyncToGenerator.js:25 -
@flopo76 Thanks again, that's useful. Can you please share
as well? -
@chrishamm I can't upload the gcode,too big...
