Is filament chnage required?
@phaedrux yes it is coming always.
@phaedrux I cannot upload a zip or rar file??
@icy_snake said in Is filament chnage required?:
@fcwilt Good morning, no i have nothing there
Morning.
IdeaMaker uses what they call Templates. Templates have several places where code can be entered.
For whatever template is being used when you get the filament message check all of the possible code places shown below:
@fcwilt said in Is filament chnage required?:
All tabs are empty, already checked.
Well this is curious. I'm running out of ideas.
Do you have a start.g file?
you can change the extension to .txt and upload it or use a file sharing cloud service.
@phaedrux
ok here as a txt
icy_modix60_setup .txtHey it worked.
@fcwilt Here is my
pause.g
<; pause.g ; called when a print from SD card is paused M300 S1111 P222 M117"Is filament change required? Navigate to the macros tab and press on Filament Change" M564 H1 S1 ; M116 M83 ; relative extruder moves G1 E-10 F800 ; retract 10mm of filament G91 ; relative positioning G1 Z20 F360 ; lift Z by 20mm G90 G1 Y0 F6000 ; go to the front G1 X0 F6000 ; go to the left M300 S1111 P333 M291 R"Attention !" P"It is recommended to turn off the heaters if the pause is expected to last a long time" T46>
@fcwilt Here is my
pause.g
I meant you should look at it as it is the source of the filament change message you mentioned in an earlier post.
yes we have the macro which gives the message but not sure why it comes up during printing.
As i wrote in an other post that there are problems with statics voltage, do bad design of the printer.
I added ground to all metall pieces, had to get ride of paint etc.
Now i can touch the dispaly or printer without any failures or messages on the display.
my feeling is the reason was the missing grounding.
I´m printig now a big part, total progress 540h . already 96h done.
Thx for your help
Dieter -
Thx for your help
DieterIn the config.g file, down in custom settings, there are two triggers configured which, when activated, will run pause.g. The comments say they are connected to filament sensors, one for E0 and one for E1.
Something must be happening to cause the filament sensors to activate the triggers.
I think it's as simple as filament not being loaded in the second tool.'
One way around this is to move the filament sensor activation into the tool change files so that the sensor is only checking for filament when it's the selected tool.
@phaedrux said in Is filament chnage required?:
Why would you monitor filament sensors with triggers rather than use the M591 command?
@fcwilt Probably a hold over from the original Modix files?
