Duet3D 1HCL - Closed Loop Controller Beta test
This post is deleted! -
@t3p3tony
Hey
I think I'll try it with different timing.
I use the suggested nema 17 from stepperonline. Can you provide me your M569 T ?
I'm a bit frustrated
KR
Richard -
@gruna-studio I am using the default step timing (i.e. no T parameters in M569)
@samlogan87 stall detection should work in open loop mode, however RRF cannot yet use stall homing for motors connected to expansion boards.
@dc42 bugger. Thanks for that. Any idea when it might be implemented
@samlogan87 we're planning to implement it in RRF 3.5.
Note, stall homing is less accurate than homing using a switch; so not recommended if you want to support resume-after-power-fail.
@t3p3tony
Ok thanks a lotI have constant layer shift on X axis. Can't solve it since days and several more boards are on the way.
Open a thread was not helping because nobody answered. HahaPlease help me
@gruna-studio I saw you deleted the thread, I was not sure why. Do you want to restore that thread so we can discuss the issue there? If you like I can restore the thread for you.
I have already trying a lot of things, so that this thread wasn't actual anymore.
Then I made a new one which is still online but after two days I could delete that, too.
It's also not up to date anymore.I'm Sorry
So I'll change the boards and motors later on and will make a new thread.
Did you use 48 volt?
I "saw" a shift. The motor was less noisy and slower then normal for a short second. Like you shift in a to low gear in a car.
Thanks for you reply
I just ordered 4 more 1HCL - I'm very optimisticThanks
Richard -
@gruna-studio please do repost with an uptodate setup.
I used 24V on my printer thus far.
@t3p3tony Thanks, snagged some up at Compass! Excited to try them!
Finally got the printer back up and running after rebuilding most of the mechanism. Still need to square it up as I think some of the noise is rail misalignment. That’s 1000mm/s at 30000mm/s acceleration using 48v to drive the boards
@samlogan87
Nice
