duet3d 3.3 delta calibtating problems after fimware update
@ololenok here are the files easier to read
config.g; Configuration file for Duet WiFi (firmware version 3.3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.3.10 on Sat Jan 29 2022 23:54:53 GMT+0200 (Восточная Европа, стандартное время) ; General preferences M575 P1 S1 B57600 ; enable support for PanelDue G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"Oloprint" ; set printer name ;M665 L322.000:325.662:319.857 R130.135 H275.281 B130.0 ; Set delta radius, diagonal rod length, printable radius and homed height ;M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them M665 L322.000:325.662:319.857 R130.132 H278.910 B130.0 X-1.006 Y-0.612 Z0.000 M666 X0.644 Y-1.835 Z1.191 A0.00 B0.00 ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S1 ; physical drive 0 goes forwards M569 P1 S1 ; physical drive 1 goes forwards M569 P2 S1 ; physical drive 2 goes forwards M569 P3 S1 ; physical drive 3 goes forwards M584 X0 Y1 Z2 E3 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z80.00 E420.00 ; set steps per mm M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min) M203 X18000.00 Y18000.00 Z18000.00 E4800.00 ; set maximum speeds (mm/min) M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2) M906 X1400 Y1400 Z1400 E800 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 Z0 S1 ; set minimum Z ; Endstops M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop M574 Z1 S1 P"zstop" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin zstop ; Z-Probe M558 P5 C"!^e0stop" H5 F120 T6000 I1 ; set Z probe type to switch and the dive height + speeds G31 P500 X0 Y0 Z0.182 ; set Z probe trigger value, offset and trigger height M557 R85 S20 ; define mesh grid ; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 ;M307 H0 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit M307 H0 R0.805 C340.143:340.143 D4.58 S1.00 V24.3 B0 I0 M140 H0 ; map heated bed to heater 0 M143 H0 S130 ; set temperature limit for heater 0 to 130C M308 S1 P"e0temp" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 ;M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M307 H1 R2.371 C277.016:267.141 D5.28 S1.00 V24.2 B0 I0 M143 H1 S280 ; set temperature limit for heater 1 to 280C ; Fans M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined ; Miscellaneous ;M579 X0.9966 Y1.0176 ; set scaling G29 S1 ; Enable mesh compensation M911 S21 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss M501 ; load saved parameters from non-volatile memory T0
config-override
; config-override.g file generated in response to M500 at 2022-01-31 23:12 ; This is a system-generated file - do not edit ; Delta parameters M665 L322.000:325.662:319.857 R130.132 H278.910 B130.0 X-1.006 Y-0.612 Z0.000 M666 X0.644 Y-1.835 Z1.191 A0.00 B0.00 ; Heater model parameters M307 H0 R0.805 C340.143:340.143 D4.58 S1.00 V24.3 B0 I0 M307 H1 R2.371 C277.016:267.141 D5.28 S1.00 V24.2 B0 I0 ; Workplace coordinates G10 L2 P1 X0.00 Y0.00 Z0.00 G10 L2 P2 X0.00 Y0.00 Z0.00 G10 L2 P3 X0.00 Y0.00 Z0.00 G10 L2 P4 X0.00 Y0.00 Z0.00 G10 L2 P5 X0.00 Y0.00 Z0.00 G10 L2 P6 X0.00 Y0.00 Z0.00 G10 L2 P7 X0.00 Y0.00 Z0.00 G10 L2 P8 X0.00 Y0.00 Z0.00 G10 L2 P9 X0.00 Y0.00 Z0.00
bed.g
; bed.g ; called to perform automatic delta calibration via G32 ; ; generated by RepRapFirmware Configuration Tool v3.3.10 on Sat Jan 29 2022 23:54:53 GMT+0200 (Восточная Европа, стандартное время) M561 ; clear any bed transform ; Probe the bed at 3 peripheral and 3 halfway points, and perform 6-factor auto compensation ; Before running this, you should have set up your Z-probe trigger height to suit your build, in the G31 command in config.g. ;M913 X30 Y30 Z30 ; set X Y Z motors to 50% of their normal current DELETE IT!!!! G30 P0 X0 Y84.9 H0 Z-99999 G30 P1 X73.53 Y-42.45 H0 Z-99999 G30 P2 X-73.53 Y-42.45 H0 Z-99999 G30 P3 X0 Y42.4 H0 Z-99999 G30 P4 X36.72 Y-21.2 H0 Z-99999 G30 P5 X-36.72 Y-21.2 H0 Z-99999 G30 P6 X0 Y0 H0 Z-99999 S6 ; Use S-1 for measurements only, without calculations. Use S4 for endstop heights and Z-height only. Use S6 for full 6 factors ; If your Z probe has significantly different trigger heights depending on XY position, adjust the H parameters in the G30 commands accordingly. The value of each H parameter should be (trigger height at that XY position) - (trigger height at centre of bed)
@ololenok so the first question is do you really have arms/rods on your delta that are 3 different lengths?
i suspect not, which makes this line very wrong.secondly, you shouldn't have G29 S1 in your config as you shouldn't be loading the heightmap until after the printer has been homed.
your endstops are set at being at the lower end, they should be at the higher end. Change X1 to X2 in M574 and so on.
@jay_s_uk
Thank you so much for your reply!-
The rod lengths are the same, but looks like the printer xyz tower distance is not the same (the build is not very accurate, my fault, firs project higher than 70cm). So I've made different rod length in config to compensate geometry while calibrating it with test prints.
where should I place G29 S1 to auto-load it each time the printer boots? Looks like it is the thing that's causing the problem...
@ololenok i think you can add your G29 at the end of your homing file (home delta) if you'd like to load the heightmap after every homing...
@cosmowave
I'll check it today, thank you.
I just thought it would cause an error since the homing is not finished an that moment (the whole homing script is not finished still and mesh load command is in it) -
@ololenok as @cosmowave says or use start.g or put it in your start gcode after homing the machine
@ololenok said in duet3d 3.3 delta calibtating problems after fimware update:
Warning: the height map was loaded when the current Z=0 datum was not determined probing. This may result in a height offset.
Likely this is part of your issue. You should do a single G30 at the center of your bed to set the z=0 datum before creating your heightmap (I think you missed this?), and before loading the heightmap to avoid an offset.
As the others said, you shouldn't load your heightmap until after the printer is homed etc. If you do a delta calibration with a heightmap loaded, it will mess up the calibration as they two things will fight each other
@engikeneer , looks like the firmware behaviour has changed a lot since v1.21 (it worked fine on that version). Also the config generator gave some very raw results for v3.3, like strange homedelta.g with movements after homing that lead to additional problems.
I'll clean up that mess and test everything.
Thank you for reply.
@engikeneer @cosmowave @jay_s_uk
Thank you guys for your time! Everything is working fine now.
(changed endstop types, moved G29 to start.g, making by hands G30 before mesh grid creation) -
That's likely a result of mistakenly having it set to low end endstops at the beginning.
