RRF Update to 3.3 just killed my FW
Tried to update from 3.0 to 3.3. It just hung. After about 20 minutes I gave up and rebooted. Now I can no longer connect to the machine via wifi, the extruder fan stays on and I can't get it to respond on the panel due at all. The update killed it.
OK... so I will need to do a new install. HOW? I do not see new install instructions anywheres only updates. -
It's likely that that wifi server didn't get updated correctly.
Try sending M997 S1 on the panel.
Otherwise connect via USB terminal and see what you can see there with M122.
Also, did you update your config.g to enable the paneldue itself? That must be done in RRF3.
M575 P1 B57600 S1
@andy-cohen if the firmware did update to 3.3 (connect via USB, send M115) send
M997 S1 P”0:/sys/DuetWiFiServer.bin”
Otherwise it will look in the /firmware folder, which doesn’t exist, and you’ll get an error message. 3.3 and later keeps firmware updates out of the sys folder.
Unfortunately... nothing seems to work at all. It acts like it cannot see the SD card and the extruder fan goes on. The update looks like it killed my whole setup!
Can't I simply take the SD card out and make changes? -
There are config changes required between 3.0 and above. Can you post your current config.g?
You can remove the SD card from the Duet and check the config.g on your PC.
A firmware update can't kill anything. We just need you to connect the board via USB terminal to see what is actually going on.
@phaedrux I was able top get the wifiserver running thanks to your post.
It looks like quite a bit of the config is no longer working. Great. -
The changes between 3.0 and up are pretty minor.
The change between RRF2 and RRF3 are more substantial. What firmware were you running before?
You can get an example config updated for 3.3 from the config tool to compare against. https://configtool.reprapfirmware.org/Start
@phaedrux I started with a late v2 and I'm lost with the new approach with the M950. Is there a web app I can use to gen the gcode?
@andy-cohen said in RRF Update to 3.3 just killed my FW:
Yes. I linked it in my last post.
Here's what I normally tell people when they want to update from RRF2
If you still have access to DWC. Upload these 3 zip files, one at a time in the system tab. Don't extract them first. Reboot after each. Use M115 in the gcode console to verify the firmware has been applied.
https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
https://github.com/Duet3D/RepRapFirmware/releases/download/3.3/Duet2and3Firmware-3.3.zip
That will get your firmware and DWC up to date.You can see the change logs here:
https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.xFor your config, might be a good idea to run through the configurator tool and generate a fresh set for RRF3.
https://configtool.reprapfirmware.org/StartBackup your existing config files in the sys folder in case you want to switch back to RRF2. It’s easy to switch back and forth, just upload the zip file for the version you want and then upload your config files.
These documents will come in handy during the conversion.
https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview
https://duet3d.dozuki.com/Wiki/Gcode -
Thanks for the help.
I was able to get it to kinda work. It still does not see my extruder heater, only the bed heater. This is the heater gcode in the config file I generated:; Heaters
M143 H1 S280 ; set temperature limit for heater 1 to 280C -
@andy-cohen Here's the tool def:
G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C -
What does not see it?
Can you send M122 and M98 P"config.g" in the gcode console or USB terminal and share the results?
@andy-cohen Yeah... I see it... The web app did not make the P1 tool.
@phaedrux OK... heaters and fans seem OK.
Now the motors. They won't home. Comparing with my original config, I see nothing that can be incorrect. Any ideas?
M92 X88.57 Y88.57 Z400.00 E125.459271 ; set steps per mm
M201 X1000.00 Y1000.00 Z20.00 E250.00 ; set accelerations (mm/s^2)
M906 X800 Y800 Z400 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X300 Y195 Z210 S0 ; set axis maxima; Endstops
M574 X2 S0 P"xstop" ; configure switch-type (e.g. microswitch) endstop for high end on X via pin xstop
M574 Y2 S0 P"ystop" ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin ystop
M574 Z1 S0 P"zstop" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin zstop -
M574 Z1 S0 P"zstop" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin zstopS0 is incorrect.
If the signal needs to be inverted, use S1 and add a
to the front of the pin name.M574 X2 S1 P"!xstop"
@phaedrux It moves but the limit switches are ignored. When told to Home X it moves it on an angle. It's a coreXY machine so I got something wrong..
Why oh WHY was soooo much changed?!? -
You'll have to share your config and homing files at this point for any meaningful feedback.
Are you sure it's set to corexy kinematic?
@phaedrux Heck... at this point I'm not sure of anything!
I also suspect the wifiserver FW needs to be updated as well as the ManelDue.; Configuration file for Duet WiFi (firmware version 3.3)
; generated by RepRapFirmware Configuration Tool v3.3.10 on Mon Jan 31 2022 16:37:49 GMT-0800 (PST); General preferences
M550 P"My Printer" ; set printer name; Network
M550 P"CloneDuet" ; Set machine nameM552 S1 ; Enable network
M586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Disable FTP
M586 P2 S0 ; Disable TelnetM552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M574 X2 S1 P"!xstop" ; configure switch-type (e.g. microswitch) endstop for high end on X via pin xstop
M574 Y2 S1 P"!ystop" ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin ystop
M574 Z1 S1 P"!zstop" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin zstop; Z-Probe
M558 P1 C"zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
M557 X10:300 Y-16.0:195 S20 ; define mesh grid; Heaters
M563 P1 ; Define tool 1
G10 P1 X35 Y0 Z0 ; Set tool 1 axis offsets
G10 P1 R0 S0 ; Set initial tool 1 active and standby temperatures to 0C; Custom settings are not defined
Yeah... you were correct.
There's no
"M669 K1 ; switch to CoreXY mode"
I added it and now it seems to work. -
Can you send m122 and share the results?
