Dudes about Bltouch
i am configuring Ratrig printer, and i have isues with Zprobe...
Printer mounts a BlTouch, but when i order the printer Homing, X and Y axis are fine, but Z Duet send a message that are not z probe defined.When power on the printer, BlTouch do selftest, but when i send macros to deploy, retract and test, do nothing.
a strange thing is that in config.g that Ratrig facilitates for the configuration, for the BLTouch it indicates that you put these lines...
; BLTouch M950 S0 C"io7.out" ; Create a servo pin on io7 M558 P9 C"io7.in" H5 F240 T10800 A5 ; set Z probe type to unmodulated and the dive height + speeds G31 P25 X-28.00 Y-13.00 Z0.90 ; set Z probe trigger value, offset and trigger height, more Z means closer to the bed
But... Bltouch, its connected to io2
Too add retractprobe.g and deployprobe.g
; deployprobe.g ; Called to deploy a physical Z probe ; M280 P0 S10 ; Deploy the BLTouch pin
and
; retractprobe.g ; Called to retract a physical Z probe ; M280 P0 S90 ; Retract the BLTouch pin
ideas, why not are detected when homing procedure?
one thing more, after start printer and do selftest, BlTouch rest lighted
@peirof Change the io7 in M558&M950 to the connections you have, io2.
@fcwilt yes
