[3.4.0Beta7/RC1] MZV and ZVDDD Causing Firmware Crash
@kevinmar I was able to revert the config.g
attached is the problematic config.g
config - MZV problem.gBeing ran on a Duet 6HC with a Pi 4b SBC
@kevinmar hmm in the config it's upper case... Has to be lower
@pcr it was lowercase when I ran it lol
just made it uppercase when I rewrote it for the forum -
@pcr also,
P"type" Type of input shaping to use, not case sensitive.
@kevinmar Can you post the output from m122 if the firmware is crashing this should provide some clues as to what is happening.
@gloomyandy I cannot access the machine immediately after the incident, but now that I've changed the config and booted it back up, here's the output
=== Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.4.0beta7+7 (2022-01-14 08:57:59) running on Duet 3 MB6HC v1.01 or later (SBC mode) Board ID: 08DJM-9P63L-DJ3T8-6JKDD-3SD6M-9V4Z9 Used output buffers: 1 of 40 (18 max) === RTOS === Static ram: 150968 Dynamic ram: 66704 of which 0 recycled Never used RAM 133000, free system stack 200 words Tasks: SBC(ready,0.9%,468) HEAT(notifyWait,0.0%,341) Move(notifyWait,0.0%,352) CanReceiv(notifyWait,0.1%,797) CanSender(notifyWait,0.0%,374) CanClock(delaying,0.0%,351) TMC(notifyWait,7.6%,92) MAIN(running,91.4%,923) IDLE(ready,0.0%,30), total 100.0% Owned mutexes: HTTP(MAIN) === Platform === Last reset 00:00:10 ago, cause: software Last software reset at 2022-01-16 13:49, reason: User, GCodes spinning, available RAM 133000, slot 2 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0044a000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a Error status: 0x00 Step timer max interval 182 MCU temperature: min 31.6, current 31.8, max 31.8 Supply voltage: min 24.0, current 24.0, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 12.1, current 12.1, max 12.1, under voltage events: 0 Heap OK, handles allocated/used 0/0, heap memory allocated/used/recyclable 0/0/0, gc cycles 0 Events: 0 queued, 0 completed Driver 0: pos 0, standstill, SG min n/a, mspos 8, reads 5698, writes 0 timeouts 0 Driver 1: pos 0, standstill, SG min n/a, mspos 8, reads 5698, writes 0 timeouts 0 Driver 2: pos 0, standstill, SG min n/a, mspos 8, reads 5698, writes 0 timeouts 0 Driver 3: pos 0, standstill, SG min n/a, mspos 8, reads 5698, writes 0 timeouts 0 Driver 4: pos 0, standstill, SG min n/a, mspos 8, reads 5697, writes 0 timeouts 0 Driver 5: pos 0, standstill, SG min n/a, mspos 8, reads 5698, writes 0 timeouts 0 Date/time: 2022-01-16 13:49:37 Slowest loop: 1.63ms; fastest: 0.06ms === Storage === Free file entries: 10 SD card 0 not detected, interface speed: 37.5MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === DMs created 125, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 === GCodes === Segments left: 0 Movement lock held by null HTTP* is doing "M122" in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger* is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty === CAN === Messages queued 9, received 80, lost 0, boc 0 Longest wait 0ms for reply type 0, peak Tx sync delay 173, free buffers 50 (min 50), ts 5/5/0 Tx timeouts 0,0,0,0,0,0 === SBC interface === Transfer state: 4, failed transfers: 0, checksum errors: 0 RX/TX seq numbers: 1016/1016 SPI underruns 0, overruns 0 State: 5, disconnects: 0, timeouts: 0, IAP RAM available 0x2bd70 Buffer RX/TX: 0/0-0 === Duet Control Server === Duet Control Server v3.4-b5 Code buffer space: 4096 Configured SPI speed: 8000000Hz Full transfers per second: 40.84, max wait times: 33.8ms/0.1ms Codes per second: 1.00 Maximum length of RX/TX data transfers: 4526/1248```
@dc42 I have provided more detailed information above
@kevinmar are you using an F parameter in your M593 command, for the frequency you want to cancel? Input shaping won’t work without it. See https://duet3d.dozuki.com/Wiki/M593
@droftarts May not apply here, looking at Kevin's troublesome config.g, 'M593 P"mzv" F36' is used.
@KevinMar it looks like you are using Duet Control Server 3.4b5 instead of 3.4b7. Please upgrade it via the package server.
@dc42 Yep! That did it!
Silly me
