Unable to Edit Config Files in Duet Web Control
dc42,
I'm not the only one here reporting this problem. I'll grab another switch and setup a dedicated network with my laptop to see if that does it however confidence is low. -
OK. I grabbed a 10/100 switch off the shelf and created a two host network between my Macbook Pro and the Duet Ethernet. Both machines have manually configured IP addresses. I am still receiving the same errors in the browser and I still cannot edit a system file in web control. Like before, the failure associated with the editing of the file causes the web control app to loose connection to the Duet. This screenshot was taken just after the app lost its connection.
can you show a screen shot of the General page of the Settings tab please?
As requested:
ok next request can you take a screen shot of the contents of the WWW Directory you can use a FTP Client to get it if you dont want to remove the SD Card? I have a hunch but don't really want to elaborate for fear of sending you down the garden path.
Doug
as requested. at some point, i reformatted the SD card and reloaded the data. The www folder should just be the contents of the web control .zip file.
Just as an add-on, I'me getting kicked out of an FTP connection as well.
um well that has got me stumped now think you may have to wait on David. My hunch was wrong which is why I didn't want to say anything.
Can you install Wireshark on the Macbook and get a Wireshark trace of the packet exchange when it gives that error?
Do you have any other laptop or PC that you can try running DWC on?
Maybe try installing Chrome I believe that DWC sometimes gets upset with Safari
Those screenshots are Chrome. Same behavior w/ Safari
Here are the wireshark results:
https://www.dropbox.com/s/jk4lo94m9v66d8p/dwc.pcapng?dl=0
I did a hard refresh, then selected the config.g file for editing. Eventually DWC dropped an AJAX error and disconnected from the Duet. Also, you're not going to believe this, but it works in Microsoft Edge running in a Win10 VMware Fusion VM on my Macbook. Hmm.
however, after going back to the VM after taking that screenshot, I found DWC – in Edge -- with an AJAX error.
This still doesn't work. What shall I do now?
I'm sorry, I lost track of this thread during the TCT show. I have it on my todo list for next week to look at your Wireshark trace.
