How to enable berd air on 2nd heater
Hi all.
How can I get the berd air working on the 2nd heater output?
Have a flyback diode installed on the berd air.
Tis is my config file.
; Configuration file for Duet WiFi (firmware version 3.3)
; generated by RepRapFirmware Configuration Tool v3.3.4 on Mon Oct 18 2021 21:01:13 GMT+0200 (Midden-Europese zomertijd); General preferences
M550 P"DeltaPro" ; set printer name
M665 R120 L288.13 B110 H321.12 ; Set delta radius, diagonal rod length, printable radius and homed height
M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them; Network
M551 P"goretec" ; set password
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M350 E32 I0 ; configure microstepping without interpolation
M350 X16 Y16 Z16 I1 ; configure microstepping with interpolation
M92 X80.00 Y80.00 Z80.00 E800.00 ; set steps per mm
M566 X3000.00 Y3000.00 Z3000.00 E3000.00 ; set maximum instantaneous speed changes (mm/min)
M203 X12000.00 Y12000.00 Z12000.00 E12000 ; set maximum speeds (mm/min)
M201 X3000.00 Y3000.00 Z3000.00 E800.00 ; set accelerations (mm/s^2)
M906 X1700 Y1700 Z1700 E1000 I10 ; set motor currents (mA) and motor idle factor in per cent
M208 Z0 S1 ; set minimum Z; Endstops
M574 X2 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for high end on X via pin xstop
M574 Y2 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin ystop
M574 Z2 S1 P"zstop" ; configure switch-type (e.g. microswitch) endstop for high end on Z via pin zstop; Z-Probe
M558 P8 R0.2 S0.02 A5 C"zprobe.in+zprobe.mod" H5 F200 T10000 ; set Z probe type to effector and the dive height + speeds
G31 P25 X0 Y0 Z-0.143 ; set Z probe trigger value, offset and trigger height
M557 R105 S20 ; define mesh grid; Heaters
M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
M143 H0 S125 ; set temperature limit for heater 0 to 125C
M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
M307 H1 R2.464 K0.571:0.000 D8.42 E1.35 S1.00 B0 V23.8 ; disable bang-bang mode for heater and set PWM limit
M950 F0 C"fan0" Q10000 ; create fan 0 on pin fan0 and set its frequency
M106 P0 C"Layer Fan" S0 H-1 ; set fan 0 name and value. Thermostatic control is turned off
M950 F1 C"fan1" Q10000 ; create fan 1 on pin fan1 and set its frequency
M106 P1 C"Hotend Fan" S1 H1 T50 ; set fan 1 name and value. Thermostatic control is turned on; Tools
M563 P0 S"Hotend" D0 H1 F0 ; define tool 0
M955 P0 C"spi.cs4+spi.cs3" ; set acccelerometer to activateThanks in advance!!!
Greetings Kevin
