Carriage Adapter Suggestion for Rostock Max
I'll measure up when I get home tonight but I think its a 3mm screw with a flange. It will work drilling two holes but I don't know just how stable it will be.
Thanks. Why might drilling two holes be less stable?
Looking at the photos I think that they use a spigot for the Barbell to locate on and then the screws just to hold in in place. I think with just the 2 mounting screws in the middle whether the carriage would have a tendency to rock causing hight variations.
It might have the potential to rock as mentioned as Its only secured in 1 plane. Just a passing thought really. I'm pretty sure it will be OK.
The holes could be large enough to fit over the bosses, and a small block could be printed to fit over the bosses. It would be tall enough to just slightly raise above the bosses with the adapter plate in place, so that the screws (with washer) would sandwich the adapter plate in place.
yes I think that would work and in fact the adaptor plate could be quite large so as to stabilise it all
So Dimensions are as follows,
Holes are 22mm centre to centre
Spigot is 6.32mm
The screw holding it is a 3mm self tapping screw with 8mm washer on -
So we should add two 6.32mm holes spaced 22mm apart horizontally. Can someone else confirm these dimensions? We'd like to get a good fit so that the carriage adaptor is horizontal automatically.
I downloaded the Model file that PlasticMetal linked to and confirmed the dimensions:
24.125mm center-to-center, and 6.35mm inner diameter
I'm not sure if these are all the same spacing, but the ball cup axle fits on two screws mounted to the carriage.
First two photos are the version 3 Rostock (the trick laser carriage as well) and the last is perhaps the v2 that didn't use ball cup joints.
https://imgur.com/8iOzxYZ.jpg
https://imgur.com/WE6CjT0.jpg
https://imgur.com/KZxVUOv.jpgJust a correction as the later V2 came with the upgraded ball cup arms.
