BLTouch Probe Won't Deploy
Are you sure you've removed all cases of K0?
Can you try this?
Power cycle your printer
Before doing anything else, send M401 and M402 to test that the pin deploys and retracts.
If that works, send G30 by itself. Does the pin deploy? Does it give an error? Does the Z axis move? -
@phaedrux said in BLTouch Probe Won't Deploy:
Here is the new Z Probe section of the config.g
; Z Probe M558 P9 F120 H8 R0 T6000 A1 B0 C"0.io4.in" ; Set Z probe type. ; K (Z probe number): 0 (1). ; P (Z Probe type): 9 (BLTouch probe). ; F (Feed rate. Probing speed [mm/min]): 120. ; H (Dive height [mm]): 3. ; R (Recovery time [seconds]): 0. ; T (Travel speed [mm/min]): 6,000. ; A (Max number of times to probe each point): 1. ; B (Heaters): 0 (Leave all heaters on while probing). ; C (Endstop input): 0. (Mainboard) io4.in. M950 S0 C"0.io4.out" ; Create GPIO/servo pin. ; S (Output/servo pin number): 0. ; C (Pin name): 0. (Mainboard) io4.out. G31 P500 X0 Y22.0 Z3.105 ; Set Z probe. ; P (Trigger value): 500. ; X (Probe X offset [mm]): 0. ; Y (Probe Y offset [mm]): 22.000. ; Z (Probe Z offset [mm]): 3.105 (This is modified for Z probe calibration. A higher offset number moves the nozzle closer to the bed.). ; K (Z probe number): 0. M557 X25:325 Y25:313.5 P3 ; Define Z probe mesh grid (This is the probe point grid, not the nozzle grid). ; X (Min:Max X coordinates to probe [mm]): 35 (Min) : 325 (Max). ; Y (Min:Max Y coordinates to probe [mm]): 25 (Min) : 313.5 (Max). ; P (Points to probe in each direction): 3.
homez.g
; Voron. ; 0:/sys/homez.g ; Called to home the Z axis via G28 Z. ; 2020/10/24/20:02 G91 ; Set axes (not extruders) to relative positioning mode. G1 H2 Z5 F6000 ; Lift Z relative to current position. G90 ; Set axes (not extruders) to absolute positioning mode. G1 X175 Y151.5 F6000 ; Move X and Y axes so the Z probe is at the center of the bed. M558 F600 H2 A1 ; Set Z probe. Feed rate: 600 mm/min. Dive height: 2 mm. Times to probe: 1. G30 ; Z probe quickly (1 of 2 passes). M558 F120 H5 A1 ; Set Z probe. Feed rate: 120 mm/min. Dive height: 5 mm. Times to probe: 1. G30 ; Home Z by probing the bed slowly (2 of 2 passes).
and I no longer have the "0" on the deployprobe and retractprobe file names.
Pin does deploy and retract with M401 and M402 respectively.
When calling G30. I get this error.
g30 Error: G30: Insufficient axes homed for bed probing
@charlie said in BLTouch Probe Won't Deploy:
X and Y have to be homed - are they?
So, after getting this error:
I threw
G92 X0
, and thenG92 Y0
in the console.The probe did deploy in this instance.
@fcwilt
Yes, homed X and Y after getting that error. The probe did deploy in this case. -
So it seems all is working and it's just a question of you being sure that X and Y are homed before trying to use the probe.
That is one of the reasons I include a Z axis endstop sensor on all my printers so I can home Z without having to worry about homing X and Y first.
@fcwilt said in BLTouch Probe Won't Deploy:
That is one of the reasons I include a Z axis endstop sensor on all my printers so I can home Z without having to worry about homing X and Y first.The problem is that the probe isnt deploying when I am actually calling a homez.g or homeall.g. It is only deploying when I am following the exact workflow that @Phaedrux outlines here.
@PhaedruxPower cycle your printer
I wonder if it has something to do with your homeall setting the dive height to be less than the trigger height.
I also thought that G30 would work regardless of X and Y being homed since it should only trigger movement in Z.
The only other thing I can recommend for troubleshooting is to generate a basic config using the online tool and only customizing it manually to account for the basics and seeing if it works as expected.
Are you using toolboards or expansion boards or just the 6HC?
In this instance of attempting to home, I am using the "Home Z" button on the DWC. Here is my most current homez.g file.
M558 F600 H2 A1
This sets your dive height to 2mm, but your probe trigger height is over 3mm.
Do you see how that could be an issue?
Do you see how that could be an issue?Yes, I definitely see how that can be an issue. With that said, I set that value to 8mm and the issue persists.
I am using 6HC and an expansion board.
Do you need to be in G91 to run a G30? If I send a G90, then G30, I have the probing issue. If I send G91, then G30, it seems to probe. Is this my issue?
In you homing files where you are using G30 you are invoking G30 twice.
Now this is not related to your problem but you don't really need to do it twice.
So, as a test, change the code so you only do it once and be sure the dive height is large enough.
As a reference my dive height setting is 5 and the Z trigger height setting is 1.8. and I always start probing at Z=10.
I double checked my code to be sure and it is always put into G90 mode before do the G30.
The code is in GCodes3.cpp DeployZProbe() and RetractZProbe(), and looks ok.
Im not sure what this means. Please let me know if you would like to provide more information.
This was analysis of the firmware source code. It accepts 0 in the deploy/retract files and also K0. It was only a check, you don't need to do anything.
About your problem, I am currently thinking about whether moving -3 away from the endstop is maybe too low and not reset to no-contact or contact (I don't know your endstop), so the endstop may not trigger at the next slow move, which is G1 H1 and doesn't set the endstop triggered then.
E. g. such a type:
approached with high speed, 3 mm back may be too low. -
So, as a test, change the code so you only do it once and be sure the dive height is large enough.Correct. I am using the first G30 to do a coarse home, and then the second G30 to do a fine home.
I tried doing one G30, and the probe still did not deploy.
What do you mean that you always start probing at 10mm? Isnt that dependent on your last print height?
Okay, thats the way that it used to work for me as well. Now the probe wont deploy unless I have a G91 before my M558 and G30 in my homez.g file.
Did you remove the double G30s in the homing files?
@joergs5 said in BLTouch Probe Won't Deploy:
Okay, thank you for doing that analysis!
Im assuming that youre referring to the
G1 H0 X-3 F6000
in my homex.g file andG1 H0 Y-3 F6000
in my homey.g file. My switches are Omron 653-D2F-5L. It has 0.5mm of movement differential, but it couldnt hurt to try 5mm.
