CONSTANT AJAX disconnect errors
Dougal1957,
I will have to verify when I get home, but I am about 99% sure I do not have the "P" in front.
Do you think this could cause the random disconnects?
Thank You
don't think so but would explain the name being the default MyDuet on DWC
The M122 report will also tell you the RSSI (received signal strength) reported by the WiFi module.
I noticed that David, and if I remember correctly the RSSI was around -44dBm.
Since updating from 1.18 to 1.19.2 this morning I've had frequent communication errors and disconnects. THings had been rock solid on 1.18 for months.
When it disconnects, I see a Duet Web Control string for the printer name and this error
Communication Error
An AJAX error has been reported, so the current session has been terminated.
Please check if your printer is still on and try to connect again.David, let me know if there is any data/testing I can do. I have an identical printer 2' from this one running 1.18 and it has been rock solid all day today so I don't think it's my network.
Here's the M122 results:
ENDING:M122
Used output buffers: 1 of 32 (9 max)
RepRapFirmware for Duet WiFi version 1.19.2 running on Duet WiFi 1.0
Board ID: 08DAM-999TL-MQ4S8-6J9F6-3SJ6L-T4BBW
Static ram used: 21176
Dynamic ram used: 96200
Recycled dynamic ram: 1408
Stack ram used: 4048 current, 7932 maximum
Never used ram: 4356
Last reset 03:34:07 ago, cause: reset button or watchdog
Last software reset reason: User, spinning module GCodes, available RAM 7004 bytes (slot 2)
Software reset code 0x0003, HFSR 0x00000000, CFSR 0x00000000, ICSR 0x00400000, BFAR 0xe000ed38, SP 0xffffffff
Error status: 0
Free file entries: 10
SD card longest block write time: 0.0ms
MCU temperature: min 28.6, current 33.1, max 35.6
Supply voltage: min 24.4, current 24.5, max 24.9, under voltage events: 0, over voltage events: 0
Driver 0: stalled standstill
Driver 1: stalled standstill
Driver 2: stalled standstill
Driver 3: standstill
Driver 4: standstill
Date/time: 2017-09-13 15:26:11
Slowest main loop (seconds): 0.022163; fastest: 0.000000
MaxReps: 399, StepErrors: 0, FreeDm: 240, MinFreeDm 234, MaxWait: 3812623ms, Underruns: 0, 0
Scheduled moves: 56, completed moves: 56
Bed compensation in use: none
Bed probe heights: 1.751 1.645 1.587 1.795 1.845
Bed heater = 0, chamber heater = -1
Heater 1 is on, I-accum = 0.0
Segments left: 0
Movement lock held by null
http is idle in state(s) 0
telnet is idle in state(s) 0
file is idle in state(s) 0
serial is ready with "M122" in state(s) 0
aux is idle in state(s) 0
daemon is idle in state(s) 0
queue is idle in state(s) 0
Code queue is empty.
Network state is running
WiFi firmware version 1.19.2
WiFi MAC address 5c:cf:7f:2b:e6:eb
WiFi Vcc 3.10, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 39904
WiFi IP address 192.168.1.230
WiFi signal strength -84dBm
Reconnections 0
HTTP sessions: 1 of 8
Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)regards,
Michael -
I don't think the ESP is as sensitive when 1.19x is installed I had similar issues which I solved cos I had a Tl710 lying around which I pressed into service as a AP Point closer to the printer I now get reliable connectiion with an RSSI of approx -72 dBm
Hey Michael!
This is the issue I was telling you I was trying to solve when my G32 went all wonky! Glad, and sorry, to see you in here. Thanks for your diags!Dougal1957,
Sorry, but what is ESP? My router is about 5 feet from my printer, and if I recall correctly my RSSI was -44dBm (ill verify that in a bit). -
ESP is the WiFi module that is used on the Duet
I suspect it could overload as well as being to low but i am not an expert in this and I dont know what levels I was seeing before the 710 was put into use -
Thanks Dougal1957,
I can easily move the router to test the overload theory, but I highly doubt it will change. But hey, I'm not opposed to trying, as I am certainly no expert! I have noticed a lot more wireless networks around from the neighbors lately, so I probably need to go in and make sure I am on my own channels and such anyways.
After an M999 the Duet comes up, via USB an M587 shows the network. M552 S1 just seems to hang but M122 shows connected to access point. But I'm unable to load DWC pages. IP address is correct. M552 S0 then M552 S1 will allow me to reload DWC and connect.
Seeing WiFi signal strength -79dBm when it can connect and WiFi signal strength -82 to -84 dBm when not. Could it be that sensitive?
I have a NETGEAR AC1200 WiFi Range Extender arriving tomorrow.
It may help to know that I was having the same connectivity issues on 1.18 as I am on 1.19.2. I upgraded to 1.19.2 in an effort to resolve them. I know you said you were rock solid on 1.18, Michael, but I wasn't so maybe that can lend a clue here.
When you get the disconnects, does the Duet printer in question still show actively connected on your wireless network? Next time this happens I will ping the IP and see if it responds.
I am seeing that my Mac - which is in the same room 4' away is showing a good connection with RRSI -62dBm and 145 MBps transmit rate. But the Duet is more shielded in the base of the printer (delta) and closer to a wall so that could explain the signal drop. I'll report back when I have the AC1200 hooked up.
My router shows the Duet disconnected. Ping times out.
I'll jump in to this thread as well with same issue, I have multiple posts on this same issue in several threads
https://www.duet3d.com/forum/thread.php?id=2466#p24112
I "believe" I was not having issues on 1.18, but I only had my duet a week or so before the 1.19 upgrade came out.
I am also using a Mac as browser device, if that is an issue.My signal strength is quite strong:
WiFi MAC address 5c:cf:7f:a4:a1:64
WiFi Vcc 3.12, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 39168
WiFi IP address 192.168.2.53
WiFi signal strength -35dBm
HTTP sessions: 2 of 8
Socket states: 2 0 0 0 0 0 0 0
Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)This way we can summarize and keep it to one thread
Well, I changed the channel for my network to a new channel just as a test, updated the machine name and password, and have been running just off of wifi for about 30 mins now.
My RSSI is -44dBm
I was missing the "P" in front of the machine name/pass in my config.g files, so that fixes the issue with the web control always showing "My Duet."
I haven't been able to print, as my G32 went crazy after the update to 1.19.2
I will continue to test.
I've run with channel as auto, channel 1, channel 6.
No difference for myself in ability to stay connected.
I also do have the "P" in front of machine name.I've been connected for now 2 days without dropping,, As soon as I print, or sometimes calibrate I drop connection within 20 min, sometimes 2 min.
Edit:reason I have not lost connection in 2 days is because I've been busy and not done anything with the gui, nt because I've solved the issue.
I believe this dispels any lack of signal strength reasoning. Signal is strong but for some reason once commands, prints, calibration starts causing the printer to be active the wifi connection drops, as if it can't keep parallel processes going.Edit 2: reconnecting to the laptop remotely that has the browser interface running, which ran for 2 days, and now an hour later when I reconnect it has the AJAX error and another disconnect.
To all of you who are experiencing disconnections, but only when the printer is not idle:
After doing a print, what is the MaxReps figure in the M122 report? Please note, MaxReps gets reset every time you run M122.
David, just to be clear what you are asking… when the disconnect occurs during the print do you want us to let the print complete then attempt to connect and get the M122 report or use Pronterface and do M122 while the print is running? Or something else? I just want to collect the most useful info for you.
It doesn't really matter. It's probably most useful if you run M122 shortly after the disconnection, and again at the end of the print.
Also please report your printer geometry, steps/mm and maximum travel speed.
After print completed, reconnected and M122 from DWC:
MaxReps: 411, StepErrors: 0, FreeDm: 240, MinFreeDm 120, MaxWait: 10976ms, Underruns: 0, 0
Delta, M92: 800 steps/mm M350: 64 microsteps
Max travel: X Y Z 7200
