GPIO input at 5V
@alankilian If you want to trigger those inputs, wire in a CMOS IC such as the 74LV14 inverting buffer. It runs from a +5v supply and will invert your signal, while safely driving the GPIO input on the MPU.
If you don't want the signal inverted, then cascade two gates, serially. Be sure that you tie any unused input pins (there are 6 of them) to either GND or the +5V (this keeps the gate from oscillating and burning itself out).
enjoy!
@tomw Yes, that will work.
Or you can also use a single NPN or PNP transistor in fully-saturated mode depending on which way you want the drive to go.
@taconite said in GPIO input at 5V:
So that means that I can't trigger them with 5V
How do you plan to trigger them? What do you plan to connect to that input?
Thank you all for your replies @TomW @alankilian @zapta
I have been using the GPIOs already several times like this (not on this Duex 5 but on others and on Duet2s aswell)
the only difference is that I am not using a 4N35 anymore but TCMT4100
@taconite Hmmmmm.
I'm not understanding your circuit well.
I could guess which pins do what, but if you could add a part number and pin numbers above that would make me not have to guess.
(OK, I'll guess just to get started.)
- I think on the upper-right you mean that you pull that pin up to 5 Volts through a 10K Ohm resistor.
- I think there's probably a phototransistor between the upper-right and lower-right pins.
- I don't know if it's an NPN or PNP phototransistor.
- I think you've got the lower-right pin connected to a GPIO Input pin.
- I don't know quite how that's supposed to work.
The TCMT4100data sheet shows an example circuit like this and I think it will work for you.
@taconite if you don't mind the input being inverted, try this:
You can leave out R2 because the 10K pullup on the DueX will provide that function.
@alankilian
You are totally right - there are no such things as obvious - I am sorry that I did not provide all the information you need.@dc42
So In my head the Duet GPIO Inputs looks something like thisI don't mind if its inverted, the problem is that I already have a PCB with the functionality. Problem is that I am not that deep into circuit design. I don't get why it was working before ( did I plan the TCMT4100 wrong)?
EDIT:
Oh no I see my error ... -
The 10K pullup to +5V is permanent, it's a resistor on the DueX. No need to use ^ to get it.
But then I guess the documentation is wrong
@taconite thanks for pointing that out i have updated the M950 documentation to note that some IO pins may be pulled up and to check the hardware pages.
@taconite a couple of notes regarding your post:
- The internal circuit of the input looks like this, with no connection to ground.
- Since the input is pulled down, you want to connect your opto coupler between the input and ground and use the inversion symbol "!" if needed. (You could still have an external pullup resistor if the internal 10K is too high for your purpose, if this an issue, you can ask here).
BTW, if you would use a duet 3 board, you may be able to drop the opto coupler all together since some of the input are can get higher voltages.
