Can't connect to Duet 3 mini 5+ Ethernet
I have a new Mini 5+ Ethernet.
When I got the board I connected USB power and Ethernet cable, everything was fine.
I then ran the online config tool to the best of my ability, checked "update firmware", saved it and then used the web interface to upload my new config.
That seemed to hang and after that, I can't connect to it (Ethernet or USB).
The press "reset" twice, get a mapped drive and upload firmware works but after the reboot I'm back to no connection. I've tried several different firmware versions, no difference.The LAN interface does not do a DHCP request.
The USB port shows up as Duet 3 motion control electronics (COM3), but I can't connect to it (Pronterface 115200 baud).Any suggestions of what I should try next?
Regards
Soren -
@kingfranz can you post the contents of your config.g?
use the </> button to format it when posting -
@jay_s_uk ```
; Configuration file for Duet 3 Mini 5+ (firmware version 3.3)
; generated by RepRapFirmware Configuration Tool v3.3.5 on Mon Nov 29 2021 21:32:55 GMT+0100 (Central European Standard Time); General preferences
M550 P"3dprinter" ; set printer name; Network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M584 X0.1 Y0.2 Z0.3 E0.0 ; set drive mapping
M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
M203 X18000.00 Y18000.00 Z300.00 E1500.00 ; set maximum speeds (mm/min)
M208 X300 Y300 Z300 S0 ; set axis maxima; Endstops
M574 X1 S1 P"io1.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin io1.in
M574 Y1 S1 P"io6.in" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io6.in
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M950 S0 C"io3.out" ; create servo pin 0 for BLTouch
M558 P9 C"io3.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X-28 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
M557 X15:215 Y15:195 S20 ; define mesh grid; Heaters
M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
M950 F0 C"out3" Q500 ; create fan 0 on pin out3 and set its frequency
M106 P0 S0 H0 T45 ; set fan 0 value. Thermostatic control is turned on
M950 F1 C"out5" Q500 ; create fan 1 on pin out5 and set its frequency
M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off; Tools
M563 P0 D0 H1 F0:1 ; define tool 0
Please use this method to update the firmware to 3.3
https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Duet_3_Mini_5_WiFi_Ethernet
https://github.com/Duet3D/RepRapFirmware/releases/download/3.3/Duet3Firmware_Mini5plus.uf2
Also replace the contents of the /www folder on the SD card with the files in this zip archive for the web interface.
https://github.com/Duet3D/RepRapFirmware/releases/download/3.3/DuetWebControl-SD.zip
Your config.g looks ok and it should request a DHCP address at startup. You can use the USB terminal to send M552 to check what IP address it has taken. Also send M122 in the terminal and post the results here. You can also send M98 P"config.g" in the terminal and tell us what it reports.
@phaedrux I followed your instructions to the letter but no change
It behaves exactly as in my first post./Soren
Have you tried YAT instead of pronterface?
Do the LEDs on the ethernet port light up?
What LEDs light up on the board when connected to USB?
@phaedrux Yes, I've tried both YAT from windows and PuTTY from Linux. No response.
No light on any ethernet LED (the port worked fine before my "update").
LEDs on board with only USB connection (no 24V):
3.3V solid green
5V solid red
Status, slow stead blinking red/Soren
@phaedrux What about I try to wipe everything (including boot loader) and reinstall from scratch?
When and where did you purchase the Duet 3 mini 5+ Ethernet?
@phaedrux I bought it from the Swedish distributor RepRapPro.me and it was sent on October 15 (it has taken me a while to make the new wiring loom).
Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
@phaedrux I've done that and gotten it approved but one question remains.
Do I dare to ever run an update on the new board if it might brick it?
It seems like figuring out what happen to my current board should be a high priority.
What do you think? -
@kingfranz what happens to the USB device name if you youbleick the reset button? does it turn into DuetBoot?
Can you connect to the board via YET if the SD card is not installed?
@t3p3tony Double clicking the reset button turns it into:
On windows: serial port changes to "Serial USB unit (COM4)" and under USB-units there's a "Duet3-Mini5+"
On Linux: a mounted volume named DuetBoot shows up with the 3 files (CURRENT.UF2, INDEX.HTM and INFO_UF2.TXT).
No, can't connect in any way.
@kingfranz said in Can't connect to Duet 3 mini 5+ Ethernet:
ok great so copy over the latest 3.3 release UF2 into the DuetBoot mount. It will install and the should reset. Then try connecting to it in YAT without an SD card installed.
@t3p3tony I've already tried that, it copies the file, resets and it's back to square one, can't connect to it
undefined Phaedrux marked this topic as a question
