M566 P1 vs pressure advance
Are you also using input shaping?
Can you post a photo of what you're seeing?
@phaedrux The printer is currently in operation. I'll take a photo tomorrow. I didn't understand how to insert photos here.
@phaedrux Input shaping is not used.
@phaedrux I understood how to insert photos. I didn't see on the phone that the chat functionality doesn't fit on the screen
@phaedrux
M566 P1 vs M572 D0 S0.11 -
@phaedrux
M566 P0 vs M572 D0 S0.11 -
M566 P1 vs M572 D0 S0.11 - Incorrect printing occurs at these values.
This is visible after moving to a new part. -
@alexth is this behaviour different in RRF3.3?
@t3p3tony I am a new RRF user. I did not install other versions.
@alexth you have to tune PA with the specific jerk settings and policy.
@pcr I can't find the PA value, because the perimeter prints well, and only the beginning of the line with high underextrusion.
@alexth which printer? A PA value of 0,1 is quite high
@pcr for a direct drive
@PCR
Flying Bear 5
Long direct
~10 cm -
@alexth start with S0 and increase?
@pcr I've tried different values. Can't set up.
But I'll try again
@pcr M572 D0 S0.07 is a more appropriate value, there is no underextrusion at the beginning of the line, but the outer corners of the model are slightly outward. For the perimeter, this value is not ideal.
@alexth please print a tuning tower from S0 to S0.1 and show the pictures
