Reset at reason: Stuck In Spin Loop
Good morning,
I have a machine that is constantly rebooting, sometimes just uploading files to the microSD card.
I have done M122 and this is the result:
M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later Board ID: 08DGM-917NK-F23T0-6JTDJ-3S46L-TDADD Used output buffers: 3 of 24 (23 max) === RTOS === Static ram: 23876 Dynamic ram: 75504 of which 0 recycled Never used RAM 12180, free system stack 184 words Tasks: NETWORK(ready,14.1%,247) HEAT(delaying,0.0%,330) Move(notifyWait,0.1%,364) MAIN(running,85.7%,442) IDLE(ready,0.1%,29), total 100.0% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 00:47:50 ago, cause: software Last software reset at 2021-11-03 12:05, reason: StuckInSpinLoop, GCodes spinning, available RAM 12180, slot 0 Software reset code 0x4083 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f80f BFAR 0xe000ed38 SP 0x2000232c Task MAIN Freestk 764 ok Stack: 0042ae6f 004545d8 610f0000 3e7dff00 40dd4c00 369dc3a0 3edbc06f 3331bb4c 40000000 b5ddd98d 388ab355 bb360b61 3e2aaaab 3f800000 3f800000 4205adc8 4354c416 3e7dff00 3e7dff00 60000010 00000000 00000000 0042ae6f 00000001 00006240 00000000 20000c60 Error status: 0x00 Aux0 errors 0,0,0 Step timer max interval 0 MCU temperature: min 37.2, current 39.3, max 39.9 Supply voltage: min 23.9, current 24.1, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 99/6, heap memory allocated/used/recyclable 2048/62/0, gc cycles 0 Driver 0: position 0, standstill, SG min/max not available Driver 1: position 0, standstill, SG min/max not available Driver 2: position 0, standstill, SG min/max not available Driver 3: position 0, standstill, SG min/max not available Driver 4: position 0, standstill, SG min/max not available Driver 5: position 0 Driver 6: position 0 Driver 7: position 0 Driver 8: position 0 Driver 9: position 0 Driver 10: position 0 Driver 11: position 0 Date/time: 2021-11-03 12:54:02 Cache data hit count 4294967295 Slowest loop: 212.43ms; fastest: 0.17ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 10 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 52.5ms, write time 78.7ms, max retries 3 === Move === DMs created 83, maxWait 0ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 Heater 0 is on, I-accum = 0.0 Heater 1 is on, I-accum = 0.5 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 195.38ms; fastest: 0.00ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions HTTP sessions: 1 of 8 - WiFi - Network state is active WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 0 WiFi firmware version 1.26 WiFi MAC address 84:0d:8e:b3:06:d4 WiFi Vcc 3.38, reset reason Turned on by main processor WiFi flash size 4194304, free heap 24392 WiFi IP address 192.168.1.230 WiFi signal strength -53dBm, mode 802.11n, reconnections 0, sleep mode modem Clock register 00002002 Socket states: 0 0 0 0 0 0 0 0
Can you guide me to what might be going on or what to look for?
Previously I was working with version 3.1.1 on this machine and the same thing happened to me.
I'm checking the wiring for shorts or shunts, but so far I haven't found anything.
The configuration of this machine is identical to others that work perfectly.
Thank you, best regards
@aitor said in Reset at reason: Stuck In Spin Loop:
Might be worth trying a different SD card. You shouldn't really be getting retries.
@aitor thats a good spot by @gloomyandy if you could try a know good SD card to rule that our.
Good morning @t3p3tony and @gloomyandy
I changed the SD card and the same thing happened, this time it did reboot during a print once.
Maybe something else happened as it says that it was restarted 95h ago but the printing stopped.
I have activated an M929 eventlog to see if it gives me more information.
This was the result of M122:
16/11/2021 15:15:32 M122
Used output buffers: 3 of 24 (24 max)
Static ram: 23876
Never used RAM 12180, free system stack 168 words
Tasks: NETWORK(ready,14.1%,217) HEAT(delaying,0.0%,330) Move(notifyWait,0.1%,364) MAIN(running,85.8%,461) IDLE(ready,0.0%,29), total 100.0%
Owned mutexes:
Last reset 95:21:31 ago, cause: software
Last software reset at 2021-11-12 15:53, reason: StuckInSpinLoop, GCodes spinning, available RAM 11972, slot 1
Software reset code 0x4083 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f80f BFAR 0xe000ed38 SP 0x200032b4 Task NETW Freestk 403 ok
Stack: 0042ae6f 004545fc 410f0000 3e800000 412586e8 42263771 3edbc06f 3331bb4c 40000000 b5ddd98d 388ab355 bb360b61 3e2aaaab 3f800000 00000000 40951efe 457f5a39 7f7fffff 3e800000 80000010 00000000 00000000 0042ae6f 00000001 0025bc42 00000000 20000818
Error status: 0x00
Aux0 errors 0,0,0
MCU temperature: min 35.1, current 35.6, max 35.6
Supply voltage: min 24.2, current 24.3, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
Date/time: 2021-11-16 15:15:13
Slowest loop: 3.60ms; fastest: 0.17ms
=== Storage ===
SD card longest read time 1.0ms, write time 0.0ms, max retries 0
=== MainDDARing ===
=== AuxDDARing ===
Heater 1 is on, I-accum = 0.4
Segments left: 0
=== Network ===
Slowest loop: 201.69ms; fastest: 0.08ms
Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
HTTP sessions: 1 of 8- WiFi -
Failed messages: pending 0, notready 0, noresp 1
WiFi flash size 4194304, free heap 24632
WiFi signal strength -51dBm, mode 802.11n, reconnections 0, sleep mode modem
Socket states: 4 0 0 0 0 0 0 0
- WiFi -
