Z axis not homing
Sorry to keep on but im now having an issue where the BOLD line isnt being read. The printer just keeps the x and Y axis by the end stops
G91 ; relative positioning
G1 H1 X230.5 Y235 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
G1 H2 X-5 Y-5 F6000 ; go back a few mm
G1 H1 X230.5 Y235 F360 ; move slowly to X and Y axis endstops once more (second pass)
G90 ; absolute positioning
G1 X-38 Y-10 F6000 ; go to first bed probe point and home Z
;G1 X-100 Y-50 F6000 ; go to first bed probe point and home Z
G30 ; home Z by probing the bed:s
if i put my finger in to make the printer think its homed the Z axis (on home all) im still getting this error too
G28
Error: in file macro line 5: M280: parameter 'P' too high -
@prior123 can your printer even reach X-38 Y-10?
Post your config.g -
@prior123 you may also want to check your retractprobe.g as well
; generated by RepRapFirmware Configuration Tool v3.2.3 on Tue Mar 16 2021 15:54:40 GMT+0000 (Greenwich Mean Time); General preferences
M550 P"" ; set printer name; Network
;M551 P"" ; set password
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0 S1 ; physical drive 0 goes backwards
M569 P1 S1 ; physical drive 1 goes backwards
M569 P3 S0 ; physical drive 3 goes forwards
M92 X80.00 Y80.00 Z400.00 E93.00 ; set steps per mm
M566 X900.00 Y900.00 Z12.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
M906 X600 Y600 Z600 E600 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X-5.5 Y-10 Z0 S1 ; set axis minima
M208 X220 Y220 Z250 S0 ; set axis maxima; Endstops
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X-49 Y9 Z1.597 ; set Z probe trigger value, offset and trigger height
M557 X-15:165 Y20:230 S20 ; define mesh grid
;M557 X5:205 Y5:165 S20 ; Define mesh grid; Heaters
M308 S0 P"bedtemp" Y"thermistor" T98801 B4185 ; configure sensor 0 as thermistor on pin bedtemp
M308 S1 P"e0temp" Y"thermistor" T98801 B4185 ; configure sensor 1 as thermistor on pin e0temp
M106 P0 C"Part Cooling" S0 H-1 ; set fan 0 name and value. Thermostatic control is turned off
M106 P1 C"Heatsink/Hotend" S1 H1 T45 ; set fan 1 name and value. Thermostatic control is turned on
M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency
M106 P2 C"PartCooling" S1 H1 T45 ; set fan 2 name and value. Thermostatic control is turned on; Tools
M563 P0 S"PrintHead01" D0 H1 F0 ; define tool 0
T0 ; select first tool -
@jay_s_uk This has stopped the warning sign! thank you
@prior123 all sorted now?
the homing error is fixed but the x and y positioning when homing the Z via home all isnt working
@prior123 because you're in absolute mode. Surely X-38 Y-10 is off your bed or even outside your axis limits
@jay_s_uk so should i comment out that line then? sorry im pretty unknown when it comes to programming
@prior123 well where do you want the nozzle to move to when you do the G30?
@jay_s_uk probably X-60 and Y-10
But i just changed that in the homeall.g and it doesnt seem to be doing anything
@prior123 how? That's way outside your bed limits set in M208 in your config
@jay_s_uk this has helpe massively! thank you.
How can i work out the true measurements essentially ive defined it all no with
M208 X60 Y-10 Z0 S1 ; set axis minima
M208 X235 Y235 Z260 S0 ; set axis maximahowever im not trying to define the mesh coordinates and i am continuously getting this
Warning: Skipping grid point X=200.0, Y=180.0 because Z probe cannot reach it
Warning: Skipping grid point X=220.0, Y=180.0 because Z probe cannot reach it
Warning: Skipping grid point X=220.0, Y=200.0 because Z probe cannot reach it
Warning: Skipping grid point X=200.0, Y=200.0 because Z probe cannot reach it -
@prior123 the Z probe can go further im just really confused why it thinks it cant
@prior123 your z probe has an offset of x-49. That means it can probe any further than 49mm before your x maximum. So with a maximum of 235, you can only probe up to X186 (otherwise the nozzle will have to go outside the machine limits)
@jay_s_uk said in Z axis not homing:
235
sooo close now
ive recalibrated the Z probe, and redefined both the bed size and mesh size.
I have just one last issue it still wont hit the last point on the bed and throws out an error before continuing the rest of the G32 code
G31 P500 X-43 Y10 Z3.79 ; set Z probe trigger value, offset and trigger height
M557 X60:260 Y30:245 S20 ; define mesh gridi thought it may have been the S value but that doesnt seem to make sense as 20 goes into 260
any more ideas?
@prior123 what error does it throw
@jay_s_uk
G32
Warning: Skipping grid point X=240.0, Y=30.0 because Z probe cannot reach it
Warning: Skipping grid point X=260.0, Y=30.0 because Z probe cannot reach it
Warning: Skipping grid point X=260.0, Y=50.0 because Z probe cannot reach it
Warning: Skipping grid point X=240.0, Y=50.0 because Z probe cannot reach it -
@prior123 again, you cant probe those points because your nozzle will go outside your axis limits. Based on 260, the closest you can go is X217
