Z axis not homing
@prior123 have you got the x axis travelling further than total axis travel?
If it fails to find the endstops on the first move but finds it on the second, that's usually when you get that message -
Sorry to keep on but im now having an issue where the BOLD line isnt being read. The printer just keeps the x and Y axis by the end stops
G91 ; relative positioning
G1 H1 X230.5 Y235 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
G1 H2 X-5 Y-5 F6000 ; go back a few mm
G1 H1 X230.5 Y235 F360 ; move slowly to X and Y axis endstops once more (second pass)
G90 ; absolute positioning
G1 X-38 Y-10 F6000 ; go to first bed probe point and home Z
;G1 X-100 Y-50 F6000 ; go to first bed probe point and home Z
G30 ; home Z by probing the bed:s
if i put my finger in to make the printer think its homed the Z axis (on home all) im still getting this error too
G28
Error: in file macro line 5: M280: parameter 'P' too high -
@prior123 can your printer even reach X-38 Y-10?
Post your config.g -
@prior123 you may also want to check your retractprobe.g as well
; generated by RepRapFirmware Configuration Tool v3.2.3 on Tue Mar 16 2021 15:54:40 GMT+0000 (Greenwich Mean Time); General preferences
M550 P"" ; set printer name; Network
;M551 P"" ; set password
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0 S1 ; physical drive 0 goes backwards
M569 P1 S1 ; physical drive 1 goes backwards
M569 P3 S0 ; physical drive 3 goes forwards
M92 X80.00 Y80.00 Z400.00 E93.00 ; set steps per mm
M566 X900.00 Y900.00 Z12.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
M906 X600 Y600 Z600 E600 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X-5.5 Y-10 Z0 S1 ; set axis minima
M208 X220 Y220 Z250 S0 ; set axis maxima; Endstops
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X-49 Y9 Z1.597 ; set Z probe trigger value, offset and trigger height
M557 X-15:165 Y20:230 S20 ; define mesh grid
;M557 X5:205 Y5:165 S20 ; Define mesh grid; Heaters
M308 S0 P"bedtemp" Y"thermistor" T98801 B4185 ; configure sensor 0 as thermistor on pin bedtemp
M308 S1 P"e0temp" Y"thermistor" T98801 B4185 ; configure sensor 1 as thermistor on pin e0temp
M106 P0 C"Part Cooling" S0 H-1 ; set fan 0 name and value. Thermostatic control is turned off
M106 P1 C"Heatsink/Hotend" S1 H1 T45 ; set fan 1 name and value. Thermostatic control is turned on
M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency
M106 P2 C"PartCooling" S1 H1 T45 ; set fan 2 name and value. Thermostatic control is turned on; Tools
M563 P0 S"PrintHead01" D0 H1 F0 ; define tool 0
T0 ; select first tool -
@jay_s_uk This has stopped the warning sign! thank you
@prior123 all sorted now?
the homing error is fixed but the x and y positioning when homing the Z via home all isnt working
@prior123 because you're in absolute mode. Surely X-38 Y-10 is off your bed or even outside your axis limits
@jay_s_uk so should i comment out that line then? sorry im pretty unknown when it comes to programming
@prior123 well where do you want the nozzle to move to when you do the G30?
@jay_s_uk probably X-60 and Y-10
But i just changed that in the homeall.g and it doesnt seem to be doing anything
@prior123 how? That's way outside your bed limits set in M208 in your config
@jay_s_uk this has helpe massively! thank you.
How can i work out the true measurements essentially ive defined it all no with
M208 X60 Y-10 Z0 S1 ; set axis minima
M208 X235 Y235 Z260 S0 ; set axis maximahowever im not trying to define the mesh coordinates and i am continuously getting this
Warning: Skipping grid point X=200.0, Y=180.0 because Z probe cannot reach it
Warning: Skipping grid point X=220.0, Y=180.0 because Z probe cannot reach it
Warning: Skipping grid point X=220.0, Y=200.0 because Z probe cannot reach it
Warning: Skipping grid point X=200.0, Y=200.0 because Z probe cannot reach it -
@prior123 the Z probe can go further im just really confused why it thinks it cant
@prior123 your z probe has an offset of x-49. That means it can probe any further than 49mm before your x maximum. So with a maximum of 235, you can only probe up to X186 (otherwise the nozzle will have to go outside the machine limits)
@jay_s_uk said in Z axis not homing:
235
sooo close now
ive recalibrated the Z probe, and redefined both the bed size and mesh size.
I have just one last issue it still wont hit the last point on the bed and throws out an error before continuing the rest of the G32 code
G31 P500 X-43 Y10 Z3.79 ; set Z probe trigger value, offset and trigger height
M557 X60:260 Y30:245 S20 ; define mesh gridi thought it may have been the S value but that doesnt seem to make sense as 20 goes into 260
any more ideas?
@prior123 what error does it throw
