Configuration problems
Cant seem to get the config correct Keep getting unknown channel.
Old config was
M305 P0 T100000 B3950 R4700 ; set thermistor + ADC parameters for heater 0
M305 P1 T100000 B4388 R4700 ; set thermistor + ADC parameters for heater 1Have tried various settings
latest one was
M308 S0 P"e0temp" Y"thermistor" T100000 B4725 ; configure sensor 1 as thermistor on pin e0temp
M950 H0 C"e0temp" T0get Error: Temperature reading fault on heater 1: unknown temperature sensor channel
also tried
M308 S0 P"e0temp" Y"thermistor" T100000 B3950 ; define E0 temperature sensor
M950 H0 C"e0heat" T0 ; heater 1 uses the e0heat pin and sensor 1
Error: Temperature reading fault on heater 1: unknown temperature sensor channel -
@dave-parry said in Configuration problems:
Old config was
latest one was
also tried
Error: Temperature reading fault on heater 1: unknown temperature sensor channelYou are showing code for heater 0 but the error is for heater 1.
What is the code for heater 1?
Frederik
here's the code for both
M308 S0 P"bed_temp" Y"thermistor" T100000 B3950 ; define bed temperature sensor
M308 S1 P"e0temp" Y"thermistor" T100000 B4388 ; define E0 temperature sensor
M950 H0 C"bed_heat" T0 ; heater 0 uses the bed_heat pin, sensor 0
M950 H1 C"e0heat" T1 ; heater 1 uses the e0heat pin and sensor 1Still have error heater 1
both still showing 2000 °CJust changed back to old settings and temps are correct so not a sensor problem.
both still showing 2000 °CThanks.
What do you mean by "changed back to old settings"?
I checked the sensors by removing M308 and M960 lines and put back M305 lines. and the sensor readings were back and correct.
What firmware version are you running?
WiFi/Ethernet 2.05.1 (2020-02-09b1)
(Thought I had upgraded to Release 3.4.0 beta 3
but it seems that for some reason it hasn't worked.)Duet Web Control 3.3.0
Will try again
Just tried again and the machine specific tab still says 2.05
Will try again
Remember that you have to first go from 2.05.1 to 3.0.0
Tried 3.1 combined.bin Cant seem to upload it.
3.1?
So you got it up to 3.0 already?
No I hadnt but have now. When I looked down the list 3.1 was above 2.05 and 3.0 was below and I didnt see it.
You now should be able to go to 3.3.0 or (if you ok with betas) to 3.4.x.
Thanks Frederick.
Cant get 3.4 to install. Get Error: In-application programming binary "Duet2CombinedIAP.bin" not foundTemps are working now but still have problem that cant set heaters to active
Have tried all the way back to 3.2. Same error message
Got it done now at WiFi/Ethernet 3.4.0beta3 (2021-08-24)
This post is deleted! -
Glad to hear it.
OK so Hot end now goes Off Active and standby, but Bed not showing up and these error messages
G28
Warning: Obsolete use of S parameter on G1 command. Use H parameter instead.
Error: Failed to enable endstops -
Oh and no fan controls showing up
Do you have this command after the M950 for the bed heater?
M140 P0 H0 ; map heated bed to heater 0
G28
Error: Failed to enable endstopsCorrect.
What used to be G1 S1 is now G1 H1.
Just edit your homing files.
