RRF 3.4b3 - bed heater fault
@phaedrux said in RRF 3.4b3 - bed heater fault:
Can you give us some details about the bed and heater?
Bed is made out of 8 mm aluminum plate with dimensions 340X340
Heating element - 300X300 - 220V, 750W Kenovo connected via SSRStarting with RRF 3.2 I had all versions installed, including betas - it was only with RRF3.4b3 that this problem occurred
my bed config from config.g
M308 S0 P"temp0" Y"thermistor" T100000 B4138 A"Bed" ; configure sensor 0 as thermistor on pin temp0 M950 H0 C"out0" T0 ; create bed heater output on out0 and map it to sensor 0 M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S130 ; set temperature limit for heater 0 to 130C
@cadetc @SIam in order to help ne work on a solution, please can each of you do the following:
- Heat the bed to the same temperature that you tuned it at (resetting heater faults as necessary);
- When the temperature is stable, use command M573 P0 (assuming it is heater 0) to monitor the heater PWM;
- When the value reported by M573 is stable, report in this thread:
- The M573 result
- The ambient temperature at the time
- The bed temperature that you tuned at and set
- The heater tuning results, or the resulting M307 command.
@dc42 Here we go, The first thing is M573 is never stable, the heat bed is on Temp since 3 hours
28.8.2021, 13:27:28 M573 P0 Average heater 0 PWM: 0.238 28.8.2021, 13:27:27 M573 P0 Average heater 0 PWM: 0.247 28.8.2021, 13:27:26 M573 P0 Average heater 0 PWM: 0.177 28.8.2021, 13:27:24 M573 P0 Average heater 0 PWM: 0.215 28.8.2021, 13:27:23 M573 P0 Average heater 0 PWM: 0.267 28.8.2021, 13:27:22 M573 P0 Average heater 0 PWM: 0.262 28.8.2021, 13:27:20 M573 P0 Average heater 0 PWM: 0.216 28.8.2021, 13:27:19 M573 P0 Average heater 0 PWM: 0.228 28.8.2021, 13:27:18 M573 P0 Average heater 0 PWM: 0.214 28.8.2021, 13:27:16 M573 P0 Average heater 0 PWM: 0.184 28.8.2021, 13:27:14 M573 P0 Average heater 0 PWM: 0.262 28.8.2021, 13:27:11 M573 P0 Average heater 0 PWM: 0.199 28.8.2021, 13:27:09 M573 P0 Average heater 0 PWM: 0.262 28.8.2021, 13:27:07 M573 P0 Average heater 0 PWM: 0.289 28.8.2021, 13:27:06 M573 P0 Average heater 0 PWM: 0.185 28.8.2021, 13:27:03 M573 P0 Average heater 0 PWM: 0.278 28.8.2021, 13:27:02 M573 P0 Average heater 0 PWM: 0.236 28.8.2021, 13:27:00 M573 P0 Average heater 0 PWM: 0.209 28.8.2021, 13:26:58 M573 P0 Average heater 0 PWM: 0.244 28.8.2021, 13:26:56 M573 P0 Average heater 0 PWM: 0.147
The ambient temperature is 17 C°
The Bed temperature that i have Tuned was 100C° and set to 75C°
and at last the tuning result is
M307 H0 R0.466 C285.252:285.252 D0.89 S1.00 V24.3 B0 I0
if you need more tests, let me know
@siam thanks. If the M573 reading is not stable, is the temperature oscillating a little? If so, increase the M307 D parameter until it is stable. You can do this while the heater is hot.
@dc42 said in RRF 3.4b3 - bed heater fault:
the temperature after reaching the desired 110 degrees is a little unstable, it fluctuates within +0.3, -0.3 degrees
I tried to change parameter D, but I don't know by what values I can change it - I changed it by 0.1 to the value 4.80 with no visible improvement.
Here are the readings taken about an hour after setting the bed temperatureM573 results
.08.2021, 16:03:22 m573 P0 Average heater 0 PWM: 0.196 28.08.2021, 16:03:16 m573 P0 Average heater 0 PWM: 0.165 28.08.2021, 16:03:15 m573 P0 Average heater 0 PWM: 0.163 28.08.2021, 16:03:14 m573 P0 Average heater 0 PWM: 0.178 28.08.2021, 16:03:12 m573 P0 Average heater 0 PWM: 0.213 28.08.2021, 16:02:57 m573 P0 Average heater 0 PWM: 0.256
Ambient temperature 20C
Bed temperature 110CM307 H0
8.08.2021, 16:00:46 M307 H0 Heater 0 model: heating rate 0.858, cooling time constant 275.9, dead time 4.18, max PWM 1.00, calibration voltage 24.0, mode PID Computed PID parameters: setpoint change: P49.8, I1.466, D145.6, load change: P49.8, I3.664, D145.6
@dc42 The temperature is a bit unstable 69.8 C° - 70.2C° I have increased the d Value by 0.1 up to 6 without any improvement
@dc42 I can do what I want, the PWM Value is always unstable, the only change I can see is that the temperature fluctuations get bigger when I increase the D value. I have now the D value increased by 0.5 until D=25
I have now written a quick and dirty macro to get the values and share the results
var D_Value = 1 var D_Value_max = 10 var D_value_incr = 0.5 var get_pwm_repeat = 10 var count_pwm = 0 echo >"PWM.log" " " ; write new file to sys: while var.D_Value < var.D_Value_max echo >>"PWM.log" " " echo "D_Value " ^ var.D_Value echo >>"PWM.log" "D_Value " ^ var.D_Value M307 H0 R0.466 C285.252:285.252 D{ var.D_Value } S1.00 V24.3 B0 I0 ; change that line to fit to your heater settings echo "M307 H0 R0.466 C285.252:285.252 D" ^ var.D_Value ^ " S1.00 V24.3 B0 I0" ; change that line to fit to your heater settings echo >>"PWM.log" "M307 H0 R0.466 C285.252:285.252 D" ^ var.D_Value ^ " S1.00 V24.3 B0 I0" ; change that line to fit to your heater settings set var.D_Value = var.D_Value + var.D_value_incr G4 S2 while var.count_pwm < var.get_pwm_repeat M573 P0 echo "PWM: " ^ heat.heaters[0].avgPwm echo >>"PWM.log" "PWM: " ^ heat.heaters[0].avgPwm G4 S1 set var.count_pwm = var.count_pwm +1 set var.count_pwm = 0
The result
D_Value 1 M307 H0 R0.466 C285.252:285.252 D1 S1.00 V24.3 B0 I0 PWM: 0.196 PWM: 0.235 PWM: 0.239 PWM: 0.199 PWM: 0.179 PWM: 0.201 PWM: 0.220 PWM: 0.186 PWM: 0.156 PWM: 0.154 D_Value 1.5 M307 H0 R0.466 C285.252:285.252 D1.5 S1.00 V24.3 B0 I0 PWM: 0.224 PWM: 0.215 PWM: 0.257 PWM: 0.303 PWM: 0.278 PWM: 0.215 PWM: 0.181 PWM: 0.195 PWM: 0.243 PWM: 0.282 D_Value 2.0 M307 H0 R0.466 C285.252:285.252 D2.0 S1.00 V24.3 B0 I0 PWM: 0.206 PWM: 0.225 PWM: 0.268 PWM: 0.285 PWM: 0.264 PWM: 0.263 PWM: 0.302 PWM: 0.342 PWM: 0.336 PWM: 0.321 D_Value 2.5 M307 H0 R0.466 C285.252:285.252 D2.5 S1.00 V24.3 B0 I0 PWM: 0.246 PWM: 0.203 PWM: 0.198 PWM: 0.200 PWM: 0.167 PWM: 0.138 PWM: 0.141 PWM: 0.172 PWM: 0.185 PWM: 0.159 D_Value 3.0 M307 H0 R0.466 C285.252:285.252 D3.0 S1.00 V24.3 B0 I0 PWM: 0.206 PWM: 0.255 PWM: 0.264 PWM: 0.228 PWM: 0.191 PWM: 0.195 PWM: 0.234 PWM: 0.257 PWM: 0.255 PWM: 0.255 D_Value 3.5 M307 H0 R0.466 C285.252:285.252 D3.5 S1.00 V24.3 B0 I0 PWM: 0.199 PWM: 0.218 PWM: 0.219 PWM: 0.204 PWM: 0.206 PWM: 0.235 PWM: 0.259 PWM: 0.247 PWM: 0.233 PWM: 0.251 D_Value 4.0 M307 H0 R0.466 C285.252:285.252 D4.0 S1.00 V24.3 B0 I0 PWM: 0.296 PWM: 0.299 PWM: 0.336 PWM: 0.361 PWM: 0.329 PWM: 0.269 PWM: 0.233 PWM: 0.241 PWM: 0.239 PWM: 0.197 D_Value 4.5 M307 H0 R0.466 C285.252:285.252 D4.5 S1.00 V24.3 B0 I0 PWM: 0.191 PWM: 0.170 PWM: 0.140 PWM: 0.130 PWM: 0.151 PWM: 0.149 PWM: 0.123 PWM: 0.100 PWM: 0.095 PWM: 0.117 D_Value 5.0 M307 H0 R0.466 C285.252:285.252 D5.0 S1.00 V24.3 B0 I0 PWM: 0.218 PWM: 0.209 PWM: 0.194 PWM: 0.207 PWM: 0.223 PWM: 0.201 PWM: 0.165 PWM: 0.152 PWM: 0.169 PWM: 0.204 D_Value 5.5 M307 H0 R0.466 C285.252:285.252 D5.5 S1.00 V24.3 B0 I0 PWM: 0.175 PWM: 0.165 PWM: 0.155 PWM: 0.131 PWM: 0.107 PWM: 0.101 PWM: 0.126 PWM: 0.165 PWM: 0.205 PWM: 0.242 D_Value 6.0 M307 H0 R0.466 C285.252:285.252 D6.0 S1.00 V24.3 B0 I0 PWM: 0.299 PWM: 0.304 PWM: 0.327 PWM: 0.317 PWM: 0.284 PWM: 0.246 PWM: 0.218 PWM: 0.216 PWM: 0.226 PWM: 0.215 D_Value 6.5 M307 H0 R0.466 C285.252:285.252 D6.5 S1.00 V24.3 B0 I0 PWM: 0.233 PWM: 0.248 PWM: 0.233 PWM: 0.222 PWM: 0.242 PWM: 0.269 PWM: 0.266 PWM: 0.248 PWM: 0.251 PWM: 0.275 D_Value 7.0 M307 H0 R0.466 C285.252:285.252 D7.0 S1.00 V24.3 B0 I0 PWM: 0.240 PWM: 0.253 PWM: 0.258 PWM: 0.235 PWM: 0.207 PWM: 0.190 PWM: 0.169 PWM: 0.149 PWM: 0.161 PWM: 0.194 D_Value 7.5 M307 H0 R0.466 C285.252:285.252 D7.5 S1.00 V24.3 B0 I0 PWM: 0.174 PWM: 0.145 PWM: 0.144 PWM: 0.170 PWM: 0.191 PWM: 0.178 PWM: 0.154 PWM: 0.155 PWM: 0.177 PWM: 0.190 D_Value 8.0 M307 H0 R0.466 C285.252:285.252 D8.0 S1.00 V24.3 B0 I0 PWM: 0.194 PWM: 0.214 PWM: 0.201 PWM: 0.167 PWM: 0.141 PWM: 0.147 PWM: 0.177 PWM: 0.211 PWM: 0.223 PWM: 0.207 D_Value 8.5 M307 H0 R0.466 C285.252:285.252 D8.5 S1.00 V24.3 B0 I0 PWM: 0.217 PWM: 0.201 PWM: 0.168 PWM: 0.148 PWM: 0.152 PWM: 0.146 PWM: 0.121 PWM: 0.101 PWM: 0.112 PWM: 0.116 D_Value 9.0 M307 H0 R0.466 C285.252:285.252 D9.0 S1.00 V24.3 B0 I0 PWM: 0.112 PWM: 0.132 PWM: 0.125 PWM: 0.118 PWM: 0.135 PWM: 0.159 PWM: 0.162 PWM: 0.141 PWM: 0.134 PWM: 0.155 D_Value 9.5 M307 H0 R0.466 C285.252:285.252 D9.5 S1.00 V24.3 B0 I0 PWM: 0.150 PWM: 0.167 PWM: 0.193 PWM: 0.196 PWM: 0.180 PWM: 0.186 PWM: 0.215 PWM: 0.248 PWM: 0.276 PWM: 0.291
Today I checked again how this issue looks like - when heating up to 110C I had to delete fault once, then everything was OK.
After about 30 minutes temperature quite stable, small fluctuations +0.1, -0.1 degrees .
After the temperature of the table stabilized (with small deviations as above) the result of M573 varied from 0.226 to 0.242 - I checked it for about 15 minutes30.08.2021, 17:18:38 M307 H0 Heater 0 model: heating rate 0.858, cooling time constant 275.9, dead time 4.18, max PWM 1.00, calibration voltage 24.0, mode PID Computed PID parameters: setpoint change: P49.8, I1.466, D145.6, load change: P49.8, I3.664, D145.6 30.08.2021, 17:17:49 M573 p0undefined
@cadetc said in RRF 3.4b3 - bed heater fault:
After about 30 minutes temperature quite stable, small flRefer to https://forum.duet3d.com/topic/24809/3-4-0-beta-3-heater-0-fault/12
undefined hestiahuang referenced this topic
