Slow down before endstop?
@fcwilt the backup-and-go-again is an accuracy thing. In my case, it's the stopping at speed that is the problem. it really needs to decelerate to go slow before being told to stop.
@thekm said in Slow down before endstop?:
Well if you can say with certainty how long it takes to stop then you can position the one sensor at an appropriate location.
The important thing is that the sensor remain triggered from that position until the end of travel.
Normal moves have controlled acceleration/deceleration. I don't know what controls deceleration when an endstop is triggered - I would need to do some research.
@fcwilt ...I get what you're saying, it stops wherever it stops, then re-measure it. But again, it is the stopping that is the problem. When it stops, it a hard stop. It's asking a very heavy machine to stop instantly, and the inertia is putting a lot of unnecessary strain on the ballscrews, the crunch is terrible. Nobody mechanically minded would think that the crunch is the sound of a properly operating machine during regular operation
...so I'm after a way for the controller to apply the max deceleration value and slow it down nicely ahead of the stop.
The greater the deceleration the more abrupt the stop - I think you need less deceleration.
Let me do a test to see what settings control deceleration at an endstop. Won't take but an hour or two.
@fcwilt ...correct, this is the setting used to describe the fastest rate the machine can accelerate or decelerate, so when it's processing tool paths it slows down and speeds up appropriately for corners.
But the controller doesn't use these settings for the homing/move-until-switch operations, which is a hard, abrupt stop. If i could just tell it to apply the max deceleration and stop gracefully, that's what I'm after... as I could then tell it to slow down and measure the hard stop point in the usual way.
I super appreciate the help!!!
...until I found the max accel/decel settings, watching it take hard corners like a 3d printer was really horrible
I don't get why you wouldn't use one of the two options given. What is wrong with using an end stop switch mounted off to the side with a lever and roller and activated by the carriage?
Also, we are talking a single move in the x an y axis that is executed when the machine is initially turned on. 'Crawling' to the end stop would be painful but there is also no reason for the machine to go at maximum speed. You may loose 5 seconds per axis first thing in the morning but does that really matter?
Pick a speed that works for you, change the end stop switch to one that you don't 'run into' and you are set. I don't see the issue ..... -
@jens55 ...what I have seen are suggestions for switches. And that's cool. It was my plan to use exactly the switch ideas mentioned (micro switches with long arms and rollers).
Except for my car and tractor, this CNC machine is the heaviest thing that I own, it is a brick. It is also just shy of being the size of a queen sized bed. Telling the gantry to stop instantly without decelerating is prohibitive unless it is crawling. If this was about "5 seconds per axis" I would not have posted, I promise.
I want to look after the machine and I would like to be more productive when using it, and so I need a way to tell it to slow down when it passes a switch so it can be moving slow enough to stop dead when it actually gets to the e-stop.
At the moment I'm just using the e-stops for emergencies only to stop the machine dead, and just hope I don't put in any action in that hits them while trying to manage the job space... because whenever I trigger the e-stops I have to go over all the job setup again because the controller has reset, like it should when it hits emergency stops as it thinks it's an emergency. So, it would be much more productive if I could let the machine discover its work area before running jobs.
As indicated by other responses though, I'm not the only one who would like to take advantage of this efficiency.
Ahhh .... a 'serious' sized machine ....
I am now confused as to how we got to e-stops (as in emergency stop) as compared to an end stop. Probably just a slip of the tongue/keyboard but those are not the same thing.
So if I understand you correctly now, you are concerned not about the carriage hitting the end stop (or at least that's not the only issue) but rather you want the carriage to slow down also because you think that the sudden stop might be too hard on the machine.
If that is the case then yes, mounting another sensor close to the actual end stop would be the way to go. Yes, it will involve some tricky gcode programming because you will need to sense the carriage passing that switch and then reducing the speed. Unfortunately I can't help with the programing of that. Most Duet setups have enough sensor lines that it shouldn't be an issue to connect a suitable sensor.Good luck and please share your final setup.
So you have verified that M204 does not effect homing moves - those like G1 H1?
And I take it simply using a nice, slow speed would simply take too much time?
@jens55 ...it's fun time to hang out in CNC forums, machines hitting endstops are equivalent to the world ending and should be nuked from orbit (actual quote from someone else on the topic). If it's not expected to hit endstops, then it's the only indicator there is of the machine knowing that things are not good, and it should die as quickly as possible. Powerful machines with powerful tools, plasma cutters, etc etc... it's a reasonable attitude to take, and the endstops are often wired into the same loop as the emergency stop button, and wired to be closed, so if anything breaks the circuit it all stops.
CNC forums are fun, but none will have specifics on the Duet gcode things.
@thekm, I agree that a machine should not collide with the end stop. That is why I suggested the sideways switch which does not allow a collision to happen.
@fcwilt said in Slow down before endstop?:
M204
I set it with 201, which the docco says 204 will reference as to not exceed.
am curious if 205 will do anything though...
M204
Notice that M201 set acceleration for any kind of move. M204 allows you to put an upper limit on each kind of move - printing and travel.
I need to go test M204.
On some of the CNC plasma systems we sell, they have two inductive sensors as the end stops.
On reaching the first, the machine slows and on reaching the second it stops and gives a limit error.
I think that on reaching the first, the max speed is reduced. On leaving the zone it's restored.
I think you could use a similar approach provided that you can create triggers that activate on both rising and falling
M581 sort of says that you can if you call it twice for the same input with different values, but you'd have to try.
When M581 is executed, if the T parameter is present but the other parameters are omitted, the trigger inputs and edge polarities for that trigger number are reported. Otherwise, the specified inputs and their polarities are added to the conditions that cause that trigger.EDIT
Thinking on this, I don't think changing the max speed would interrupt a move in progress.
You'd have to segment it -
@owend, that is a good point .... you would have to do the first move to the earlier stop as if it was the real end stop. Then go to the second end stop at a much slower speed.
OK.
I verified the M204 T does affect the acceleration of a G1 H1 move but when the endstop is triggered it stops immediately.
Different value for M205 do not seem to change the stopping.
The firmware supports "triggers" which are external events which can run code - but unless something has changed since I last tested that code cannot interrupt a move in progress.
You could possibly "home" using a series of short moves (10mm ?) - the trigger code may get a chance to run at the end of each move and it could do one last move with low deceleration.
I would have to test that.
@fcwilt ...the more I play with it the more I think it would need a firmware tweak to get something that decelerates to a value or even decelerate to a stop rather than the hard termination.
...or I guess I just need to make sure I home it before I turn the machine off, so that when it turns on it can assume it's not far to travel to home it, and once homed it can assume dimensions for limits. And if I forget to home it, then I suffer the wait of the slow job setup when I turn it back on
I agree. Other than using a series of short moves and a trigger I don't see anyway to have a "soft" endstop.
There is a firmware suggestion category.
Dumb question: why can't you have and endswitch at, say, 50mm from the hard stop. When it passes that point, you know where it is, and can slow and continue on for N additional counts to get to where you want to end up?
