T1 moves in X without being asked.
Lol my gcode is "g1 z0" or literally anything that asks for a movement in Z while the tool is selected. I can click the "-0.5" button in the web interface, type a gcode command, anything, they all have the same problem.
MB6HC, firmware 3.3.
config.g
; Configuration file for Duet 3 (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.2.3 on Sat Jul 17 2021 19:40:18 GMT-0500 (Central Daylight Time) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"Tenlog Hands 2+" ; set printer name ; Network M551 P"idexer" ; set password M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0.0 S0 ; physical drive 0.0 goes BACKWARDS M569 P0.1 S1 ; physical drive 0.1 goes forwards M569 P0.2 S0 ; physical drive 0.2 goes BACKWARDS M569 P0.3 S0 ;DRIVE 3 GOES BACKWARDS M569 P0.4 S1 ;DRIVE 4 GOES FORWARDS M569 P0.5 S1 ;DRIVE 5 GOES FORWARDS M569 P1.0 S1 ; physical drive 1.0 goes FORWARDS M569 P1.1 S0 ; physical drive 1.1 goes BACKWARDS M569 P1.2 S1 ;DRIVE 1.2 GOES FORWARDS M584 X0.0 U0.5 Y0.1 Z0.2:0.3 E1.0:1.1 ; set drive mapping ADDED U AND Z2 AXES M671 X-25:245 Y0:0 S2.5 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis M350 X64 U64 Y64 Z16 E64:64 I1 ; configure microstepping with interpolation ADDED U AXIS M92 X320.00 U320.00 Y320.00 Z800.00 E1600:1600 ; set steps per mm ADDED U AXIS M566 X900.00 U900.00 Y900.00 Z60.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min) ADDED U AXIS M203 X10000.00 U10000.00 Y10000.00 Z500.00 E1200.00:1200.00 ; set maximum speeds (mm/min) ADDED U AXIS M201 X1500.00 U1500.00 Y1500.00 Z30.00 E150.00:150.00 ; set accelerations (mm/s^2) ADDED U AXIS M906 X1600 U1600 Y1600 Z1360 E800:800 I30 ; set motor currents (mA) and motor idle factor in per cent ADDED U AXIS M84 S30 ; Set idle timeout ; Axis Limits M208 X-35 U-5 Y0 Z-1 S1 ; set axis minima M208 X225 U255 Y218 Z210 S0 ; set axis maxima ; Endstops M574 U2 s1 P"io4.in" ; configure active-high endstop for high end on U via pin io4.in M574 X1 S1 P"io1.in" ; configure active-high endstop for low end on X via pin io1.in M574 Y1 S1 P"io2.in" ; configure active-high endstop for low end on Y via pin io2.in ;M574 Z1 S2 ; configure Z-probe endstop for low end on Z (COMMENTED OUT FOR TESTING) ; Z-Probe M558 P8 C"io5.in+io5.out" H5 F300 T24000 ; set Z probe type to unmodulated and the dive height + speeds G31 P500 X-10 Y28 Z0.4 ; set Z probe trigger value, offset and trigger height M557 X40:180 Y40:180 S20 ; define mesh grid ; Heaters M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0 M950 H0 C"out0" T0 ; create bed heater output on out0 and map it to sensor 0 M307 H0 B0 R0.299 C532.6 D3.65 S1.00 V24.0 ; heated bed tuning specs M140 H0 ; map heated bed to heater 0 M143 H0 S115 ; set temperature limit for heater 0 to 115C M308 S1 P"temp1" Y"thermistor" T100000 B4725 C7.060000e-8 ; configure sensor 1 as thermistor on pin temp1 M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1 M307 H1 B0 R2.308 C271.0:261.3 D5.56 S1.00 V24.0 ; heater 1 on e0 tuning specs M143 H1 S260 ; set temperature limit for heater 1 to 260C M308 S2 P"temp2" Y"thermistor" T100000 B4725 C7.060000e-8 ; configure sensor 2 as thermistor on pin temp2 M950 H2 C"out2" T2 ; create nozzle heater output on out2 and map it to sensor 2 M307 H2 B0 R2.268 C237.1:235.1 D5.83 S1.00 V24.0 ; heater 2 on e1 tuning specs M143 H2 S260 ; set temperature limit for heater 2 to 260C ; Fans M950 F0 C"out4" Q500 ; create fan 0 on pin out4 and set its frequency CASE FAN 1 M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"out5" Q500 ; create fan 1 on pin out5 and set its frequency CASE FAN 2 M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off M950 F2 C"1.out3" Q500 ; create fan 2 on pin 1.out3 and set its frequency CASE FAN 3 M106 P2 S1 H-1 ; set fan 2 value. Thermostatic control is turned off M950 F3 C"out6" Q500 ; create fan 3 on pin out6 and set its frequency HE FAN E0 M106 P3 S1 H1 T60 ; set fan 3 value. Thermostatic control is turned on M950 F4 C"out7" Q500 ; create fan 4 on pin out7 and set its frequency PART COOLING FAN E0 M106 P4 S1 H-1 ; set fan 4 value. Thermostatic control is turned off M950 F5 C"out8" Q500 ; create fan 5 on pin out8 and set its frequency HE FAN E1 M106 P5 S1 H2 T60 ; set fan 5 value. Thermostatic control is turned on M950 F6 C"out9" Q500 ; create fan 6 on pin out9 and set its frequency PART COOLING FAN E1 M106 P6 S1 H-1 ; set fan 6 value. Thermostatic control is turned off ; Tools M563 P0 S"LEFT" D0 H1 F4 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S220 ; set initial tool 0 active and standby temperatures to 0C M563 P1 S"RIGHT" D1 H2 X3 F6 ; define tool 1 ADDED X3 TO MAP U AXIS TO X AXIS G10 P1 X0.1 Y-0.6 Z0.265 ; set tool 1 axis offsets G10 P1 R0 S220 ; set initial tool 1 active and standby temperatures to 0C M563 P2 S"DUPLICATE" D0:1 H1:2 X0:3 F4:6 ;ADDED DUPLICATE TOOL G10 P2 X40 Y0 U-40 ;SET OFFSETS TO KEEP CARRIAGES 80MM APART G10 P2 S220 R0 ;SET STARTING AND STANDBY TEMPS TO 0C M567 P2 E1:1 ; set mix ratio 100% on both extruders ; Custom settings are not defined ; Miscellaneous M575 P1 S1 B57600 ; enable support for PanelDue M911 S10 R11.5 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
tfree0
; tfree0.g ; called when tool 0 is freed ; ; generated by RepRapFirmware Configuration Tool v3.2.3 on Tue Jun 08 2021 18:16:59 GMT-0500 (Central Daylight Time) G91 ; relative axis movement G1 Z5 F1000 ; Z up 5mm G90 ; absolute axis movement G0 H0 X-10 ; fast move the X carriage to -10
tfree1
; tfree1.g ; called when tool 1 is freed ; ; generated by RepRapFirmware Configuration Tool v3.2.3 on Tue Jun 08 2021 18:16:59 GMT-0500 (Central Daylight Time) G91 ; relative axis movement G1 Z5 F1000 ; Z up 5mm G90 ; absolute axis movement G0 H0 U230 ; Fast move the U carriage to 230
tpost0
; tpost0.g ; called after tool 0 has been selected ; M116 P0
tpost1
; tpost1.g ; called after tool 1 has been selected ; M116 P1
I haven't put anything in the tpre files yet,. I'm still setting the machine up
Can you send M98 P"config.g" in the console and report any errors?
And your homing files?
No errors come back from the m98 command, I get the following response:
m98 P"config.g" HTTP is enabled on port 80 FTP is disabled TELNET is disabled
homeall
; homeall.g ; called to home all axes ; ; generated by RepRapFirmware Configuration Tool v3.2.3 on Tue Jun 08 2021 18:16:58 GMT-0500 (Central Daylight Time) G91 ; relative positioning G1 H2 Z5 F12000 ; lift Z relative to current position G1 H1 X-300 U300 Y-235 F5000 ; move quickly to X, U, and Y axis endstops and stop there (first pass) G1 H2 X5 U-5 Y5 F5000 ; go back a few mm on each axis G1 H1 X-300 U300 Y-235 F1000 ; move slowly to X, U, and Y axis endstops once more (second pass) G90 ;back to absolute mode G1 X120 Y82 F5000 ; put head over the centre of the bed, or wherever you want to probe G30 ; lower head, stop when probe triggered and set Z to trigger height G32 ; run bed.g to level Z axis leadscrews G91 G1 H1 X-300 Y-235 F5000 ; move quickly to X, U, and Y axis endstops and stop there (first pass) G1 H2 X5 Y5 F5000 ; go back a few mm on each axis G1 H1 X-300 U300 Y-235 F1000 ; move slowly to X, U, and Y axis endstops once more (second pass)
homeu
Tenlog Hands 2+ m98 P"config.g" Status Idle Mode: FFF Tool Position X -35.0 Y 101.5 Z 24.73 U 100.0 Extruder Drives Drive 0 0.0 Drive 1 0.0 Speeds Requested Speed 0 mm/s Top Speed 0 mm/s Sensors Vin 24.1 V V12 12.0 V MCU Temperature 41.7 °C Z-Probe 0 Tools Extra Control Heaters Tool Heater Current Active Standby LEFT T0 - Load Filament Heater 1 off 74.0 °C 220 0 RIGHT T1 - Load Filament Heater 2 off 72.6 °C 220 0 DUPLICATE T2 Heater 1 off 74.0 °C 220 0 Heater 2 off 72.6 °C 220 0 Bed Heater 0 off 23.5 °C 0 0 Temperature Chart System Directory 0:/sys/homeu.g ; homeu.g ; called to home the U axis ; ; generated by RepRapFirmware Configuration Tool v3.2.3 on Tue Jun 08 2021 18:16:58 GMT-0500 (Central Daylight Time) G91 ; relative positioning G1 H2 Z5 F5000 ; lift Z relative to current position G1 H1 U300 F5000 ; move quickly to X axis endstop and stop there (first pass) G1 H2 U-5 F5000 ; go back a few mm G1 H1 U300 F1000 ; move slowly to X axis endstop once more (second pass) G1 H2 Z-5 F5000 ; lower Z again G90 ; absolute positioning
homex
; homex.g ; called to home the X axis ; ; generated by RepRapFirmware Configuration Tool v3.2.3 on Tue Jun 08 2021 18:16:58 GMT-0500 (Central Daylight Time) G91 ; relative positioning G1 H2 Z5 F24000 ; lift Z relative to current position G1 H1 X-300 F5000 ; move quickly to X axis endstop and stop there (first pass) G1 H2 X5 F5000 ; go back a few mm G1 H1 X-300 F1000 ; move slowly to X axis endstop once more (second pass) G1 H2 Z-5 F24000 ; lower Z again G90 ; absolute positioning
homey
; homey.g ; called to home the Y axis ; ; generated by RepRapFirmware Configuration Tool v3.2.3 on Tue Jun 08 2021 18:16:58 GMT-0500 (Central Daylight Time) G91 ; relative positioning G1 H2 Z5 F25000 ; lift Z relative to current position G1 H1 Y-235 F5000 ; move quickly to Y axis endstop and stop there (first pass) G1 H2 Y5 F5000 ; go back a few mm G1 H1 Y-235 F1000 ; move slowly to Y axis endstop once more (second pass) G1 H2 Z-5 F25000 ; lower Z again G90 ; absolute positioning
homez
G91 ; relative mode G1 H2 Z5 F5000 ; raise head 15mm to ensure it is above the Z probe trigger height G90 ; back to absolute mode G1 H1 U300 F5000 ; move U CARRIAGE out of the way G1 X120 Y110 F5000 ; put head over the centre of the bed, or wherever you want to probe G30 ; lower head, stop when probe triggered and set Z to trigger height
homeall - the last 3 lines seem odd
homeu - seriously odd
Also if you don't already do it your bed.g file after doing a leveling the bed you need to set the Z=0 datum again with G30.
@fcwilt said in T1 moves in X without being asked.:
Hey Frederick, none of that is relevant to the question being asked here. Do you have anything of value to add?
I've already stated that the machine is a work in progress. If you don't have anything helpful to add, maybe don't post anything in a thread next time.
I get that it's sometimes frustrating to receive help from forum volunteers that's not <specifically> what you are asking for.
Please accept the free help even if it's not perfect.
This forum runs on helpful volunteers as well as professionals. We need the volunteers to continue helping this community.It's quite fine to ignore helpyness you aren't interested in receiving, but please do not encourage people not to post. It makes everyone less likely to try and help you or the next person in line with a question.
I do not know anything about your printer, so I can't be helpful for this problem, but maybe I can help you another time in the future.
@alankilian consider this constructive criticism in that spirit.
Help that didn't get asked for isn't help at all. Quite the opposite in fact.
And I'd repeat my criticism for your post, do you have anything of value to add here? If not, maybe the forum would be best served by your going help someone with something that you understand?
@terbospaghetti Is there a line missing from your homeall.g file? If not it looks like it will leave you set in relative mode, which may not be what you intend. I doubt if that will be causing your strange movement problem though. You may want to connect via USB and enable gcode debug by using M111 P3 S1 then run your test, the output may provide a clue as to what is going on.
@terbospaghetti said in T1 moves in X without being asked.:
What a wonderful attitude. I will indeed refrain from intruding.
I will just add this one thought. My printers all work.
Goodbye
I was going to put some time and effort into going over your files closely, but your attitude has dampened my enthusiasm. I'd rather spend some time with my family. Maybe tomorrow if you can manage to show some contrition between now and then. I don't want to leave you with nothing though, so have you seen this? https://duet3d.dozuki.com/Wiki/ConfiguringMultipleIndependentXcarriagesCartesian
I'll risk the flames... and this is a guess. What you describe is one axis (U) moving when you are commanding a different axis (Z) to move. One possibility is that you have a motor assignment saved in firmware. M584 does not eliminate previous mappings. To test, in your config.g, add an M18 to clear all motor assignments (M18 X Y Z A B C D U V W ). This needs to be before the M584 command. I have this in my config.g as a matter of personal policy.
This line is sufficiently different to my IDEX configuration that I believe your X offset on T1 may be related to this issue. On my printer with an X span of 235 mm the minimum distance between the nozzles is 58.5mm to avoid them crashing into each other, so my X offset is just that (Y offset is unrelated and Z offset is 0 because I can adjust the height of the hotend):
G10 P1 X58.5 Y-14 Z0 R0 S0
This is a pure shot in the dark, but maybe it helps you figure out what's oing on.
Goodbye
This kind of holier-than-thou attitude is exactly why I hesitate to come near this forum in the first place. You don't wanna come near an issue unless you get the chance to pick at any little detail.
All of you go fuck yourselves, I'm glad I bought clones.
