Duet3 SD Card
If running a Duet3 in standalone mode, do any of the new firmware releases allow for an external SD card to be connected?
@that-guy-e
Duet 3 Mainboard 6HC - No, and this is a physical limitation, not firmware limitation; it doesn't have pins to connect an external SD card socket.
Duet 3 Mini 5+ - Yes, external SD card socket is supported, connected to PanelDue or 12863 expansion pins. Supported in all RRF 3 versions that support the Mini 5+, afaik. (External SD card socket support has been in RRF since v1.16.)Ian
@that-guy-e said in Duet3 SD Card:
We are considering adding that option to RRF. The SD card socket would be connected to the temperature daughter board connector.
@dc42 that would be great. If network connections issues occur, having the extra SD card to load programs is very helpful.
@dc42 Do you know when the decision would be on whether or not this is implemented? I'm planning to use the board as an OEM in a new piece of equipment we are designing. I will need to plan accordingly based on this functionality being available in the next 2-3 months. Any time frame you could provide would be very helpful, I know that input shaping is a big focus as of now.
Have any additional plans been made to add the ability to use a secondary SD card on the Duet3?
