Fans dont appear in Dwc
eee.... where i can find doc, how to do it?
its strange, but thin that the socket that twrows 20,4 volts, must be turn the fan.... maybe slowy
Has the mosfet on the fan been damaged?
@phaedrux how i can see/check this?
Do they look like this?
https://duet3d.dozuki.com/Wiki/Connector_and_spare_part_numbers#Section_Fan_mosfet
Seems that, no. But not sure.
attach photo
P.D.: i am thinking, and the fan connected in Shocket FAN1, yesterday turns.... estrange... Can do more tests?
one dude....
What minimum voltage does it need to turn? I say it, because perhaps a 24V fan, with a voltage of 20.4, V should rotate even if it was slower.
No?
@peirof said in Fans dont appear in Dwc:
No?
Maybe? It would depend on the fan on how it tolerated undervolting.
@phaedrux
I'm using now a fan for the nozzle that is 40x40x28 , 6.8Watt and is not pwm despite is declared 6-13.8 voltage range. If I don't give the 100% it won't either spin a little.
https://www.aliexpress.com/item/4000358337229.html?spm=a2g0o.productlist.0.0.1af91fae2vpxjC&algo_pvid=2777b708-8377-426c-8404-8851119de85f&algo_exp_id=2777b708-8377-426c-8404-8851119de85f-5
It is really powerful and make a lot of loud BUT when I close the enclosure it completely disappear. (luckily)
Ps: I made the mode of the 12v with the LM2596 >> Zl116LUM also for make lower Ampere.
https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+5:+Upgrades/54#s214Mine was fuse but not damaged ! (exteriorly)
https://forum.duet3d.com/topic/23594/solved-shorted-pwm-fan2So basically to be sure settings are fine , the fan is good, and noting if fried.
Is this the correct configuration to use heater 01 as a fan?
in this case, for thermostatic tests, then it will be per layer
M950 F2 C"e1heat" M106 P2 T45 H1
You can find all pin names here. e1heat is correct.
https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_Pin_names_for_Duet_2_WiFi_Ethernet
@phaedrux do it, works.... FW3 save me the ass
