Extruder E1 not working
@jackd2282 ; Configuration file for Duet WiFi (firmware version 3)
; generated by RepRapFirmware Configuration Tool v3.2.3 on Mon Aug 02 2021 02:19:39 GMT-0500 (Central Daylight Time); General preferences
M550 P"My Printer" ; set printer name
M669 K1 ; select CoreXY mode; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P3 R-1 ; disable drive 3 and stop monitoring
M569 P2 S0 ; physical drive 2 goes backwards
M569 P4 S1 ; physical drive 4 goes forwards
M584 X1 Y0 Z2 E4 ; set drive mapping
M92 X80.00 Y80.00 Z400.00 E98.00 ; set steps per mm
M566 X600.00 Y600.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 E1500.00 ; set maximum speeds (mm/min)
M201 X3000.00 Y3000.00 Z100.00 E10000.00 ; set accelerations (mm/s^2)
M906 X950 Y950 Z950 E700 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X250 Y250 Z400 S0 ; set axis maxima; Endstops
M574 Z1 S1 P"zstop" ; configure active-high endstop for low end on Z via pin zstop; Z-Probe
M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
M557 X15:215 Y15:195 S20 ; define mesh grid; Heaters
M308 S1 P"e1temp" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin e1temp
M950 H1 C"e1heat" T1 ; create nozzle heater output on e1heat and map it to sensor 1
M563 P0 H1 F0 ; define tool 0
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss -
If it was just the driver that failed, you didn't need to change the heater bindings as well, but if you want to, that's fine, just remember to move the actual cable connections also.
Your tool definition is missing the D0 to tell it to use the first defined extruder. I thnk this is the main problem. You should have M563 P0 D0 H1 F1
@phaedrux when I do that the hotend disappears from the ui
@jackd2282 also I did move the cables and heat works fine
Can you send M122 and M98 P"config.g" in the Gcode console in DWC and post the results?
Can you confirm what version of DWC you are using as well?
@phaedrux I am at work till morning but I will then
@jackd2282 You don't assign the extruder to the first tool so that doesn't seem right. Change back to
and then rerun config.g as Phaedrux suggested. -
@phaedrux on the expansion board if I can’t get this sorted is that an option instead of a new board?
@chrishamm when I change to that it removes the hotend from the interface for some reason
@chrishamm also that line is from the repeal config tool where I put the extruder to E1 as well as the hotend
@jackd2282 reprap config
@jackd2282 With the M584 code from your config.g you map driver 4 to extruder drive 0, so it should be possible to use
M563 P0 D0 H1 F0
as well. If no tool shows up, rerunning config.g withM98 P"config.g"
as suggested by Phaedrux will show why it does not work. -
@chrishamm said in Extruder E1 not working:
M98 P"config.g"
I tried M563 P0 D0 H1 F0 and M563 P0 D0 H1 F1 because both were mentioned and while the tool interface now stays on both for the hot end and M98 P"config.g" showsM98 P"config.g"
HTTP is enabled on port 80
FTP is disabled
TELNET is disabled
when I heat up the hotend to 195c to get both extrusion and retraction buttons to become available i get Warning: motor phase A may be disconnected reported by driver(s) 4
Warning: motor phase B may be disconnected reported by driver(s) 4 with multiple
with multiple stepper motors -
Can you send M122 and provide the results?
How did you "burn" driver 3?
Can you provide some photos of the board? Especially close ups of the drivers?
@phaedruxM122
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later
Board ID: 08DLM-996RU-N85S4-7JKD2-3SN6K-1U97R
Used output buffers: 3 of 24 (23 max)
Static ram: 23876
Dynamic ram: 75020 of which 24 recycled
Never used RAM 15496, free system stack 184 words
Tasks: NETWORK(ready,6.0%,246) HEAT(delaying,0.0%,314) Move(notifyWait,0.1%,364) MAIN(running,93.9%,441) IDLE(ready,0.0%,29), total 100.0%
Owned mutexes: WiFi(NETWORK)
Last reset 00:01:42 ago, cause: software
Last software reset at 2021-08-03 14:09, reason: User, GCodes spinning, available RAM 15496, slot 2
Error status: 0x00
Step timer max interval 0
MCU temperature: min 23.4, current 24.5, max 24.8
Supply voltage: min 27.1, current 27.3, max 27.4, under voltage events: 0, over voltage events: 0, power good: yes
Driver 0: position 0, standstill, SG min/max not available
Driver 1: position 0, standstill, SG min/max not available
Driver 2: position 0, standstill, SG min/max not available
Driver 3: position 0, temperature-shutdown! short-to-ground, standstill, SG min/max not available
Driver 4: position 0, standstill, SG min/max not available
Driver 5: position 0
Driver 6: position 0
Driver 7: position 0
Driver 8: position 0
Driver 9: position 0
Driver 10: position 0
Driver 11: position 0
Date/time: 2021-08-03 14:10:58
Slowest loop: 7.65ms; fastest: 0.17ms
=== Storage ===
Free file entries: 10
SD card longest read time 2.0ms, write time 0.0ms, max retries 0
=== MainDDARing ===
=== AuxDDARing ===
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 202.62ms; fastest: 0.08ms
HTTP sessions: 1 of 8- WiFi -
Network state is active
Failed messages: pending 0, notready 0, noresp 1
WiFi firmware version 1.26
WiFi MAC address 8c:aa:b5:c2:16:2b
WiFi Vcc 3.38, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 26952
WiFi IP address 192.168.1.140
WiFi signal strength -71dBm, mode 802.11n, reconnections 0, sleep mode modem
Clock register 00002002
- WiFi -
@jackd2282 I hooked up my new bondtech ddx and my guess is that the motor was wired wrong cause it got hot then the driver burned
@jackd2282 said in Extruder E1 not working:
Driver 3 is definitely damaged.
with multiple stepper motorsAnd it sounds like you still have the motor wired incorrectly.
Carefully identify the motors phase pairs first before wiring them up again.
@phaedrux I made sure the phases are right and tried all 4 combinations on the motor. No luck. Maybe E1 is also damaged?
Possibly, or the damage to driver 3 is also preventing driver 4 from working.
@phaedrux said in Extruder E1 not working:
Do you notice any damage or pock marks?
@phaedrux it was physically burned and not dremeled out
