Setting up Accelerometer and wiring
@jay_s_uk thx
How about the physical mounting? Anything special people need to be aware of. Is this firm enough and an acceptable location?
@nurgelrot firm enough: yes. Acceptable: maybe. The closer to the nozzle, the better. In that location, assuming that the print head is rigidly coupled to the carriage, it will pick up any ringing of the carriage as a whole. It won't pick up more subtle types of ringing so well - such as torsional oscillations of the print carriage about the X gantry, which are a significant problem on one of my printers.
@dc42 Thanks for the explanation. I'll try and come up with a place to put it on the front nearer the nozzle
@dc42 I've had a theory for a while that the thin heatbreak of the common E3D V6 moves a lot during printing. Perhaps it would be beneficial to mount the accelerometer directly to the (cold) heat block?
See this rudimentary analysis of resonant frequencies I did:
@bot I suspect that any resonance of the hot end heater block would be at a somewhat higher frequency than the usual troublesome resonances in 3D printers, because the heater block has quite low mass if it's an aluminium one, and the heat break is quite stiff. But by all means, see if you can measure it.
Can someone please double check my planned wiring for a Maestro board?
@ccs86 12864 SPI0_CS0 and PANEL DUE SD SPI0_CS0 seems to be sharing the same CPU pin. I would connect INT of the accelerometer to TEMP DAUGHTERBOARD SPI0_CS1 or SPI0_CS2. I'm not sure at all because i have a 2wifi and not a maestro.
@mikes said in Setting up Accelerometer and wiring:
That wire was my least confident one. Unfortunately, I am using the temp daughterboard for my PT100 bed sensor... unless that pin is unaffected and I can just grab it on the output pins of the daughterboard.
@ccs86 Give it a try but i think it won't work cause the MAX31865 chip should be powered and connected to these pins.
Fast solution is to cut the trace on the daughterboard (if not used) that connect cs2 to the chip and solder the INT pin there.
Cleaner one is to create an extension cable that expose that pin for the accelerometer and route all other pins to the daughterboard.
In any case you should wait someone more experienced than me on that board...maybe some other pins can be used. -
@ccs86 I suggest you connect the CS and INT pins to pins EXP_0 and EXP_1 on the expansion header. In the M955 command, refer to them as "exp.pa21+exp.pa22".
@dc42 said in Setting up Accelerometer and wiring:
Thank you!
Revised at your suggestion:
I know that some people have struggled with the wiring itself. Have any best practices been established yet? I was originally going to use ethernet cable, but saw people struggling with that. Some said USB 3.0 cable, but that only has 4 conductors. I was thinking about using this VGA cable:
@dc42 That's a good point. For example, in that very GIF I posted, the resonant frequency identified is above 50 kHz (edit: seems to say ~5 kHz, not 50. The photo was blurry)! It might be worth experimenting with, but it seems like (again) you are correct!
Edit: Yeah, I just checked the simulation and the lowest identified harmonic frequency is 1770 Hz. Much higher than important, no? Frequencies that the shaper will deal with are in the order of 50 hz or less, right?
One more question: Am I interpreting the Maestro pinout diagram correctly?
@ccs86 yes your wiring diagram looks OK to me.
Re wiring, I now recommend using a 1K resistor in series with the SDO signal at the accelerometer board end.
On my delta I use an unshielded 8-core cable to connect the accelerometer, and it works even without the resistor. I think that VGA cable should be OK.
Is the typical error without that resistor "accelerometer not found"? (edit: 1k resistor inline on SDO and still getting accelerometer not found)
When defining the accelerometer with M955 P0 C"[first pin]+[second pin]", are you defining CS in the first pin and INT in the second pin? Or does the order even matter?
Can somebody help me with wiring diagram to connecting the same acclolmeter as one above to duet 3 6hc 1.01.
@ccs86 yes that is the typical error. The CS pin must come first.
