Penta Axis (PAX) support
@joergs5 I just tried the library you mentioned, but I get many errors when including it, it struggles with
ios
dependency (within matrix_library/matrix.h byinclude
of<iterator>
and<complex>
(I didn't find an easy way to resolve it).@dc42 @JoergS5 I gonna code some matrix helpers for my use case, once things run well and reliable I get back to you and you can look at my code and consider to include something in
RRFLibrary/Math
.PS: I spent hours chasing errors reported under Eclipse (Linux), but console reported 0 errors - once I ran Index > Rebuild, the errors under "Problems" disappeared
@xyzdims said in Penta Axis (PAX) support:
Maybe you were missing using namespace std; in the cpp code, because there are std::ios, std::iterator and std::complex standard classes then. But anyway, good luck implementing the matrix methods.
@joergs5 I've got my kinematics numerically working with the few helpers based on
FixedMatrix<floatc_t,4,4>
I mentioned (not yet optimized or so).Still some stuff to sort out regarding
LimitSpeedAndAcceleration()
to coordinate different speeds of my axes (they differ quite a lot in speed). -
This post is deleted! -
@dc42 I post here and intentionally avoid creating a new topic (if you prefer new topic, I will do so next time).
Since more than a week I struggle with a bug in my new kinematics, and I can't comprehend RRF/Movement/Kinematics stack with DDA in details yet - so I would appreciate a few hints from you.
Problem: my kinematics has 2 additional head rotation axis for FDM, Zrotation (Axis A) and tilt rotation (Axis B); my numeric calculations work, but mechanical it behaves likes this:
G1 B10
: expected: B, Y & Z move; actual result: click/blocked (perhaps too fast) motor movement of B, Y and Z (hardly move at all, missing correct final position)G1 Y0.1 B10
: B, Y and Z move correctly (right speed, right final position)G1 X0.1 B10
: B, Y and Z move correctly and X a bit
When I disable B affecting Y & Z within my kinematics, then:
G1 B10
: moves B correctly (not affecting Y & Z)
Presumbly wrong logic at work:
- when a rotational axis moves alone (based on G1 code), but
CartesianToMotorSteps()
provides motions involving other axes, wrong speed/accel is calculated and performed - when a rotational axis moves with another axis requested, correct speed/accel is calculated
Any thoughts?
PS: my
PAXKinematics::LimitSpeedAndAcceleration()
is present but doesn't limit anything, and I'm on3.3-dev
@xyzdims my idea would be you should set a lower speed and accel for B, instead of
M203 A20000 B20000
M201 A800 B800
lower values. M203 B20000 is 333 degree/second, which is quite high*). You can calculate how fast Y and Z must be for this B speed. I expect that the Y and Z speed is too high, failing to reach the coordinated BYZ speeds.*) with high I don't mean the rotation speed, but the rotation of the nozzle plus the distance of the nozzle to the hinge axis produce a YZ distance which may be too high. I didn't check your nozzle-hinge-distance, but the more, the worse. I cannot find the information how you set the nozzle-hinge distance. Is it by parameter in config?
Roughly calculated, if nozzle-hinge distance is 5 cm, and 10 degree means 30 ms for rotation (333 degrees/s). Starting vertical nozzle, roughly all movement goes into Y movement (sin(10*3.14/180)*5 = 0.868 cm), which is 290 mm/s for Y movement. This is not reachable by config restriction for Y, if config Y10000 = 166 mm/s is correct. But it's only a rough calculation, I ignored accel of B and Y eg.
My understanding of firmware movement code, I hope my understanding is correct:
G1 Y0.1 B10 slows down B, because Y restricts the total time limit for the movement. The slowest actuator sets the total time needed, and step generation of all actuators are calculated according to this total time. In most cases the slowest actuator is the extruder speed (not here, but when 3d printing). -
Some debugging infos (
M111 S1 P4 + P6
), more useful for you @dc42 :
G1 B20
(fails to perform mechanically):pr 1 ts=43851297 DDA: start=[0.000000 0.000000 0.000000 0.000000 20.000000] end=[0.000000 0.000000 0.000000 0.000000 20.000000] s=0.000000 vec=[0.000000 0.000000 0.000000 0.000000 20.000000] a=40.000000 d=nan reqv=4.166667 startv=0.000000 topv=0.000000 endv=0.000000 cks=0 sstcda=0 tstcddpdsc=0 exac=0 DMB: dir=F steps=45 next=1 rev=46 interval=0 2dtstc2diva=nan accelStopStep=1 decelStartStep=1 2c2mmsda=0.00 2c2mmsdd=nan mmPerStepTimesCdivtopSpeed=nan fmsdmtstdca2=0.00 cc=0 acc=0 DMZ: dir=B steps=1085 next=1 rev=1086 interval=0 2dtstc2diva=nan accelStopStep=1 decelStartStep=1 2c2mmsda=0.00 2c2mmsdd=nan mmPerStepTimesCdivtopSpeed=nan fmsdmtstdca2=0.00 cc=0 acc=0 DMY: dir=B steps=1539 next=1 rev=1540 interval=0 2dtstc2diva=nan accelStopStep=1 decelStartStep=1 2c2mmsda=0.00 2c2mmsdd=nan mmPerStepTimesCdivtopSpeed=nan fmsdmtstdca2=0.00 cc=0 acc=0
[ At the first glance it's the first
'd=nan'
which raises my attention ]and debugging info from my kinematics (appears before the above debugging output), whereas
ma
machinePosmt
motorPos:; CartesianToMotorSteps: zoff=45.000 xm=0.000 ym=0.000 zm=0.000 am=0.000 bm=20.000 ;tool->machine(1): x=0.000 y=15.391 z=-42.286 ;tool->machine(2): x=0.000 y=15.391 z=2.714 ;=== ma.x=0.000 y=-15.391 z=-2.714 ; mt.x=0 y=-1539 z=-1085 ; 5 numVisibleAxes ; axis #0: ma.pos 0.00 (100.00stp/mm) mt.pos 0 ; axis #1: ma.pos 0.00 (100.00stp/mm) mt.pos -1539 ; axis #2: ma.pos 0.00 (400.00stp/mm) mt.pos -1085 ; axis #3: ma.pos 0.00 (2.25stp/mm) mt.pos 0 ; axis #4: ma.pos 20.00 (2.25stp/mm) mt.pos 45
As comparison, performing
G1 X0.1 B20
(succeeds to perform mechanically):pr 1 ts=323555603 DDA: start=[0.000000 0.000000 0.000000 0.000000 -0.000000] end=[0.100000 0.000000 0.000000 0.000000 20.000000] s=0.100000 vec=[1.000000 0.000000 0.000000 0.000000 200.000000] a=4.000000 d=4.000000 reqv=0.416667 startv=0.000000 topv=0.416667 endv=0.000000 cks=258125 sstcda=0 tstcddpdsc=258125 exac=39062 DMY: dir=B steps=1539 next=1 rev=1540 interval=4274 2dtstc2diva=28124999680.00 accelStopStep=334 decelStartStep=1206 2c2mmsda=18274854.00 2c2mmsdd=18274854.00 mmPerStepTimesCdivtopSpeed=116.96 fmsdmtstdca2=0.00 cc=0 acc=0 DMZ: dir=B steps=1085 next=1 rev=1086 interval=5091 2dtstc2diva=28124999680.00 accelStopStep=236 decelStartStep=850 2c2mmsda=25921658.00 2c2mmsdd=25921658.00 mmPerStepTimesCdivtopSpeed=165.90 fmsdmtstdca2=0.00 cc=0 acc=0 DMB: dir=F steps=45 next=1 rev=46 interval=25000 2dtstc2diva=28124999680.00 accelStopStep=10 decelStartStep=36 2c2mmsda=625000000.00 2c2mmsdd=625000000.00 mmPerStepTimesCdivtopSpeed=4000.00 fmsdmtstdca2=0.00 cc=0 acc=0 DMX: dir=F steps=10 next=1 rev=11 interval=53033 2dtstc2diva=28124999680.00 accelStopStep=3 decelStartStep=8 2c2mmsda=2812499968.00 2c2mmsdd=2812499968.00 mmPerStepTimesCdivtopSpeed=18000.00 fmsdmtstdca2=0.00 cc=0 acc=0
and my debugging (also comes before):
; CartesianToMotorSteps: zoff=45.000 xm=0.100 ym=0.000 zm=0.000 am=0.000 bm=20.000 ;tool->machine(1): x=0.000 y=15.391 z=-42.286 ;tool->machine(2): x=0.000 y=15.391 z=2.714 ;=== ma.x=0.100 y=-15.391 z=-2.714 ; mt.x=10 y=-1539 z=-1085 ; 5 numVisibleAxes ; axis #0: ma.pos 0.10 (100.00stp/mm) mt.pos 10 ; axis #1: ma.pos 0.00 (100.00stp/mm) mt.pos -1539 ; axis #2: ma.pos 0.00 (400.00stp/mm) mt.pos -1085 ; axis #3: ma.pos 0.00 (2.25stp/mm) mt.pos 0 ; axis #4: ma.pos 20.00 (2.25stp/mm) mt.pos 45
@joergs5 thanks for participating
RRF all speeds are mm or degrees per minutes. Also,
G1 A20
performs ok (doesn't not involve X/Y/Z if B=0).I have lowered it earlier to
M203 A10000 B10000
(the info on my blog isn't up-to-date as I change it a lot), but as you perhaps read on my above experience, it's not so much tuning min/max speed the problem as such, the click/blocked motor indicates way out of range speed or acel/decel, there is miscalculation somewhere on DDA/DDARing level, which my debug info I posted today confirms or hints to. I currently try to comprehend Move/DDA/DDARing functionality better, perhaps I'm missing an important config which leads to thed=nan
(deceleration) line (see my other post on this thread). -
@xyzdims unfortunately I won't have time to look at this in detail for the next couple of weeks. But the following may be useful:
- Acceleration and speed limits set by M201 and M203 apply to the movements of axes as specified on the command line. So if e.g. you command X to move and your kinematics causes B to move as well, the acceleration and speed B won't be limited by the M201/M203 B values, only by the M201/203 X values and the ration of B movement to X movement.
- If you get NaNs in the calculations, this normally means that somewhere you have taken the square root of a negative number, or taken an arcsin or arccos of a number outside the range -1.0..1.0.
- This bit of your debug looks odd:
Assuming you created extra axes A B only in that order, this means that your kinematics command a move of total distance NaN after segmentation, and B was moving 20 times as much as the distance specified in the G1 command. That's not right, only axes that are moving implicitly should have have a 'vec' component greater than 1. You need to find out where that NaN is coming from. Check that you haven't accidentally set the segmentation distance to zero.
PS - you might want to try the same move using regulator Cartesian kinematics + your A and B axes, to check that the code outside your kinematics is behaving properly in the same configuration.
The "pr" comes from
void DDA::Prepare()
in DDA.cpp, thered
or decelaration is NAN.G1 B20
: DDA "pr": a=40.0 (aceleration), d=NAN (deceleration), s=0.0 (distance)G1 X0.1 B20
: DDA "pr": a=4.0, d=4.0, s=0.1I need to dive deeper into the DDA.cpp to find out, I suspect the main problem could be s=0.0; just after
if(delta!=0)
in DDA::Prepare() the debug is printed out with tag "pr", it determined there is change, but distance is 0 (=> contradiction), and if any value is divided by s (=0.0) before we get NAN. -
So, DDA.cpp: DDA::Prepare() calls https://github.com/Duet3D/RepRapFirmware/blob/3.3-dev/src/Movement/DriveMovement.cpp#L59
PrepareCartesianAxis()
just before the debug, and thereconst float stepsPerMm = (float)totalSteps/dda.totalDistance;
and
dda.totalDistance
is 0.0 . . . and other calculations follow about acceleration / deceleration, there the NAN is created.The problem starts somewhere in DDA.cpp
DDA::InitStandardMove()
, theretotalDistance
is calculated, which should be non-zero and it looks it is 0.0 there too.if (linearAxesMoving) { // There is some linear axis movement, so normalise the direction vector so that the total linear movement has unit length and 'totalDistance' is the linear distance moved. // This means that the user gets the feed rate that he asked for. It also makes the delta calculations simpler. // First do the bed tilt compensation for deltas. directionVector[Z_AXIS] += (directionVector[X_AXIS] * k.GetTiltCorrection(X_AXIS)) + (directionVector[Y_AXIS] * k.GetTiltCorrection(Y_AXIS)); totalDistance = NormaliseLinearMotion(reprap.GetPlatform().GetLinearAxes()); debugPrintf("DDA::InitStandardMove.1: %f totalDistance\n",totalDistance); } else if (rotationalAxesMoving) { // Some axes are moving, but not axes that X or Y are mapped to. Normalise the movement to the vector sum of the axes that are moving. totalDistance = Normalise(directionVector, reprap.GetPlatform().GetRotationalAxes()); debugPrintf("DDA::InitStandardMove.2: %f totalDistance\n",totalDistance); } else { // Extruder-only movement. Normalise so that the magnitude is the total absolute movement. This gives the correct feed rate for mixing extruders. totalDistance = 0.0; for (size_t d = 0; d < MaxAxesPlusExtruders; d++) { totalDistance += fabsf(directionVector[d]); } if (totalDistance > 0.0) // should always be true { Scale(directionVector, 1.0/totalDistance); } } debugPrintf("DDA::InitStandardMove.3: %f totalDistance\n",totalDistance);
linearAxesMoving
androtationalAxesMoving
are bothtrue
when I doG1 B20
, so which gives strange debug results:DDA::InitStandardMove.1: 0.000000 totalDistance DDA::InitStandardMove.3: 0.000000 totalDistance
As reminder:
G1 B20
, causing Y, Z and B motors to move by request ofPAXKinematics::CartesianToMotorSteps()
.That both
linearAxesMoving
aretrue
makes sense, given they mean motor axes.I think there is a bug in the logic of the code I quoted above:
if(linearAxesMoving)
code block needs to considerrotationalAxesMoving
case too, it's both, not "either or" as withelse if(rotationalAxesMoving)
I disabled
if(0 && linearAxesMoving)
case forG1 B20
, and I had correct mechanical movement! [Update: https://www.youtube.com/watch?v=2x_rOThE_Ns doingG1 B45
andG1 B0
again, the nozzle tip is supposed to stay in place in relation to bed (hence Y, Z and B movement) ].@dc42 Let me know if there is someone else I should address this in case you don't have the time/capacity. I think we are close to resolve this.
@xyzdims thanks for looking into this. I think the bug is that if you have declared B to be a rotational axis (the default), then linearAxesMoving should not be set for a G1 B20 move. It should be set if any only if there is motion of the tool head in Cartesian space. The fact that your kinematics has to move X, Y or Z when moving B should not cause linearAxesMoving to be set.
Looking into this some more, I think the linear or rotational axis moving flag should be set as moving if positionDelta is nonzero, not if delta is nonzero as at present.
doMotorMapping
istrue
inDDA::InitStandardMove()
; not sure what the flag actually means, I inserted some moredebugPrintf
in the relevant loop:if (doMotorMapping) { delta = endPoint[drive] - positionNow[drive]; debugPrintf("axis #%d: posN %d -> endP %d => delta=%d\n",drive,positionNow[drive],endPoint[drive],delta); const float positionDelta = endCoordinates[drive] - prev->GetEndCoordinate(drive, false); debugPrintf(" positionDelta=%f\n",positionDelta); directionVector[drive] = positionDelta; if (positionDelta != 0.0 && (Tool::GetXAxes(nextMove.tool).IsBitSet(drive) || Tool::GetYAxes(nextMove.tool).IsBitSet(drive))) { flags.xyMoving = true; // this move has XY movement in user space, before axis were mapped } }
G1 B20
requested:doMotorMapping=1, numVisibleAxes=5 axis #0: posN 0 -> endP 0 => delta=0 positionDelta=0.000000 axis #1: posN 0 -> endP -1539 => delta=-1539 positionDelta=0.000000 axis #2: posN 0 -> endP -1085 => delta=-1085 positionDelta=0.000000 axis #3: posN 0 -> endP 0 => delta=0 positionDelta=0.000000 axis #4: posN 0 -> endP 45 => delta=45 positionDelta=20.000000 linearAxesMoving=1, rotationAxesMoving=1 DDA::InitStandardMove.1: totalDistance=0.000000 DDA::InitStandardMove.3: totalDistance=0.000000
Hope this helps.
@xyzdims this is the current code (I am looking at 3.4beta1 so it might be slightly different in 3.3):
for (size_t drive = 0; drive < MaxAxesPlusExtruders; drive++) { accelerations[drive] = normalAccelerations[drive]; endCoordinates[drive] = nextMove.coords[drive]; if (drive < numVisibleAxes) { int32_t delta; if (doMotorMapping) { delta = endPoint[drive] - positionNow[drive]; const float positionDelta = endCoordinates[drive] - prev->GetEndCoordinate(drive, false); directionVector[drive] = positionDelta; if (positionDelta != 0.0 && (Tool::GetXAxes(nextMove.tool).IsBitSet(drive) || Tool::GetYAxes(nextMove.tool).IsBitSet(drive))) { flags.xyMoving = true; // this move has XY movement in user space, before axis were mapped } } else { // Raw motor move on a visible axis endPoint[drive] = Move::MotorMovementToSteps(drive, nextMove.coords[drive]); delta = endPoint[drive] - positionNow[drive]; directionVector[drive] = (float)delta/reprap.GetPlatform().DriveStepsPerUnit(drive); } if (delta != 0) { #if 0 // debug only stepsRequested[drive] += labs(delta); #endif if (reprap.GetPlatform().IsAxisRotational(drive)) { rotationalAxesMoving = true; } else { linearAxesMoving = true; } } } else if (LogicalDriveToExtruder(drive) < reprap.GetGCodes().GetNumExtruders())
This is what I think it should be:
for (size_t drive = 0; drive < MaxAxesPlusExtruders; drive++) { accelerations[drive] = normalAccelerations[drive]; endCoordinates[drive] = nextMove.coords[drive]; if (drive < numVisibleAxes) { const float positionDelta = endCoordinates[drive] - prev->GetEndCoordinate(drive, false); if (positionDelta != 0.0) { if (reprap.GetPlatform().IsAxisRotational(drive)) { rotationalAxesMoving = true; } else { linearAxesMoving = true; } } int32_t delta; if (doMotorMapping) { delta = endPoint[drive] - positionNow[drive]; directionVector[drive] = positionDelta; if (positionDelta != 0.0 && (Tool::GetXAxes(nextMove.tool).IsBitSet(drive) || Tool::GetYAxes(nextMove.tool).IsBitSet(drive))) { flags.xyMoving = true; // this move has XY movement in user space, before axis were mapped } } else { // Raw motor move on a visible axis endPoint[drive] = Move::MotorMovementToSteps(drive, nextMove.coords[drive]); delta = endPoint[drive] - positionNow[drive]; directionVector[drive] = (float)delta/reprap.GetPlatform().DriveStepsPerUnit(drive); } #if 0 // debug only if (delta != 0) { stepsRequested[drive] += labs(delta); } #endif } else if (LogicalDriveToExtruder(drive) < reprap.GetGCodes().GetNumExtruders())
@dc42 I copied it, thanks! It works
but give me a day or so to confirm some edge cases as well.
