Password length limit
I'm having trouble while trying to get my Duet to log into my network.
While trying to do a console login I was thwarted by being limited to 19 characters. Our network has about a 25 character password. So dumping everything off the network by changing to a short temporary password I was able to put the Duet on the network via the console. Yay!Once on the network I was able to use the web editor to edit the config.g file to put in the long password. I then changed the network password back to the original long one then rebooted the Duet.
No joy. It complains that the password is being rejected. I suspect it's a problem with the length again.
Does anyone know what the working length can be? It's supposed to be 63 characters but I don't believe the Duet 2.0 firmware is allowing that. Anyone else able to use a 25 character + password successfully?
@kcress you can't set the network password in config.g because the network system is disabled until config.g has completed. Create a macro to set it instead.
Gack! I had no idea that was the case. I'll give that a try.
Thanks dc42. -
@dc42 I dindt knew this: I can set the wifi password in the config.g file?
@dc42 I have tried that, but the command M587 gives me a "command nor supported".
I have version 3.3 of the firmware and the 3.3 of DWC as well. -
@tinchus If you are using your Duet with a SBC, you may have to start the DuetPi Management Plugin on the Settings -> Machine-Specific -> Plugins page first. M587 won't work on Ethernet boards without SBC.
@chrishamm Yes, Im using it with a SBC (raspberry PI 3B+), but I see nothing related to that plugin setting. I checked in SETTINGS > MACHINE-SPECIFIC > MACHINE-SPECIFIC PLuging. It is empty
@chrishamm I upgraded from 3.1 I think. I followed the instructions in the release notes, I got some errors but now seems to be working as intended
Thanks!Update: the plugin doesnt start automatically after reboot, I have to manually start it.
