Duet3D PCB delta printer effector sneak preview
@CaLviNx:
Im intrigued by one of the extra holes I have spied in the effector kit !! I wonder how much free space there is around it ?
located above the "input2" screen printed words on the right, as for me if there is a little free space around it I would use a hollow threaded nipple to locate my air cooling system !!
Originally in an earlier iteration I had a few of these around the edge of the board, they were there to be used to secure zipties for cable strain relief. As the design progressed more and more had to be removed to make space for other things and in the end that is the only one left!
It is quite close to the edge :Be very careful with the trace running between it and the edge of the board though
Any idea if this will be available for purchase from a supplier in the US?
2X
I will post an update As soon as I can confirm when they will be available.
@CaLviNx:
It is quite close to the edge :https://cdn.pbrd.co/images/GFDdQHLE.png
What is the diameter of the hole ?
That IP2 connector had to be moved slightly in the production run as it could cause a collision with the rods and cause a rod disconnect so don't think you could really use that but maybe you could if you used a right angle nipple suitably angled?
Doug
Good idea, if the hole can be massage (away from the trace) one of the following might work!!
The hole looks to me to be the same or very close to the ballstud holes which are 2.9mm Diam so yeah something like that but would need to be M3 I think?
Wonder how many have been ordered so far in the first 24 hours of being available lol?
Doug
I ordered one Sunday, and it's already in the possession of the Royal Mail.
No idea of the total numbers, T3DP3D would have to be the ones to say.
yes indeed mine is also in the Royal Mail hands just had to get a release version and keep the Beta one as a spare?
Doug
Its slightly smaller 2.7mm the smallest i could make it to work with common mini zip ties
Just ordered Duet Wifi, PCB Effector, PT100 daughter board, E3D w/PT100 Sensor
Now the wait has startedAbout the Duet Wifi, has support for hidden SSID been added yet?
-Jannis
-Jannis
If you mean support for connecting as a client to a hidden SSID, that is in version 1.19.
I have created a new forum to discuss the smart effector here https://www.duet3d.com/forum/viewforum.php?id=13 so I will now close this thread.
