mesh bed compensation not compensating
@fcwilt
The machine homes and probes without a hot end attached then when it starts printing it picks up a tool from the rack and uses that tools offsets.The nozzle I currently have configured hangs about 11mm below the switch when mounted. So T1 has a -11 mm z offset.
I believe that the e3d tool changer uses a similar method
@jayson said in mesh bed compensation not compensating:
about 11mm
This is going to need to be quite exact otherwise the nozzle will never touch the bed where you expect. Same goes for the XY offset.
Can you post a photo of your heightmap image?
M376 H10
You might need to eliminate that for now until you get things working and know how quickly you can actually taper off the compensation.
@phaedrux said in mesh bed compensation not compensating:
M376 H10
It set at 11.2 mm to make a good section of my bed useable.
I will take out that M376 and see if that helps.
thank you
@phaedrux
my bed is a little warped, needs some work but nothing bed compensation should handle it for now.Number of points: 100
Probe area: 2397.1 cm²
Maximum deviations: -0.270 / 0.581 mm
Mean error: 0.252 mm
RMS error: 0.184 mm -
For such a large bed you may need to increase the point density. 441 is the max number of points and you're only using 100. That can mean a large distance between points where interpolation has to guess what the bed height actually is. Combine that with XYZ offsets that aren't quite accurate and it's going to have a very hard time keeping the nozzle where it's supposed to be.
@phaedrux I took out that m376 and now it's working
thank you so much!
Its not great but it is actually usable over my whole bed now.
Things are a bit temporary right now as I plan on changing most of this printer. as soon as it can print its own replacement parts I will rebuild it and maybe double my probing points.
I just don't want to wait that long for it to probe.... -
Well if the bed is stable and things don't shift around too much you can save a detailed heightmap and load it instead of probing before each print.
G29 S1 to load saved map.
@phaedrux I might try G29 S1 but I have a removable magnetic bed. so if I have to take it off I will probably need to re-probe.
Maybe, maybe not. If it registers pretty much the same each time it should be ok. Only one way to find out for sure.
I have the BuildTak system and I use the same height map.
I do re-create it from time to time.
@fcwilt I have the buildtak system. Just have to try it
