Error: Probe was not triggered during probing move
@phaedrux not helped, Error: This kinematics does not support auto-calibration is still there
@milan-baca I think you must have made another change to config.g. Please post it as it is now.
easier to read
; Configuration file for Duet 3 (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.2.3 on Sun Apr 04 2021 22:18:55 GMT+0200 (CEST) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"Duet 3" ; set printer name M669 K1 ; select CoreXY mode M912 S-13.7 ; mcu temperature correction ; Drives M569 P0.0 S0 ;H50 V50 D3 ; physical drive 0.0 goes forwards axis X M569 P0.1 S0 ;H50 V50 D3 ; physical drive 0.1 goes forwards axis Y M569 P0.2 S0 ; physical drive 0.2 goes forwards EXTRUDER M569 P0.3 S0 ;H50 V50 D3 ; physical drive 0.3 goes forwards M569 P0.4 S0 ;H50 V50 D3 ; physical drive 0.3 goes forwards M569 P0.5 S0 ;H50 V50 D3 ; physical drive 0.3 goes forwards M584 X0.0 Y0.1 Z0.3:0.4:0.5 E0.2 ; set drive mapping M671 X-26,188:155,021:331,23 Y-20,717:307,493:-20,717 S50 ;Z Lift Point position M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X160.00 Y160.00 Z1600.00 E712.00 ; set steps per mm M566 X1200.00 Y1200.00 Z30.00 E120.00 ; set maximum instantaneous speed changes (mm/min) M203 X18000.00 Y18000.00 Z1800.00 E1200.00 ; set maximum speeds (mm/min) M201 X1600.00 Y1600.00 Z100.00 E250.00 ; set accelerations (mm/s^2) M906 X1400 Y1400 Z1400 E300 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X320 Y320 Z321 S0 ; set axis maxima ; Endstops M574 X1 S1 P"io0.in" ; configure active-high endstop for low end on X via pin io0.in M574 Y1 S1 P"io1.in" ; configure active-high endstop for low end on Y via pin io1.in ; Z-Probe M950 S0 C"io7.out" ; create servo pin 0 for BLTouch M558 P9 C"io7.in" H15 F150 T6000 R0.2 A5 G31 P25 X22.775 Y5.21 Z2.5 ; set Z probe trigger value, offset and trigger height M557 X25:282 Y10:282 P5:5 ; define mesh grid ; Heaters M308 S0 P"temp0" Y"thermistor" T100000 B4267 ; configure sensor 0 as thermistor on pin temp0 M950 H0 C"out0" T0 ; create bed heater output on out0 and map it to sensor 0 M307 H0 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"temp1" Y"thermistor" T100000 B3950 ; configure sensor 1 as thermistor on pin temp1 M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1 M307 H1 R3.678 C133.6 D6.67 S1.00 V24.0 M143 H1 S280 ; set temperature limit for heater 1 to 280C ; Fans M950 F0 C"out7" ;Q250 ; create fan 0 on pin out7 and set its frequency M106 P0 S0 H1 T45 ; set fan 0 value. Thermostatic control is turned on M950 F1 C"out4" Q500 ; create fan 1 on pin out4 and set its frequency M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned of ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined ;M581 Y S1 T2 ; Miscellaneous M308 S10 Y"mcu-temp" A"MCU" M501 M911 S22 R23.5 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss T0
Your M671 doesn't look valid to me
how is your bed supported? what are the co-ordinates of the screws? -
I agree with @jay_s_uk. Change the commas in the M671 command to fullstops.
@jay_s_uk
I am using calculator from this project
https://miragec79.github.io/HevORT/firmwaresettings.html -
@dc42 thank you very much guys problem was in M671 command in numbers
I look at it many times but after you point to that command I saw the problem. It was decimal separator in coordinates
G32 command now work wellstill have a problem with G29
after few points I got
Error: Probe already triggered before probing move startedps: should I make a new thread or can I continue here?
@milan-baca does it do that at the same probe point each time, or at different points?
In this line:
you could try increasing R0.2 to R0.3. If that doesn't fix it then I suspect that the pin of the BLTouch may be sticky. Is it a genuine BLTouch, or a clone?
@dc42 triangle lab (not genuine) - but this one I am using on my other printer (I took it from there) with duet2 wifi for years and it works well there
@milan-baca you could also try reducing the maximum Z speed in M203, in case the Z axis can't keep up with the commanded speed when the probe is raised.
@dc42 thank you very much again R0.3 was the trick
