Add extruder and heater
Do you have to manually update config.g to add another extruder and hot end heater?
I followed the directions here but nothing changed:
https://betrue3d.dk/duet-wifi-adding-a-second-extruder/ -
@pyper in that tutorial he doesn’t add new heater or temp sensor to the tool, as he’s using the existing hotend for both tools. So yes, you need to add them. Probably easiest to use the RRF configuration tool to produce an example config with two hotends, then copy the bits you need.
@droftarts
That makes sense, thank you!
