Same .gcode file - two different printers - very different results
No that will not affect your Z AXis hight at all?
Probably not, but sounds like it needs to be done anyway??
Looks like no difference .. when done printing will try to measure the "jog" on the Z axis ..
What is the thread pitch on your Z axis screw? is there any gearing between the Z axis motor and the screw?
Alternatively, do you know what Z steps/mm you were using in the firmware for the other board?
Tried a jog of +100 and measured 65 mm change.. Will repeat .. Pretty much same result ..
Could this be a current problem to the Z steppers (2) -
Looking to find your answers .. Have to find the old marlin code .. and of course it is not on this computer .. will be back when I have the answers .. I believe the P3 came with M5x295 screw rods if that helps ..
It could be that your Z steps/mm are wrong, or your X acceleration is too high, or your Z maximum speed is too high, or the Z motor current is too low. You should be able to get all of these details except the motor current from your Marlin config file.
One other possibility: if you have two Z motors and they are badly-chosen high inductance low current types, then the series connection used by the two Z motors connectors on the Duet won't work well with them, and you will need to connect them in parallel instead. Can you read the model number of the Z motors from the label?
Some numbers :
Steppers SL42STH40-1684A
MARLIN:
DefaultAxisStepsPerUnit 80,80,4000, 775 – the 4000 looks bigger than the config val
Default Acceleration 3000
Yup z Steps are set to 2560 .. try a change to 4000?
Ratios look about right for measurements ..
warmin up for a test print .. -
If you got a 65mm change when commanding 100, then 4000 will get you close.
BTW, your pictures in this post and another you posted in, are not working.
It is printing .. hopeful .. damn, you guys are good ..
Glad you sorted it. Those steppers are good for plugging directly into the 2 Z motor sockets on the Duet. 1000mA current in the M906 command would be about right.
Print looks much better .. still not perfect but closer, do a few more calcs and adjusts.. will up the current to 1000 in M906 and increase the extruder steps for the titan and the 0.9 motor .and keep trying . Thanks again all ..
