HELP! Duet 2 WiFi Configuration and DWC Upload???
You measure the filament going INTO the extruder, not out of it. You really need to look at that guide.
I did that first, initially. And at 93steps it went way past my line. I've calibrated printers before. My concern is when I run the same program 3 times and I get different results. I assume that when my black line disappears at a high speed at 93 steps and then keeps going, and going when I set it at a low speed, and the next time I run the same program it spits out nothing....that it's not extruding correctly. That coupled with the fact that my PanelDue says its extruding different values that my DWC is.
After the 8th time measuring out my black line, I stopped because there's no point to try and awkwardly get in there to measure it if I know its going to be wrong. That's when I started to look at how much was extruding out of the nozzle.
@pcnoobneedsmajorhelp said in HELP! Duet 2 WiFi Configuration and DWC Upload???:
What do you mean by that?
Mark the line farther up so that it doesn't get sucked down past where you can measure.
So if you look at the two pictures above, one is of my computer screen showing my extrusion setting on the DWC and the other is a picture of my PanelDue with the extrusion settings pulled up, and they don't match.
Just realizing that I never sent the picture, my bad.
So, just ran the same test (with marking the line) and this time it was way short. short of the 100mm mark by 35mm.
they don't match.
That's correct. They don't match. The DWC values are also editable if you right click on the buttons. that's just the way it is.
Well it's going to take a few passes to get it dialed in.
33mm is the average. so do I increase the steps or lower them?
sorry, I'll just do the equation, duh carson. long day
you'll get there
Ok. we're good. 139 steps
I'll recheck everything once more and then run a test print.
Sorry if I was rude or sounded like I had an attitude at any point. When I get frustrated I tend to be short with people. There's no excuse for that kind of behavior.
Any thoughts on the PanelDue issue?
-I'll probably be in touch.
Thanks,
-Carson
It's not an issue. They just have different options. See my comments above.
No worries.
So I uploaded a calibration cube gcode to the DWC to find my flow rate percentage.
Once everything was heated up, it initiated by homing (very slowly) (my initial layer speed is at 20, but this was way slower). Then, usually it would extrude a straight line next to its home location before the print, then head to the center of the bed to start the skirt. But this time after the initial homing, it started to move diagonal to the opposite corner very very slow, and I thought it was going to crash so I Estopped it, then homed it and it homed back at normal speeds
Just wondered what you thought that could be?
Thanks,
-Carson
What slicer are you using?
What is in the start gcode section in the slicer? -
Cura 4.8.0
Should I match The Cura machine settings values to match my config.g settings values?
Just remove the M201, M203, M204, M205 lines from the start gcode.
Also switch your gcode flavor from Marlin to RepRap.
It's still doing it. I wasn't paying attention and thought it was going to crash but it didn't. It's just doing what it normally does with the line before the print but at the opposite corner. Is that just how it is now or can we change that.
-So its starting the print from the front left instead of the back right (where in want it to start from)
Thoughts?
Thanks,
-Carson
It's also not automatically heating the extruder to the Cura printing settings
Ignore that last reply. I guess the bed heats up first
