Tevo little monster
hey im new to this but i wanted to ask if anyone can help me set up my bored cant get it too run can someone please help me im at a freash new start
@tripz2757 said in Tevo little monster:
ant get it to
i have a TLM modded with Duet... in what can i help you?
hey you think you can share your config.g file
@peirof
everything i try seems to not work when i home it starts and then just keeps on going and going and havent been able to do anything with it -
@tripz2757 You could post your files as well and maybe we can spot what's wrong. We'd need to see config.g, homedelta.g, bed.g.
Have you gone through these?
https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareDeltaPrinter
https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer -
@phaedrux
config.json
thats my config file -
can you post the actual config.g please? The .json files are intended for computers to read back the data.
@phaedrux
; generated by RepRapFirmware Configuration Tool v3.2.3 on Mon May 03 2021 10:47:43 GMT-0700 (Pacific Daylight Time); General preferences
M550 P"TEVO MY LITTLE MONSTER" ; set printer name
M665 R155 L397.19 B155 H520 ; Set delta radius, diagonal rod length, printable radius and homed height
M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S1 ; enable FTP
M586 P2 S1 ; enable Telnet; Drives
M92 X80.00 Y80.00 Z80.00 E798 ; set steps per mm
M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
M203 X18000.00 Y18000.00 Z18000 E1200 ; set maximum speeds (mm/min)
M201 X1000 Y1000 Z1000 E1000 ; set accelerations (mm/s^2)
M906 X1200 Y1200 Z1200 E1200 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 Z0 S1 ; Set minimum Z; Endstops
M574 X2 Y2 Z2 S1 ; Set active high endstops; Z-Probe
M307 H3 A-1 C-1 D-1 ; reserve pin 21 for M42 or servo use
M558 P1 H5 F120 T6000 ; Set Z probe type to unmodulated and the dive height + speeds
G31 P25 X0 Y20 Z0.2 ; Set Z probe trigger value, offset and trigger height
M557 R150 S45 ; Define mesh grid; Heaters
M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off; Tools
G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C; Custom settings
M591 D0 C3 P2 E6.0; Miscellaneous
M575 P1 S1 B57600 ; enable support for PanelDue -
@phaedrux said in Tevo little monster:
How bout your other delta related files? Maybe config-override.g as well so we can see your saved delta calibration results?
And maybe the results of M122 so we can see your firmware version etc.
