BtnCmd-DWC Plugin - Customise DWC - v01.03.08 01-03-25
@stephen6309 Does it look like this or different?
@mintytrebor No, that dropdown is underneath the Edit Panel. Can't see DWC Webcam and Alt Webcam.
@stephen6309 Thanks for info. If you/when you have an opportunity I would appreciate it if you could check if the issue is the same on the edit button settings window.
This does sound like the same issue as I linked to previously, its unfortunate the resolution didn't work for you. We were never able to track down what the cause was....
@mintytrebor No dropdown appears with Edit Button Type. Up/Down keys work.
@stephen6309 Thanks! I think that confirms it is the same issue.. I wish the fixed had worked for you.
I will re-instate the work around I had in place, I only took it out in this version. To get around the problem (because we could never track it down), I implemented a "use radio buttons" option which changed all the drops downs to radio buttons, for the users who experienced this problem. I cannot re-create the problem and there is nothing in the code that is causing the issue, it seems to be a weird framework bug, which does not impact everybody. I'll let you know when I have published the changes, at least then you can use the plugin without issues.
Thanks for the feedback, and answering my questions its appreciated.
Hey @MintyTrebor, thanks for the new version. I just made myself a little endstops monitor.
How ever I cant get the object model panel to display the value of a global variable. The panel just lists: ### as the value. Have tried with strings, ints, floats and booleans. All other OM values seem to work.
Are you or anyone else experiencing this issue?
Duet3-6HC + Pi4, DSF, DWC and RRF all running 3.3beta3
Thanks,
T -
@stephen6309 I have just pushed 0.8.17 Alpha to github.
If you open global settings and disable the "Selections in Settings" option, all of the drop downs will switch to radio buttons.You may still experience a few hover/tooltip issues.
The overall issue appears to be a plugin system or framework bug, which occurs at the local level and does not affect every user. Unfortunately I am unable to correct this issue within my plugin as there no options available to me to change this behaviour as it is part of the core bootstrap/vue system used by DWC. The fact you had an issue installing the plugin the first time, is a new data point I did not have before.
If any others are having this issue please can you let me know, or post an issue on github. I would really like to get the bottom of the issue - I want to know if its my stupid mistake, or something else.
@tristanryerparke The three ### is a placeholder I put in the code to tell you/me when the system is unable to match the Model Path you entered in the current machine model resident in DWC. Which means 1 of three things..
The active machine model in DWC does not always contain all of the object model at the same time, some values may only be available during print etc.
I'm using the wrong machine object model resident in DWC or DWC does not load global variables in its default object model and I have to supplement the default model with global variables in my plugin code.
You have entered the wrong path - but given this is exclusive to a particular class of object I doubt this very much.
Could you give me an example path you are using please, then I track it down.
Edit - Also any chance of a screen shot? I would like to see how your using it!
@mintytrebor v0.8.17 works with Selections in Settings off.
@tristanryerparke I ran some tests by creating my own global variables using the
global <new-variable-name> = <expression>
command.
In the OMB plugin it looks like this:
I set up a new Model Panel in BtnCmd like this:
Which worked OK.
Is this what you did/expected, or am I missing something?
@mintytrebor
It works for me, although didn't at first because I accidentally copied a trailing space when I copied it from the OM browser.
The only problem is that the DWC global variable values aren't updated at the moment.
The dev's are aware, so it will likely be fixed in the next beta. -
@owend Great! Thanks for letting me know.
@mintytrebor I'm going through the same process:
First sending:global testBTN = 40
Checking in OM browser (refreshed a few times to be sure):
Then setting up the panel:
I checked for trailing spaces and made sure they were not there.
Still getting "###":
Also I tried sending this command:set global.testBTN = 45
To see if it would update the value in the panel, but still have "###".
Are you guys in standalone mode/duet2? I'm running an SBC.
Cheers,
T -
@tristanryerparke I'm using a stand alone config on a duet2. That may account for the variance??
In principle DWC is the same for both versions - however there maybe some differences in the way the machine model is retrieved in the backend.
In the plugin I am not retrieving the model, I am using the one that is already resident in DWC, so I will have to do some digging to see what I can find out. Its unlikely to be a speedy process though.
Update: I've just spotted this post https://forum.duet3d.com/post/227873, which seems related to this issue. Looks like its an SBC issue.....
@MintyTrebor With the 3.3rc1 update globals are now displaying correctly in btncmd!
Would it be possible to have a color option for the Object Model panel?
Or a color switch based upon value like the z-probe status in DWC?
Also, what about a secondary organization structure in which buttons and panels could be grouped? Kind of like this on the DWC dashboard:
Just some suggestions, I'm really loving this plugin so far.
Much simpler than my previous node-red dashboard setup.
Thanks,
T -
@tristanryerparke Good news that the global variables are working for you now! I will have a look at setting the panel colour in the next release. Conditional colours & grouping I will have to look into.
HI @MintyTrebor ,
Have you ever come across an error like this:
Installation failed!
InvalidOperationException in InstallPlugin: Cannot perform command because the plugin service is not started
I was running 3.2.2 (this is all in SBC mode) and tried to install Alpha 0.8.17 which wouldn't work and so I upgraded DWC to 3.3.0-rc1 and then this error occurred.
Just tried Alpha 0.8.16 in case and got the same error.
Thanks-
Nate
@madeinta1wan see : https://forum.duet3d.com/post/219064
You need to install/enable the plugin service. -
Thanks
Very nice and useful. Thanks for your work!
With Firefox when adding a new button the select "Type" does not expand. With up/down buttons it is possible to change the field value.
And in addition may I place a feature request?
Would be nice to have a button type to execute a command line script/command.
