Strange first layer
Since few days i have this strange first layer
i dont have change nothing
i print pla with nozzle: 200°C, bed: 60°C
if you need some other files for check
it's look like you have some fat on your print bed try to clean it with acetone and sandpaper or equal
I have clean it All and with sandpaper
My and first layer looks like this in pics
I dont know what it is
@lui2004 Over extrusion. Either too much flow, or too close to the bed.
@lui2004 maybe also old/wet filament? Do you hear any popping as it extrudes? PLA isn't as bad as nylon/petg, but can still absorb water over time. I've also found damp filaments swell a but so you get some overextrusion at the same time...
Thats only the first layer the rest of print looks perfect.
Flow and extruder is calibrated
Then likely too close to the bed on the first layer.
As phaedrux says you're to close to the bed move your nozzle some babysteps higher
