DWC 3.1.1
@luca-Massimiliano said in DWC 3.1.1:
Error: Bad command: Configuration Tool v3.2.3 on Sun Mar 14 2021 01:38:34 GMT+0100 (Ora standard dell’Europa centrale)...
RISOLTO
COME DICEVI TE NO ERA NASCOSTO NEL FILE DELOYPROBLE.G -
non penso sia correto,
VORREI USARE REPETIER HOST TRAMITE WIFI , NON SO COME FARE , MI PUOI INDIRIZZARE ?
I WOULD LIKE TO USE REPETIER HOST VIA WIFI, I DON'T KNOW HOW TO DO IT, CAN YOU ADDRESS ME?
I do not know how to use repetier host.
COSA USI PER STAMPARE?
I upload the sliced file directly from the slicer to the Duet over the network.
@luca-Massimiliano You upload gcode files to the 'Jobs' screen in DWC, print from there!
See: https://duet3d.dozuki.com/Wiki/Duet_Web_Control_v2_and_v3_(DWC)_Manual#Section_JobsIan
@droftarts STL OK?
@luca-Massimiliano No. You need to 'slice' the stl first, with something like Cura or PrusaSlicer, to make a gcode file, then upload that. I think Repetier Server does this for you, but then it transfers the gcode to the Duet by USB (or Telnet over Ethernet/WiFi, which should be faster), as it's printing, which can cause pausing problems.
Most people prefer to have control over the slicing of the stl to gcode, so use a separate program to do this. Repetier Server takes away this control, to make it easier to use. Up to you.
TI RINGRAZIO MA RIPRENDERO DOPO LA STAMPA DIRETTA
IL MIO INIZIALE PROBLEMA PRIMA DI ADGIORNARE TUTTA LA MACCHINA COSA CHE SONO CONTENTISSIMO E RINGRAZIO TUTTI MA IN PARTICOLAR MODO PHAEDRUX PHAEDRUX. E' IL SEGUENTE , IL RISCALDATORE T1 NON VIENE RICONOSCIUTO REPETIER NE DA PRONTERFACE
This post is deleted! -
@leblond are you available for some italian translation?
NON RIESCO INSERIRE PIU' FOTO
IL RISCALDATORE T1 NON VIENE RICONOSCIUTO DA REPETIER NE DA PRONTERFACE ! ECCO LA FOTO DELLA SCHEDA https://duet3d.dozuki.com/Wiki/Hardware_Overview#Section_Firmware_notes
IL RISCALDATORI SONO NOMINATI E1 E0 E BED IN TUTTE LE APPLICAZIONI ,VENGONO NOMINATI E1 E2 E IL BED NOMINATO E0 QUINDI NON VORREI CHE SI CREI UN CONFLITTO , -
QUI SONO GIUSTI:
M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
M308 S1 P"e0temp" Y"thermistor" T100000 B4388 ; configure sensor 1 as thermistor on pin e0temp
M308 S2 P"e1temp" Y"thermistor" T100000 B4388 ; configure sensor 2 as thermistor on pin e1temp
M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2
M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
M143 H2 S280 ; set temperature limit for heater 2 to 280C -
I don't know anything about proterface or repetier. I would suggest you use DWC to interact with the printer.
