Warning on the console since update
@appjaws said in Warning on the console since update:
No they are not from my macro, I think they are coming from the internal G31 code.
As I stated, the macro is not using M120 or M121.
I have also checked the macro and all indents are tabs.When I get those warnings the line number refers to the line in one of my gcode files where I am using conditional code requiring indentation.
Post your files as uploads so we can look at them in a text viewer that shows the difference between tab and space characters.
Here is the relevant file, thanks for your interest
I don't see anything in there. Could it be in the SET_LED macros that get called?
No, The called macros are all ok, just tabs.
Has something changed in the beta firmware in the way G31 operates? -
I had a similar problem with that error message finally was the error not in the macro file where the error point me to but at the bed.g file.
I updated my 6HC to 3.3 beta 2 and I am not getting any warnings like that from invoking G31.
Warning: both space and tab characters used to indent blocks by line 184
Do you have a macro with a line 184?
@Phaedrux
No, all my macros are quite small.
This is really strange, I'll check all my macros again tomorrow . -
@Phaedrux
This is really strange, I'll check all my macros again tomorrow .It can be any gcode file in your SYS or MACRO directory.
@fcwilt
Even if not called?
I'd better check all my files. -
@fcwilt
Even if not called?
I'd better check all my files.Well yes they have to called.
Problem solved, I checked all files and there were a few that had space and tabs. They now have all tabs and the error has been fixed.
Thank you for all who helped
