Connecting to web control
Please post your config.g and the results of M122 and M98 P"config.g"
Do you have a password set in config.g?
Modifying the config.g file is the easiest way with the web settings. Setting mine up I modified the config.g for the correct IP and when I connected it said that the correct files may not have been saved to the www/ folder. What I found out is that I had to type "192.168.0.1/index.html" Without the index.html at the end if didn't correct. I'm sure there's something to fix the index.html requirement, but all in due time.
I'll check when I get home. Forgive my ignorance but I'm not sure what you mean by 'post your config.g'.
Initally I didn't set a password. When web control asked for one, then didn't function I attempted to set one first by going through the configurator again, then in YAT. It doesn't seem to have made a difference. When I put the password in it comes back with invallid.
@Yar said in Connecting to web control:
It means can you copy and paste the contents of your config.g file here so we can see what it's configured to do.
If there is a password set, it would be defined in config.g.
Everything in RepRapFirmware is configured by gcode commands. config.g is just a list of all the commands needed to define your printer at startup. Without config.g it wouldn't do anything.
Good news and bad. I went through the sd card and found that for some reason the latest files didn't copy. I'm sure I must have messed up. Now I seem to be connected, if I send an M115 I get a good firmware response.
Next challenge, the setup instructions on the website
https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+3:+Commissioning/39
want me to go through several steps to ensure everything is working correctly, but the web control is very different from that in the directions. I don't see any of the same menus. -
Here's my current config file
config-print.pdf -
m122
RepRapFirmware for Duet 2 Maestro version 2.02(RTOS) running on Duet Maestro 1.0
Board ID: 08DLM-9T6R1-MD3T0-6J1FA-3S06S-1WQPR
Used output buffers: 4 of 20 (15 max)
Static ram: 19476
Dynamic ram: 99216 of which 0 recycled
Exception stack ram used: 212
Never used ram: 12168
Tasks: NETWORK(ready,672) HEAT(blocked,952) MAIN(running,3940) IDLE(ready,204)
Owned mutexes:
Last reset 00:02:16 ago, cause: power up
Last software reset details not available
Error status: 0
Free file entries: 10
SD card 0 detected, interface speed: 15.0MBytes/sec
SD card longest block write time: 3.2ms, max retries 0
MCU temperature: min 25.7, current 27.5, max 27.9
Supply voltage: min 24.3, current 24.3, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
Driver 0: standstill, read errors 0, write errors 0, ifcount 6, reads 3331, timeouts 0
Driver 1: standstill, read errors 0, write errors 0, ifcount 6, reads 3331, timeouts 0
Driver 2: standstill, read errors 0, write errors 0, ifcount 6, reads 3331, timeouts 0
Driver 3: standstill, read errors 0, write errors 0, ifcount 6, reads 3331, timeouts 0
Driver 4: standstill, read errors 0, write errors 0, ifcount 6, reads 3331, timeouts 0
Driver 5: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 3330
Driver 6: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 3331
Date/time: 2021-03-12 20:31:18
Slowest loop: 4.55ms; fastest: 0.15ms
I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0
Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 240, MaxWait: 0ms, Underruns: 0, 0
Bed compensation in use: none
Bed heaters = 0, chamberHeaters = -1 -1
Heater 1 is on, I-accum = 0.0
Segments left: 0
Movement lock held by null
http is idle in state(s) 0
telnet is idle in state(s) 0
file is idle in state(s) 0
serial is idle in state(s) 0
aux is idle in state(s) 0
daemon is idle in state(s) 0
queue is idle in state(s) 0
lcd is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 7.22ms; fastest: 0.03ms
Responder states: HTTP(0) HTTP(1) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
HTTP sessions: 2 of 8
Interface state 5, link 100Mbps full duplex -
@Phaedrux said in Connecting to web control:
M98 P"config.g"
M98 P"config.g"
HTTP is enabled on port 80
FTP is disabled
TELNET is disabled -
If you still have access to DWC. Upload this zip file in the system tab. Don't extract it first. Reboot after. Use M115 to verify the firmware has been applied. It should show 2.05.1.
For the config you can just copy and paste the text from the window.
The new config
; Configuration file for Duet WiFi (firmware version 2.00)
; generated by RepRapFirmware Configuration Tool v3.2.3 on Fri Mar 12 2021 17:38:06 GMT-0600 (Central Standard Time); General preferences
M550 P"Pierce - Ender 3" ; set printer name; Network
M551 P"Glur2005!" ; set password
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0 S0 ; physical drive 0 goes backwards
M350 E128 I0 ; configure microstepping without interpolation
M350 X16 Y16 Z16 I1 ; configure microstepping with interpolation
M92 X80.00 Y80.00 Z400.00 E93.00 ; set steps per mm
M566 X600.00 Y600.00 Z60.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
M203 X9000.00 Y9000.00 Z600.00 E6000.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z120.00 E5000.00 ; set accelerations (mm/s^2)
M906 X800 Y800 Z800 E900 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X235 Y235 Z260 S0 ; set axis maxima; Endstops
M574 Z1 S2 ; set endstops controlled by probe; Z-Probe
M558 P1 H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
G31 P500 X-45 Y-10 Z2.5 ; set Z probe trigger value, offset and trigger height
M557 X10:220 Y10:220 S20 ; define mesh grid; Heaters
M305 P0 T9880 B4185 R4700 ; set thermistor + ADC parameters for heater 0
M143 H0 S80 ; set temperature limit for heater 0 to 80C
M305 P1 T9880 B4185 R4700 ; set thermistor + ADC parameters for heater 1
M143 H1 S250 ; set temperature limit for heater 1 to 250C; Fans
M106 P0 S0 I0 F20 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P1 S0 I0 F20 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
M106 P2 S0 I0 F20 H1:0 T45 ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C; Custom settings
m918 p1 e4 ; enable 12864 LCD with 1 menu item per encoder click; Miscellaneous
T0 ; select first tool -
Another thing I've noticed is the LCD lights and has info displayed but the knob/button doesn't do anything
@Yar Is that the stock ender 3 screen and encoder wheel?
Does M115 show 2.05.1 and Is the DWC version also 2.x?
https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+1:+Wiring/37
Check out this series of guides on getting the Ender 3 an Maestro setup.
Yes, stock screen and encoder. I figured out the display and encoder, they function now.
Yes, Reprap 2.05.1. DWC 2.0.4
That's is the instruction set I've been following since the start.Going through the tests both heaters are showing fault. I double checked the wiring based on the instructions. Suggestions?
What exactly does the fault error message say?
M305 P0 T9880 B4185 R4700 ; set thermistor + ADC parameters for heater 0 M143 H0 S80 ; set temperature limit for heater 0 to 80C M305 P1 T9880 B4185 R4700 ; set thermistor + ADC parameters for heater 1
I think your T values may be missing a digit.
Should be
98801
The screenshots in that guide cut off the last character of that value but it's basically close to 100000.
Based on your suggestion I changed the value by adding a "1", so 98801. That fixed both the hot end and the bed! Thanks for that! My bad for looking at the image, not the text!
My next issue is setting up for a EZABL. I've looked at the install text from TX3D. At this point I don't want to mess up what has been done, but the printer clearly isn't recognizing the sensor isn't funtioning properly without its code. The instructions say to install config.h (appropriately adjusted) but I don't find a config.h in the sys file. Should I simply add it?
Really appreciate your patience and assistance with all this!!
config.h
Probably means config.g which is the main configuration file for RepRapFirmware.
Check M588 the type of sensor "might" be wrong for abl
Once thats set and it functions...calibrate height. Procedures There are complete instructoind on how to setneverything in The duet documentation portion of this site. Hope this helps. To get to that part hit the three bars at top left for site pulldown menus look for the z-probe section there is tables with all the sensor setting for any z probe sensor
(Just in case) hope this help -
Found a post on your site
https://forum.duet3d.com/topic/8963/ezabl-z-probe-wiring-and-configuration/8
TH3D's suggested code is M558 P5 C"!zprobe.in" H3 F900 T1200. When I change the probe type as in the post to l1 for M558 the sensor seems to work fine. However, when I turn off the machine then turn it back on the sensor doesn't work, unless I put the M558 in again.Thoughts?
@Yar P5 is from before P9 existed specifically for the BLtouch.
