Diag flashing
@Phaedrux m98 missing parameter āpā
@Phaedrux said in Diag flashing:
M98 P"config.g"
That's the full command.
M98 calls a macro defined by P"whatever macro name"
; generated by RepRapFirmware Configuration Tool v3.2.3 on Sat Mar 06 2021 22:50:41 GMT-0700 (Mountain Standard Time); General preferences
M550 P"SWX1 Duet" ; set printer name
M669 K1 ; select CoreXY mode; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M92 X80.00 Y80.00 Z400.00 E415.00 ; set steps per mm
M906 X900 Y900 Z900 E900 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X300 Y300 Z400 S0 ; set axis maxima; Endstops
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
M557 X15:215 Y15:195 S20 ; define mesh grid; Heaters
M143 H1 S300 ; set temperature limit for heater 1 to 300C; Fans
M106 P1 S0 H1 T45 ; set fan 1 value. Thermostatic control is turned on
M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency
M106 P2 S0 H1 T45 ; set fan 2 value. Thermostatic control is turned on; Tools
M563 P1 D0 H1 F0 ; define tool 1
G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C; Custom settings are not defined
@Phaedrux guess im not fallowing ,
@anthony1m said in Diag flashing:
Is your machine CoreXY? Because you have it set as such. This will move both motors for an X or Y move.
Edit: please post your homing files, as @Phaedrux asked you to.
In the console tab send this command
M98 P"config.g"
and copy and paste the response here. It might show some errors or messages. -
M98 P"config.g"
3/10/2021, 7:27:21 PM M98 P"config.g"
HTTP is enabled on port 80
FTP is disabled
TELNET is disabled -
This post is deleted! -
@anthony1m That looks good. No errors anyway.
WiFi firmware version 1.23
It looks like the wifi server didn't get updated.
Try uploading the full release zip file again to the system tab in DWC. Just to make sure everything is correct.
https://github.com/Duet3D/RepRapFirmware/releases/download/3.2.2/Duet2and3Firmware-3.2.2.zip
Will need to see your homing files to say why it's moving the way it's moving during homing. Post homeall.g homex.g homey.g homez.g and bed.g if you've set that up yet.
@Phaedrux I'm close3/10/2021, 8:10:02 PM m122
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2.2 running on Duet WiFi 1.02 or later
Board ID: 08DLM-996RU-N85S4-7JTD6-3SJ6R-KA9BR
Used output buffers: 3 of 24 (10 max)
Static ram: 23460
Dynamic ram: 73268 of which 40 recycled
Never used RAM 15312, free system stack 189 words
Tasks: NETWORK(blocked,186) HEAT(blocked,308) MAIN(running,457) IDLE(ready,20)
Owned mutexes: WiFi(NETWORK)
Last reset 00:01:47 ago, cause: software
Last software reset at 2021-03-10 20:08, reason: User, GCodes spinning, available RAM 15068, slot 2
Error status: 0x00
Aux0 errors 0,0,0
MCU temperature: min 31.3, current 32.0, max 32.4
Supply voltage: min 21.9, current 22.1, max 22.3, under voltage events: 0, over voltage events: 0, power good: yes
Driver 0: position 0, standstill, SG min/max not available
Driver 1: position 0, standstill, SG min/max not available
Driver 2: position 0, standstill, SG min/max not available
Driver 3: position 0, standstill, SG min/max not available
Driver 4: position 0, standstill, SG min/max not available
Driver 5: position 0
Driver 6: position 0
Driver 7: position 0
Driver 8: position 0
Driver 9: position 0
Driver 10: position 0
Driver 11: position 0
Date/time: 2021-03-10 20:10:01
Cache data hit count 129951247
Slowest loop: 4.40ms; fastest: 0.21ms
=== Storage ===
Free file entries: 10
SD card longest read time 3.2ms, write time 0.0ms, max retries 0
=== MainDDARing ===
=== AuxDDARing ===
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 15.91ms; fastest: 0.00ms
HTTP sessions: 1 of 8- WiFi -
Network state is active
WiFi MAC address 48:3f:da:88:d4:72
WiFi Vcc 3.38, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 22120
WiFi IP address 192.168.0.197
WiFi signal strength -36dBm, mode none, reconnections 0, sleep mode modem
Clock register ffffffff
- WiFi -
@Phaedrux I think you can check this as solved . I will work on it and if I run into any issued Ill read the information and ask for help if I need it. You guys are awesome thank you.
@Phaedrux well this happened again except now the diag is on solid and windows disconnected right away. it was fine middle of a print it dropped connection and does nothing.
@Phaedrux any ideas Its on a new meanwell ps also , why this board keeps having diag issues it brand new.
https://duet3d.dozuki.com/Wiki/What_to_do_if_your_Duet_won't_respond
Can you run through this guide and see how far you can get?
@Phaedrux yes thank you I am working on that now.
"Error reading device descriptor" This is as far as I get, I can't get past that. That's the one I was working last night before I came back here. my mac or rpi 4 wont see it either usb not recognized with or with a sd card different ports and cables and restart of the machine.
@Phaedrux Had it dialed in was producing some great prints, Then just in the middle stopped and could not connect again.
When and where did you purchase the Duet?
What LEDs light up when connected to VIN or USB?
