help for beginners
https://duet3d.dozuki.com/Wiki/Connecting_and_configuring_a_chamber_heater
You can use the online config tool to setup a chamber heater as well. That will give you a good example of the gcode needed for your firmware version and let you choose which heater and sensor to use.
This post is deleted! -
Tell me why the heating icon of the printer camera does not light up on the touch screen and there is no adjustment
There have been some enhancements for chamber heater support in RRF3 and the recent 3.x PanelDue firmwares.
Please tell us what firmware you have on the Duet and PanelDue and how you have the chamber configured.
the camera sign on the web page is visible and working. but it is not on the screen. firmware 2.05 and how to raise it to 3, I do not understand, I have already read everything but is not stitched.
Tell me how I can connect and activate drivers to the board that are much more powerful than those installed on the board
@sergei said in help for beginners:
If you still have access to DWC. Upload these 3 zip files, one at a time in the system tab. Don't extract them. Reboot after each. Use M115 to verify the firmware has been applied.
https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
https://github.com/Duet3D/RepRapFirmware/releases/download/3.2.2/Duet2and3Firmware-3.2.2.zip
That will get your firmware and DWC up to date.For your config, might be a good idea to run through the configurator tool and generate a fresh set for RRF3.
https://configtool.reprapfirmware.org/Start@sergei said in help for beginners:
https://duet3d.dozuki.com/Wiki/Using_external_stepper_motor_drivers
you can tell how to connect external drivers nevertheless. to those links that you sent me. I do not understand anything at all how to do it. I tried to flash the board to version 3, but it remained 2. how can I debug all this
in which program should I flash the board? I have duo 2 internet
how can I register external drivers here?
Hello. Tell me how to correctly implement the Z probe after the probe passes the entire surface of the table during printing, the z axis should move. and she stands
I don't understand the question.
What is the probe? How is it configured? How are you trying to activate it? -
tell me. is it possible to make SNS on the Duet 2 board
@sergei What is SNS?
CNC milling machine
Can I get a ready-made firmware somewhere?
It already is available in the firmware. You just need to send the gcode command to switch to CNC mode.
Maybe I don't understand what you actually mean here.
and what kind of command it is and where to register it. can you tell in more detail
